# Single channel gateway
**URL:** <https://www.thethingsnetwork.org/forum/t/single-channel-gateway/57224>\
**Category:** The Things Stack v3\
**Created:** [May 26, 2022, 8:33am UTC](https://www.thethingsnetwork.org/forum/t/single-channel-gateway/57224 "2022-05-26T08:33:48Z")\
**Showing post:** 2
**Post date:** [May 26, 2022, 8:50am UTC](https://www.thethingsnetwork.org/forum/t/single-channel-gateway/57224/2 "2022-05-26T08:50:02Z")
> [@manisha07](#):
> Can i build a single channel gateway using these components
No for two reasons:
- There is no such thing as a single channel gateway - a gateway has 8 channels minimum
- The RN module isn’t designed for all the things you may need out of a radio listening for multiple random transmissions.
A simple search fo the forum would tell you that Single Channel Packet Forwarders are disruptive to the TTN network and are unsupported. See:
> [@Single Channel Packet Forwarders (SCPF) are obsolete and not supported](https://www.thethingsnetwork.org/forum/t/single-channel-packet-forwarders-scpf-are-obsolete-and-not-supported/31117):
> Single channel packet forwarders are obsolete and are not supported Single Channel in this article refers to both Single Channel and Dual Channel devices (and any variations thereof). Single Channel Packet Forwarders are not LoRaWAN compliant gateways. They negatively impact proper operation of gateways and end devices (nodes) in their area which means they negatively impact The Things Network and its users, but they also impact other LoRaWAN operators. Not only now, but also in the future wh…
If you value any part of your time, a compliant gateway is less than $100 and doesn’t require you to send days debugging your devices that can’t understand why they can’t use any of the 8 channels they expect to.
_[View the full topic](https://www.thethingsnetwork.org/forum/t/single-channel-gateway/57224)._
