The WORKBENCH
(Phil Wilko) #707
@paulb, what software are you running on your node, I have struggled with the esp8266
#708
#709
@Amedee i got it running, thank you very much for the integration of collectd to the resin.io ttn gateway setup! Even encryption for transmitting the data per udp is working - just one little question: where do you get the supply voltage from in your screenshot from grafana? Per collectd? How? Thank you very much!
(Amedee) #710
Cool!
You need some additional hardware to read the supply voltage…
I am using @dbrgn backplane which has a Sensirion SHT21 for temperature/humidity and a Microchip MCP3425 for the voltage.
When you set GW_BACKPLANE=DBRGN in resin.io , the run script of the Collectd container will enable 2 Python Collectd plugins to pass the data to Collectd.
Plugins ‘source’ is available here
#711
Ahh thx for the info, my gateways are build on the pcb from @Charles (c2h), so i have to build something on my own to measure the voltage.
#712
addicted
:rofl:
#713
What a pity of all that gold. :wink:
(Remko) #714
Well, that is a valueable home
#715
Sniffing Lora with a cheap RTL-SDR dongle
The screencast was taken with a bandwidth of 7.8 kHz CR 4/5 and SF12
#716
what app did you use?
could you please also publish the parameters used for your sample?
thanks!
#717
A pity with a cheap RTL-SDR dongle and a program like SDR# (SDRsharp) is that the full LoRaWAN spectrum (868MHz at least) is not completely visible at once on the screen. So when it hops to a different channel that frequency may be off screen.
It is not possible to zoom out far enough to make all channels visible onscreen.
This is probably a limitation of the RTL-SDR dongle I assume(?).
#718
@ursm The application is SDR # (SDRSharp) like bluejedi has already been noticed.
About the parameters:
For the controller (dongle)
RTL-SDR_1
From the Radio drop-down menu
RTL_SDR_3
And the FFT Display
RTL-SDR_2
Does this answer your questions ?
#719
My pictures look very different. Any idea why (did I miss some settings)?
Your SDR# shows version v0.0.0.0 (v0.0 really?) and your UI (dialogs) look different.
The version that I used is: v1.0.0.1637 (on Windows 10).
Below some pictures:
(The pictures were automatically downsized while uploading. I don’t know why they cannot be clicked for full size and why they do not show the file name.)
RTL-SDR%20-%20Without%20AGC
AGC disabled
RTL-SDR%20-%20Without%20AGC%20-%20More%20zoomed%20out
With AGC disabled (lower noise floor) and more zoomed out.
RTL-SDR%20-%20Without%20AGC%20-%20More%20zoomed%20out%20-%20Partial
With AGC disabled (lower noise floor) and more zoomed out (partial).
Added because full picture cannot be maximized.
RTL-SDR%20-%20With%20RTL%20AGC
RTL AGC enabled
RTL-SDR%20-%20With%20RTL%20AGC%20-%20More%20zoomed%20in
With RTL AGC enabled (higher noise floor) and more zoomed in.
RTL-SDR%20-%20With%20RTL%20AGC%20-%20More%20zoomed%20in%20-%20Partial
With RTL AGC enabled (higher noise floor) and more zoomed in (partial)
More partial pics (because the full pictures cannot be maximized):
capture%202018-04-05%2022%C2%B747%C2%B731 capture%202018-04-05%2022%C2%B747%C2%B746
#720
I am running sdrsharp on my Linux computer, that makes the difference in the user interface and is probably the reason for the strange version number.
For the sample i didn’t used a LoraWAN package. I used a very low bandwith 7.8 kHz and the highest sprading factor sf12.
#721
You can use this sketch with a Pro mini and a RFM95.
 *  Version:           1.0.1
 *  Design:            Clemens
 * Channel CH1 868.100 MHz
 * Channel CH2 868.300 MHz
 * Channel CH3 868.500 MHz
 * Channel CH4 867.100 MHz
 * Channel CH5 867.300 MHz
 * Channel CH6 867.500 MHz
 * Channel CH7 867.700 MHz
 * Channel CH8 867.900 MHz
 * Channel CH9 869.525 MHz
#include <SPI.h>
/*------------ REGISTERS -------------*/
#define RegFifo               0x00
#define RegOpMode             0x01
#define RegFrfMsb             0x06
#define RegFrfMid             0x07
#define RegFrfLsb             0x08
#define RegPaConfig           0x09
#define RegLna								0x0C
#define RegFifoAddrPtr        0x0D
#define RegFifoTxBaseAddr     0x0E
#define RegFifoRxBaseAddr     0x0F
#define RegFifoRxCurrentAddr  0x10
#define RegIrqFlags           0x12
#define RegRxNbBytes          0x13
#define RegPktSnrValue        0x19
#define RegPktRssiValue       0x1A
#define RegModemConfig1       0x1D
#define RegModemConfig2       0x1E
#define RegModemConfig3       0x26
#define RegSymbTimeoutLsb     0x1F
#define RegPreambleMsb        0x20
#define RegPreambleLsb        0x21
#define RegPayloadLength      0x22
#define RegInvertIQ           0x33
#define RegSyncWord           0x39
/*--------- DIO mapping --------------*/
#define RegDioMapping1        0x40
#define RegDioMapping2        0x41
// DIO function mappings               D0D1D2D3
#define RXDONE                0x00  // 00------
#define TXDONE                0x40  // 01------
#define RXTOUT                0x00  // --00----
/*--------- RegOpMode ---------------*/
#define MODE_SLEEP            0x00
#define MODE_STANDBY          0x01
#define MODE_TX               0x03
#define MODE_RXSINGLE         0x06
#define MODE_RXCONTINUOUS     0x05
#define MODE_LORA             0x80
/*--------- IRQ Flags --------------*/
#define TX_DONE               0x08
#define VALID_HEADER          0x10
#define PAYLOAD_CRC_ERROR     0x20
#define RX_DONE               0x40
#define RX_TIMEOUT            0x80
const uint8_t RFM_SS = 10;
const uint8_t DIO0 = 2;
enum OpMode {SLEEP, LORA, STANDBY, TX, RXSINGLE, RXCONTINUOUS};
enum SpreadingFactor {SF7, SF8, SF9, SF10, SF11, SF12};
enum Channel {CH1, CH2, CH3, CH4, CH5, CH6, CH7, CH8, CH9};
enum Bandwidth {KHZ_7_8,KHZ_10_4,KHZ_62_5,KHZ_125, KHZ_250, KHZ_500};
enum CodingRate {CR4_5, CR4_6, CR4_7, CR4_8};
enum HeaderMode {EXPLICIT, IMPLICIT};
uint8_t dataTx[3];
uint8_t dataLenTx = 3;
// PayloadCrcError
bool CRC = true;
// set Low Data Rate Optimization true
bool LDR = true;
// set one Bandwidth (KHZ_7_8,KHZ_10_4,KHZ_62_5,KHZ_125, KHZ_250, KHZ_500)
Bandwidth bw = KHZ_7_8;
// set coding rate (CR4_5, CR4_6, CR4_7, CR4_8)
CodingRate cr = CR4_5;
// set header mode (EXPLICIT, IMPLICIT)
HeaderMode hm = EXPLICIT;
// set spreading factor (SF7, SF8, SF9, SF10, SF11, SF12)
SpreadingFactor sf = SF12;
// preamble length in symbols
uint16_t preamble = 8;
void setup() {
  SPI.begin();
  pinMode(RFM_SS, OUTPUT);
  digitalWrite(RFM_SS, HIGH);
  initRFM();
  initModemConfig(bw, cr, hm, sf, CRC, LDR);
  setPreamble(preamble);
void loop() {
  dataTx[0] = 0x00;
  dataTx[1] = 0xFF;
  dataTx[2] = 0x00;
  sendData(dataTx, dataLenTx);
  delay(30000);
* initialize the RFM module
void initRFM(void) {
	//set RFM to sleep
	setOpMode(SLEEP);
  	//Set RFM in LoRa mode
	setOpMode(LORA);
  	//Set RFM in Standby mode wait on mode ready
	setOpMode(STANDBY);
  delay(10);
	//Set carrier frequency
	setChannel(CH1);
	//PA pin (maximal power)
  writeReg(RegPaConfig, 0xFF);
	//Switch LNA boost on High Frequency (RFI_HF) LNA current adjustment Boost on, 150% LNA 		current, LNA gain setting:G1 = maximum gain
  writeReg(RegLna,0x23);
  //Set LoRa sync word
  writeReg(RegSyncWord, 0x34);
  //Set IQ to normal values
	writeReg(RegInvertIQ, 0x27);
* Description : initialize the modem configuration
* Argument 1 : Bandwidth (KHZ_7_8,KHZ_10_4,KHZ_62_5,KHZ_125, KHZ_250, KHZ_500)
* Argument 2 : CodingRate (CR4_5, CR4_6, CR4_7, CR4_8)
* Argument 3 : HeaderMode (EXPLICIT, IMPLICIT)
* Argument 4 : SpreadingFactor (SF7, SF8, SF9, SF10, SF11, SF12)
* Argument 5 : bool payload CRC error check ON or OFF
* Argument 6 : bool low data rate optimize ON or OFF
void initModemConfig(Bandwidth bw, CodingRate cr, HeaderMode hm, SpreadingFactor sf, bool CRC, bool LDR) {
	//set modem configuration
	setConfig1(bw, cr, hm); // 7,8 kHz 4/5 coding rate explicit header mode
	setConfig2(sf, CRC);    // SF12 CRC ON
	setConfig3(LDR);        // LowDataRateOptimize ON, AGC auto ON
* Description : set the preamble value
* Argument 1  : uint16_t the value of the preamble (+4)
void setPreamble(uint16_t value) {
  uint8_t msb = value >> 8;
  uint8_t lsb = value;
	writeReg(RegPreambleMsb, msb);
	writeReg(RegPreambleLsb, lsb);
* Description : switch to receive
void initRx(void) {
  //Change DIO 0 to RxDone
  writeReg(RegDioMapping1, RXDONE);
  //Switch to continuous receive
  setOpMode(RXCONTINUOUS);
* Description : Function for sending a package with the RFM
* Argument 1  : array pointer to data that will be send
* Argument 2  : data lenght
void sendData(uint8_t *data, uint8_t len) {
  //Switch DIO0 to TxDone
  writeReg(RegDioMapping1, TXDONE);
  // initialize the payload size and address pointers
  writeReg(RegFifoTxBaseAddr, 0x00);
  writeReg(RegFifoAddrPtr, 0x00);
  //Set payload length to the right length
  writeReg(RegPayloadLength, len);
  //Write Payload to FiFo
  writeBuffer(RegFifo, data, len);
  //Switch RFM to Tx
  setOpMode(TX);
* Description: clear the IRQ flags
void clearIRQ(void) {
  //Clear interrupt register
  writeReg(RegIrqFlags,0xFF);
* Description : write Register
* Argument 1  : address
* Argument 2  : data
void writeReg(uint8_t addr, uint8_t data) {
  digitalWrite(RFM_SS, LOW);
  //Send Addres with MSB 1 to make it a write command
  SPI.transfer(addr | 0x80);
  SPI.transfer(data);
* Description : read Register
* Argument    : address
* Return      : data
uint8_t readReg(uint8_t addr) {
  uint8_t data;
  //Send Addres with MSB 0 to make it a read command
  SPI.transfer(addr & 0x7F);
  // Send 0x00 to be able to receive the answer from the RFM
  data = SPI.transfer(0x00);
  return data;
* Description: write to FIFO buffer
void writeBuffer(uint8_t addr, uint8_t buf[], uint8_t len) {
