The BARGAIN basement part 5
03%20PM
25%20AM
53%20PM
06%20AM
:no_mouth:
41%20PM
… but can you get an RJ45 connector on the end of a cable through the gland?
That’s why you crimp you own cables. Attach the RJ45 after threading the utp cable through the gland.
37%20PM
diy - https://www.ebay.com/itm/DC6V-12V-24V-Miniature-Hand-Crank-Wind-Hydraulic-Generator-Dynamotor-Motor-Hot/362652263223
Yes you can if you use a M20 gland.
The right make and model have sufficient turn-down on the gland to seal on the cable but are large enough to pass the RJ45 plug. The glands in the link are from the PG series, they are too small but an M20 is slightly larger and they work.
06%20PM
mchip-discount
21%20AM
You can also use a split gland.
11%20PM
07%20AM
I wonder if this works as an UPS…
29%20PM
36%20PM
13%20PM
All-in-one USB Oscilloscope, Signal Generator, Power Supply, Logic Analyzer and Multimeter USD $29.00
20%20AM
