Dear TTN crew,
I discovered that for the following settings for registering a new end device in the V3 console is fetching forever.
Can you suggest your help?
Thanks for letting us know. I can confirm the issue.
@kschiffer @bafonins: It looks like the Console doesn’t show the error that’s returned by the server.
"code": 5,
"message": "error:pkg/fetch:file_not_found (file `vendor/example/elsys-eu868-profile.yaml` not found)",
"details": [
"namespace": "pkg/fetch",
"name": "file_not_found",
"message_format": "file `{filename}` not found",
"attributes": {
"filename": "vendor/example/elsys-eu868-profile.yaml"
"correlation_id": "888a9bdaa69d4456a4a0acf2b83b0513",
"code": 5
The problem seems to be line 34 of vendor/elsys/ers-co2-lite.yaml in the device repository which incorrectly tries to load a profile from the example
vendor. I’ll ask someone to fix that for the next release.
Hey @Flo356! Thank you for reporting this issue. This is now fixed and the Console will properly handle such errors in the next release.