  SPI.transfer(buf, len);
* Description: read from FIFO buffer
void readBuffer(uint8_t addr, uint8_t buf[], uint8_t len) {
  for (uint8_t i = 0; i < len; i++) {
    buf[i] = SPI.transfer(0x00); // Send 0x00 to be able to receive the answer from the RFM
* Description : set opMode
* Arguments   : Enum OpMode SLEEP, LORA, STANDBY, TX, RXSINGLE, RXCONTINUOUS
void setOpMode(OpMode mode) {
	switch(mode) {
		case SLEEP:
			writeReg(RegOpMode, MODE_SLEEP);
			break;
		case LORA:
			writeReg(RegOpMode, MODE_LORA);
			break;
		case STANDBY:
			writeReg(RegOpMode, (MODE_LORA | MODE_STANDBY) );
			break;
		case TX:
			writeReg(RegOpMode, (MODE_LORA | MODE_TX) );
			break;
		case RXSINGLE:
			writeReg(RegOpMode, (MODE_LORA | MODE_RXSINGLE) );
			break;
		case RXCONTINUOUS:
			writeReg(RegOpMode, (MODE_LORA | MODE_RXCONTINUOUS) );
			break;
* Description : set coding rate and header @ Bandwidth 125 kHz
* Argument1   : Enum Bandwidth KHZ_125, KHZ_250,
* Argument2   : Enum CodingRate CR4_5, CR4_6, CR4_7, CR4_8
* Argument3   : Enum HeaderMode EXPLICIT, IMPLICIT
void setConfig1(Bandwidth bw, CodingRate cr, HeaderMode headerMode) {
		if (bw == KHZ_500) {
		switch (cr) {
			case CR4_5:
				if (headerMode == EXPLICIT) {
					writeReg(RegModemConfig1, 0x92); //500 kHz 4/5 coding rate explicit header mode
				} else {
					writeReg(RegModemConfig1, 0x93); //500 kHz 4/5 coding rate implicit header mode
				break;
			case CR4_6:
					writeReg(RegModemConfig1, 0x94); //500 kHz 4/6 coding rate explicit header mode
				} else {
					writeReg(RegModemConfig1, 0x95); //500 kHz 4/6 coding rate implicit header mode
				break;
			case CR4_7:
					writeReg(RegModemConfig1, 0x96); //500 kHz 4/7 coding rate explicit header mode
				} else {
					writeReg(RegModemConfig1, 0x97); //500 kHz 4/7 coding rate implicit header mode
				break;
			case CR4_8:
					writeReg(RegModemConfig1, 0x98); //500 kHz 4/8 coding rate explicit header mode
				} else {
					writeReg(RegModemConfig1, 0x99); //500 kHz 4/8 coding rate implicit header mode
				break;
	} else if (bw == KHZ_250) {
		switch (cr) {
			case CR4_5:
					writeReg(RegModemConfig1, 0x82); //250 kHz 4/5 coding rate explicit header mode
				} else {
					writeReg(RegModemConfig1, 0x83); //250 kHz 4/5 coding rate implicit header mode
				break;
			case CR4_6:
					writeReg(RegModemConfig1, 0x84); //250 kHz 4/6 coding rate explicit header mode
				} else {
					writeReg(RegModemConfig1, 0x85); //250 kHz 4/6 coding rate implicit header mode
				break;
			case CR4_7:
					writeReg(RegModemConfig1, 0x86); //250 kHz 4/7 coding rate explicit header mode
				} else {
					writeReg(RegModemConfig1, 0x87); //250 kHz 4/7 coding rate implicit header mode
				break;
			case CR4_8:
					writeReg(RegModemConfig1, 0x88); //250 kHz 4/8 coding rate explicit header mode
				} else {
					writeReg(RegModemConfig1, 0x89); //250 kHz 4/8 coding rate implicit header mode
				break;
	} else if (bw == KHZ_125) {
		switch (cr) {
			case CR4_5:
					writeReg(RegModemConfig1, 0x72); //125 kHz 4/5 coding rate explicit header mode
