The NOT CONNECTED / NOT SEEN in console CENTRAL topic part 1
For the noc problem, try changing https to http. Like this:
http://noc.thethingsnetwork.org:8085/api/v2/gateways/pico-gw-647fdafffe0052d9
I did see performance issues… but see lots of the other gateways in my area are up so was trying to see if it was an issue on my end (firmware or connectivity).
So re-flashing my firmware won’t help?
Thanks,
Brad
Very doubtful if you haven’t changed any settings the existing firmware and settings should be good.
Mi minigateway ttgo esp32 lora, not received data console ttn. I have configured all. Yesterday I can see data but today not.
02
Been wondering why I have been showing Not Connected for 5 or so days. Did a complete reset, to include deleting my gateway, reseting it, registering it. But it still shows Not Connected. I am using the Things Indoor Gateway (tabs).
what’s the EUI and what’s the region you are located ?
eui-70b3d57ed0021190
ttn-router-us-west
p.s. I see it connecting and drawing an DHCP IP address on my router.
tnx… not for me but if dev ops want to check / test some things
you sure that EUI is from a TTIG ? :thinking:
My gateway (eui-b827ebfffe993b67) has also been showing as “not connected” for 8 days now, although data has still been coming in successfully the entire time. It’s using the ttn-router-us-west router and it’s a LoRaGO PORT (https://sandboxelectronics.com/?product=lorago-port-multi-channel-lorawan-gateway), which uses the iC880A. It’s been running fine for the past 7 months.
We have a gateway (eui-647fdafffe007dbc) not seen at console for 11 days, yet it is handling traffic. US915 in Canada.
Are there any mechanisms in TTN to quarantine a gateway if there were problems to get Join Accepts or downlinks through? We had some issues related to packet logger but all is fixed now and traffic is being handled. Alas, the NOC and Console don’t show the GW as Connected.
off topic …
05%20AM
Hi all!
Our two routers appear offline in the console. The first one stop showing about 11 days, today we lost another one.
Routers are:
eui-b827ebfffe2fd3a7
and
eui-b827ebfffe330013
Both are connected to the region ttn-router-us-west
From our side router.us.thethings.network resolves to 13.66.213.36
Appears that are not receiving the ACK for upstream packages. I This routers are directly connected to Internet:
ago 29 14:41:27 raspberrypi ttn-gateway[631]: ### [PERFORMANCE] ###
ago 29 14:41:27 raspberrypi ttn-gateway[631]: # Upstream radio packet quality: 0.00%.
ago 29 14:41:27 raspberrypi ttn-gateway[631]: # Upstream datagram acknowledgment quality for server "router.us.thethings.network" is 0.00%.
ago 29 14:41:27 raspberrypi ttn-gateway[631]: # Downstream heart beat acknowledgment quality for server "router.us.thethings.network" is 100.00%.
ago 29 14:41:27 raspberrypi ttn-gateway[631]: # Downstream datagram content quality for server "router.us.thethings.network" is 0.00%.
ago 29 14:41:27 raspberrypi ttn-gateway[631]: # Downstream radio transmission quality for server "router.us.thethings.network" is 100.00%.
ago 29 14:41:27 raspberrypi ttn-gateway[631]: # Downstream beacon transmission quality: 0.00%.
TCPDUMP shows port activity and answers from that IP.
XX@XXXX:~ $ sudo tcpdump -n udp port 1700
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth0, link-type EN10MB (Ethernet), capture size 262144 bytes
14:46:03.407116 IP 168.24X.XX.XX.48604 > 13.66.213.36.1700:  [|radius]
14:46:03.546045 IP 13.66.213.36.1700 > 168.24X.XX.XX.48604:  [|radius]
14:46:08.577126 IP 168.24X.XX.XX.48604 > 13.66.213.36.1700:  [|radius]
14:46:08.710578 IP 13.66.213.36.1700 > 168.24X.XX.XX.48604:  [|radius]
14:46:13.747120 IP 168.24X.XX.XX.48604 > 13.66.213.36.1700:  [|radius]
14:46:13.877812 IP 13.66.213.36.1700 > 168.24X.XX.XX.48604:  [|radius]
14:46:18.917118 IP 168.24X.XX.XX.48604 > 13.66.213.36.1700:  [|radius]
14:46:19.026064 IP 13.66.213.36.1700 > 168.24X.XX.XX.48604:  [|radius]
14:46:24.057121 IP 168.24X.XX.XX.48604 > 13.66.213.36.1700:  [|radius]
14:46:24.196634 IP 13.66.213.36.1700 > 168.24X.XX.XX.48604:  [|radius]
14:46:27.642529 IP 168.24X.XX.XX.48362 > 13.66.213.36.1700: RADIUS, Access-Accept (2), id: 0xc7 length: 256
Activity appears fine. Looks like there is nothing blocking port 1700.
Gateways were reset several times without success. Any ideas?
UPDATE: It shows activity only on new data.
I have a gateway with the same issue. Showing not connected, but data is coming through.
very informative first post :wink:
Thought having a report of the issue still happening was going to be helpful. What other information should I have provided to turn that wink into a smile?
minimal what gateway type , router / region, maybe EUI ,when did it start, what did you try (reboot?) ect, things like that, So the developpers have some more info.
what you were saying is ’ he, its raining here too ’ > smile :grin:
still down after a few weeks, just getting back to this… lots of reboots but no luck, firm ware flash time? Thanks.
got it, thanks for the reply. My gateways actually started showing up as expected in the UI. For the record they are Things Indoor Gateways on US/West. Tried reboots on some of them. Started about 12 days ago but working as expected now (I haven’t checked in 3 days though)
tnx for the info :sunglasses:
