Hello guys!
I am working with LoStick from Ronoth, which has a RN2483 module on it.
I did some tests with MAC commands and I am a bit confused. Some of the values I read out are not correct or at least do not match with my expectations.
radio get snr
From the command I get values of 6 and 7 for the last received packet. But on the gateway I have values around 8 or 9. Is this maybe just an error of measurment? -
radio get rxbw
Corresponding to this command I receive packets always with a bandwidth of 25 kHz. But on the gateway I see uplinks and downlinks with 125 kHz -
radio get rssi
Does not work at all invalid_param -
mac get gwnb
I know around are several gateways, which I could reach, but LoStik tells me, that there are 0 receiving LinkCheckReq. Can I simulate such a message with TTN?
The guide with the commands can be found here:
Did someone experienced the same issues?
Thanks for your help
G