				} else {
					writeReg(RegModemConfig1, 0x73); //125 kHz 4/5 coding rate implicit header mode
				break;
			case CR4_6:
					writeReg(RegModemConfig1, 0x74); //125 kHz 4/6 coding rate explicit header mode
				} else {
					writeReg(RegModemConfig1, 0x75); //125 kHz 4/6 coding rate implicit header mode
				break;
			case CR4_7:
					writeReg(RegModemConfig1, 0x76); //125 kHz 4/7 coding rate explicit header mode
				} else {
					writeReg(RegModemConfig1, 0x77); //125 kHz 4/7 coding rate implicit header mode
				break;
			case CR4_8:
					writeReg(RegModemConfig1, 0x78); //125 kHz 4/8 coding rate explicit header mode
				} else {
					writeReg(RegModemConfig1, 0x79); //125 kHz 4/8 coding rate implicit header mode
				break;
	} else if (bw == KHZ_62_5) {
			switch (cr) {
				case CR4_5:
						writeReg(RegModemConfig1, 0x62); //62.5 kHz 4/5 coding rate explicit header mode
					} else {
						writeReg(RegModemConfig1, 0x63); //62.5 kHz 4/5 coding rate implicit header mode
					break;
				case CR4_6:
						writeReg(RegModemConfig1, 0x64); //62.5 kHz 4/6 coding rate explicit header mode
					} else {
						writeReg(RegModemConfig1, 0x65); //62.5 kHz 4/6 coding rate implicit header mode
					break;
				case CR4_7:
						writeReg(RegModemConfig1, 0x66); //62.5 kHz 4/7 coding rate explicit header mode
					} else {
						writeReg(RegModemConfig1, 0x67); //62.5 kHz 4/7 coding rate implicit header mode
					break;
				case CR4_8:
						writeReg(RegModemConfig1, 0x68); //62.5 kHz 4/8 coding rate explicit header mode
					} else {
						writeReg(RegModemConfig1, 0x69); //62.5 kHz 4/8 coding rate implicit header mode
					break;
	} else if (bw == KHZ_10_4) {
			switch (cr) {
				case CR4_5:
						writeReg(RegModemConfig1, 0x12); //10.4 kHz 4/5 coding rate explicit header mode
					} else {
						writeReg(RegModemConfig1, 0x13); //10.4 kHz 4/5 coding rate implicit header mode
					break;
				case CR4_6:
						writeReg(RegModemConfig1, 0x14); //10.4 kHz 4/6 coding rate explicit header mode
					} else {
						writeReg(RegModemConfig1, 0x15); //10.4 kHz 4/6 coding rate implicit header mode
					break;
				case CR4_7:
						writeReg(RegModemConfig1, 0x16); //10.4 kHz 4/7 coding rate explicit header mode
					} else {
						writeReg(RegModemConfig1, 0x17); //10.4 kHz 4/7 coding rate implicit header mode
					break;
				case CR4_8:
						writeReg(RegModemConfig1, 0x18); //10.4 kHz 4/8 coding rate explicit header mode
					} else {
						writeReg(RegModemConfig1, 0x19); //10.4 kHz 4/8 coding rate implicit header mode
					break;
	} else if (bw == KHZ_7_8) {
			switch (cr) {
				case CR4_5:
						writeReg(RegModemConfig1, 0x02); //7.8 kHz 4/5 coding rate explicit header mode
					} else {
						writeReg(RegModemConfig1, 0x03); //7.8 kHz 4/5 coding rate implicit header mode
					break;
				case CR4_6:
						writeReg(RegModemConfig1, 0x04); //7.8 kHz 4/6 coding rate explicit header mode
					} else {
						writeReg(RegModemConfig1, 0x05); //7.8 kHz 4/6 coding rate implicit header mode
					break;
				case CR4_7:
						writeReg(RegModemConfig1, 0x06); //7.8 kHz 4/7 coding rate explicit header mode
