The things uno otaa denied
(Patrickbr) #1
I have an thing uno from a workshop of the IOT tech day 2016.
im trying to connect to the things network with the website console but it failed. im in range of 2 gateway’s in the middle of the city Leiden in the Nederlands.
-- STATUS
EUI: 0004A30B001B8040
Battery: 3243
AppEUI: 70B3D57ED0007799
DevEUI: 0004A30B001B8040
Data Rate: 5
RX Delay 1: 1000
RX Delay 2: 2000
-- JOIN
Model: RN2483
Version: 1.0.1
Sending: mac set deveui 0004A30B001B8040
Sending: mac set adr off
Sending: mac set appeui 70B3D57ED00078FF
Sending: mac set appkey 191331EB107E4094172061D758212C21
Sending: mac save
Sending: mac set rx2 3 869525000
Sending: mac set ch drrange 1 0 6
Sending: mac set ch dcycle 0 799
Sending: mac set ch dcycle 1 799
Sending: mac set ch dcycle 2 799
Sending: mac set ch dcycle 3 799
Sending: mac set ch freq 3 867100000
Sending: mac set ch drrange 3 0 5
Sending: mac set ch status 3 on
Sending: mac set ch dcycle 4 799
Sending: mac set ch freq 4 867300000
Sending: mac set ch drrange 4 0 5
Sending: mac set ch status 4 on
Sending: mac set ch dcycle 5 799
Sending: mac set ch freq 5 867500000
Sending: mac set ch drrange 5 0 5
Sending: mac set ch status 5 on
Sending: mac set ch dcycle 6 799
Sending: mac set ch freq 6 867700000
Sending: mac set ch drrange 6 0 5
Sending: mac set ch status 6 on
Sending: mac set ch dcycle 7 799
Sending: mac set ch freq 7 867900000
Sending: mac set ch drrange 7 0 5
Sending: mac set ch status 7 on
Sending: mac set pwridx 1
Sending: mac set retx 7
Sending: mac set dr 5
Sending: mac join otaa
Join not accepted: denied
Check your coverage, keys and backend status.
Response is not OK: no_free_ch
Send join command failed
have have used the default code from TTN
#include <TheThingsNetwork.h>
// Set your AppEUI and AppKey
const char *appEui = "70B3D57ED00078FF";
const char *appKey = "191331EB107E4094172061D758212C21";
#define loraSerial Serial1
#define debugSerial Serial
// Replace REPLACE_ME with TTN_FP_EU868 or TTN_FP_US915
#define freqPlan TTN_FP_EU868
TheThingsNetwork ttn(loraSerial, debugSerial, freqPlan);
void setup()
  loraSerial.begin(57600);
  debugSerial.begin(9600);
  // Wait a maximum of 10s for Serial Monitor
  while (!debugSerial && millis() < 10000)
  debugSerial.println("-- STATUS");
  ttn.showStatus();
  debugSerial.println("-- JOIN");
  ttn.join(appEui, appKey);
void loop()
  debugSerial.println("-- LOOP");
  // Prepare payload of 1 byte to indicate LED status
  byte payload[1];
  payload[0] = (digitalRead(LED_BUILTIN) == HIGH) ? 1 : 0;
  // Send it off
  ttn.sendBytes(payload, sizeof(payload));
  delay(10000);
Unable to connect Things Node to Multitech Conduit IP67
#2
output serial looks ok to me
update firmware RN2483 from 1.01 to 1.03
update TheThingsNetwork.h
* solder another antenna :wink:
this is one from me
(Hylke Visser) #3
How do you know that you’re in range of those two gateways? Did you test with another device? If so, how’s the signal quality (RSSI/SNR) if you look in the console?
The 2016 prototype of the Uno didn’t have a very good antenna, so unless you soldered a real antenna on top of it, it may only work if you’re really close to the gateway (tens of meters).
(Patrickbr) #5
Without update i test it closer to the gateways without updates. i have a connection and ataa packages.
rssi: -115
snr: -5.8
#6
then it was your antenna like htdvisser mentioned :sunglasses:
how close is close ?
(Patrickbr) #7
about 100 meters from the building where the antenna is placed on the top (11 floors building)
#8
then the received signal strength still indicates a bad antenna
I suggest to remove the onboard antenna and replace with something like this
just cut the ipx connector, strip the wire and solder on the board.
(Patrickbr) #9
for fun an experiment in Leiden: an walk from central station to school:
https://ttnmapper.org/experiments/map.php?name=experiment_201710241110
i have orderd an anatenna
