Reconfiguring / factory resetting 'Turnkey' Sensors
(Nick) #1
Beginner help required :grinning:! I’ve purchased a few different packs of sensors from “turnkey” solutions providers such as MyDevices as part of an R&D project.
I’ve also built/setup my own TTN gateway (ie using a Raspberry Pi - not from MyDevices).
  1. I’m guessing that the various MyDevices sensors get pre-joined OTAA to a private MyDevices Network Server. Is that correct? (I assume this as I can connect those devices and see them in a Cayenne MyDevices dashboard just by knowing their dev euid)
  2. So now I want to reconfigure these devices to connect directly to my ThingsNetwork application, via my own built TTN gateway. Is that even possible?
I only have the DevEUID for these sensors and as far as I can tell logging into Cayenne / MyDevices allows me to add and remove devices from my MyDevices application but NOT the MyDevices Network Server.
Any help and advise greatly appreciated!
(Nick) #2
Are the above dumb questions? If so kindly enlighten me.
#3
maybe you tell us first what ’ a few different packs of sensors ’ are ?
enlighten us :sunglasses:
(Nick) #4
Sure thing!
Well I have one of these for example:
Tabs Motion Sensor
I also have one of these in the pack:
Netvox Wireless Water Sensor
http://www.netvox.com.tw/um/r311w/r311wDataSheet.pdf
@BoRRoZ would you agree with my question1 assumption that all of these devices have been pre-joined to the MyDevices Network Server before being sent out to me/customers?
Many thanks
Nick
#5
  • The movement detector
’ The device shall enter installation mode after being commanded by the network and remain in installation mode until commanded by the network. ’
  • The watersensor
’ Availablethird-partyplatform:Actility/ThingPark,TTN,MyDevices/Cayenne ’
My impression is that they are (real turnkey) indeed preprogrammed for a specific network and without help of the manufacturer not easy to reconfigure for use on TTN.
(Nick) #6
Thank you @BoRRoZ. That’s frustrating learn but I appreciate the reply.
