# Systematic data pauses between gateway and application
**URL:** <https://www.thethingsnetwork.org/forum/t/systematic-data-pauses-between-gateway-and-application/62352>\
**Category:** TTN Network and Services\
**Created:** [April 2, 2023, 2:35pm UTC](https://www.thethingsnetwork.org/forum/t/systematic-data-pauses-between-gateway-and-application/62352 "2023-04-02T14:35:16Z")\
**Showing post:** 6
**Post date:** [April 9, 2023, 7:07pm UTC](https://www.thethingsnetwork.org/forum/t/systematic-data-pauses-between-gateway-and-application/62352/6 "2023-04-09T19:07:15Z")
> [@Hotte93](#):
> I had not entered these extra whereby always only 3 standard frequencies have come through.
Up to date versions of LMIC do include this. As do older versions. But you have highlighted why ABP sucks.
> [@Hotte93](#):
> My current problem is that sending data to the application freezes after an undefinable time.
This is most likely hardware related as I have [nodes on hundreds of thousands of uplinks on LMIC on ABP](https://www.thethingsnetwork.org/forum/t/the-workbench-part-5/31726/102)
> [@Hotte93](#):
> From this point on, the end device no longer receives data despite the display on the gateway.
By freezing do you mean the debug serial log isn’t showing any more info? [Please think ahead to what information will help the volunteers with answering] Do you mean downlinks which is the end device receiving? If the firmware has frozen then nothing a gateway transmits is going to cause a device to restart.
As above, I’ve devices that are doing just fine. But getting LMIC in to an ATmega328 leaving room for local variables takes some configuration. What optimisations have you implemented?
_[View the full topic](https://www.thethingsnetwork.org/forum/t/systematic-data-pauses-between-gateway-and-application/62352)._
