# ST LoRa® IoT tracker - STEVAL-STRK01
**URL:** <https://www.thethingsnetwork.org/forum/t/st-lora-iot-tracker-steval-strk01/22975>\
**Created:** [February 20, 2019, 11:06am UTC](https://www.thethingsnetwork.org/forum/t/st-lora-iot-tracker-steval-strk01/22975 "2019-02-20T11:06:17Z")\
**Showing post:** 58
**Author:** ![stdemo](https://www.thethingsnetwork.org/forum/user_avatar/www.thethingsnetwork.org/stdemo/32/35697_2.png) [@stdemo](https://www.thethingsnetwork.org/forum/u/stdemo)\
**Post date:** [March 13, 2019, 9:59am UTC](https://www.thethingsnetwork.org/forum/t/st-lora-iot-tracker-steval-strk01/22975/58 "2019-03-13T09:59:56Z")
Hi malbec,
the command ?devicejoinparam gives you information about the keys that the device is currently used.
If the keys are correct, you have to investigate on the gateway configuration and distance.
I am using this pretty gw, the TTN indoor gateway [TTIG : The Things Indoor Gateway](https://www.thethingsnetwork.org/forum/t/ttig-the-things-indoor-gateway/22049) and the STEVAL-STRKT01 works correctly.
_[View the full topic](https://www.thethingsnetwork.org/forum/t/st-lora-iot-tracker-steval-strk01/22975)._
