Raspberrypi+ ic880a gateway
(Vignesh Varan) #1
I am trying to configure raspberry pi 3 with ic880a gateway...but it asks for git hub user name and password....I created an account in git hub and entered the necessary details...but i cant proceed after that....Authentication failed is appearing....pls help me with this issue.
(Remko) #2
Likely your problem is taht you have not "identified" your device to github:
I managed it this way:
Generate SSH key at your device (RPI)
$ ssh-keygen -t rsa -b 4096 -C youreEmailAddress@github
Presse Enter to accept default location
Press Enter twice to set pass phrase to none.
Print new SSH key to screen
$ cat ls .ssh/id_rsa.pub
Select and copy the printed SSH key to github at: https://github.com/settings/keys
Now your device is accepted by github.
I hope it helps.
(Vignesh Varan) #3
Thanks for ur help sir.....but Its asking for a usernamr and password..after entering the correct username and password it is asking for command line....if i give exit also...it again asks for the username and password
(Remko) #4
after a plain installation of wheezy username is pi en password is raspberry.
