# Still stuck at EV\_JOINING
**URL:** <https://www.thethingsnetwork.org/forum/t/still-stuck-at-ev-joining/24394>\
**Created:** [March 27, 2019, 9:00am UTC](https://www.thethingsnetwork.org/forum/t/still-stuck-at-ev-joining/24394 "2019-03-27T09:00:58Z")\
**Showing post:** 6
**Post date:** [March 27, 2019, 11:16am UTC](https://www.thethingsnetwork.org/forum/t/still-stuck-at-ev-joining/24394/6 "2019-03-27T11:16:01Z")
> [@Toberto](#):
> I think the device got now a downlink?
You cannot tell from TTN Console if the device received it. You only know that TTN wanted a gateway to transmit it. (Might also be another gateway if your uplink was received by multiple gateways.)
> [@Toberto](#):
> again: only sending once…
Again: your device is waiting for the downlink, but not receiving it.
> [@arjanvanb](#):
> your single-channel test gateway does not support downlinks
Some single-channel test gateways _do_ support downlinks, so one could say it’s the software of your gateway.
(Also, your device should not ask for a confirmation for each uplink, see [Fair Use Policy explained](https://www.thethingsnetwork.org/forum/t/limitations-data-rate-packet-size-30-seconds-uplink-and-10-messages-downlink-per-day-fair-access-policy/1300))
_[View the full topic](https://www.thethingsnetwork.org/forum/t/still-stuck-at-ev-joining/24394)._