					} else {
						writeReg(RegModemConfig1, 0x07); //7.8 kHz 4/7 coding rate implicit header mode
					break;
				case CR4_8:
						writeReg(RegModemConfig1, 0x08); //7.8 kHz 4/8 coding rate explicit header mode
					} else {
						writeReg(RegModemConfig1, 0x09); //7.8 kHz 4/8 coding rate implicit header mode
					break;
* Description : set Spreading Factor and CRC Information extracted from the received packet header
* Argument 1  : enum SpreadingFactor SF7, SF8, SF9, SF10, SF11, SF12
* Argument 2  : bool CRC ON or OFF
void setConfig2(SpreadingFactor sf, bool CRC) {
	switch(sf) {
		case SF7:
			if (CRC) {
				writeReg(RegModemConfig2,0x74); //SF7 CRC On
			} else {
				writeReg(RegModemConfig2,0x70); //SF7 CRC OFF
			break;
		case SF8:
			if (CRC) {
				writeReg(RegModemConfig2,0x84); //SF8 CRC On
			} else {
				writeReg(RegModemConfig2,0x80); //SF8 CRC OFF
			break;
		case SF9:
			if (CRC) {
				writeReg(RegModemConfig2,0x94); //SF9 CRC On
			} else {
				writeReg(RegModemConfig2,0x90); //SF9 CRC OFF
			break;
		case SF10:
			if (CRC) {
				writeReg(RegModemConfig2,0xA4); //SF10 CRC On
			} else {
				writeReg(RegModemConfig2,0xA0); //SF10 CRC OFF
			break;
		case SF11:
			if (CRC) {
				writeReg(RegModemConfig2,0xB4); //SF11 CRC On
			} else {
				writeReg(RegModemConfig2,0xB0); //SF11 CRC OFF
			break;
		case SF12:
			if (CRC) {
				writeReg(RegModemConfig2,0xC4); //SF12 CRC On
			} else {
				writeReg(RegModemConfig2,0xC0); //SF12 CRC On
			break;
* Description : LNA gain set by the internal AGC loop AgcAutoOn and LowDataRateOptimize ON / OFF
* Arguments   : bool Low DataRate Optimize ON / OFF
void setConfig3(bool LDR) {
	if (LDR) {
		writeReg(RegModemConfig3,0x0C); //LowDataRateOptimize ON, AGC auto ON
	} else {
		writeReg(RegModemConfig3,0x04); //Low datarate optimization OFF, AGC auto ON
* Description : set Channel
* Arguments   : Enum chan CH1, CH2, CH3, CH4, CH5, CH6, CH7, CH8, CH9
void setChannel(Channel chan) {
	switch (chan) {
		case CH1:
			//Channel 1 868.100 MHz / 61.035 Hz = 14222987 = 0xD9068B
			writeReg(RegFrfMsb,0xD9);
			writeReg(RegFrfMid,0x06);
			writeReg(RegFrfLsb,0x8B);
			break;
		case CH2:
			//Channel 2 868.300 MHz / 61.035 Hz = 14226264 = 0xD91358
			writeReg(RegFrfMid,0x13);
			writeReg(RegFrfLsb,0x58);
			break;
		case CH3:
			//Channel 3 868.500 MHz / 61.035 Hz = 14229540 = 0xD92024
			writeReg(RegFrfMid,0x20);
		  writeReg(RegFrfLsb,0x24);
			break;
		case CH4:
			//Channel 4 867.100 MHz / 61.035 Hz = 14206603 = 0xD8C68B
			writeReg(RegFrfMsb,0xD8);
			writeReg(RegFrfMid,0xC6);
			break;
		case CH5:
			//Channel 5 867.300 MHz / 61.035 Hz = 14209880 = 0xD8D358
			writeReg(RegFrfMid,0xD3);
			break;
		case CH6:
			//Channel 6 867.500 MHz / 61.035 Hz = 14213156 = 0xD8E024
			writeReg(RegFrfMid,0xE0);
			break;
		case CH7:
			//Channel 7 867.700 MHz / 61.035 Hz = 14216433 = 0xD8ECF1
			writeReg(RegFrfMid,0xEC);
			writeReg(RegFrfLsb,0xF1);
			break;
		case CH8:
			//Channel 8 867.900 MHz / 61.035 Hz = 14219710 = 0xD8F9BE
			writeReg(RegFrfMid,0xF9);
			writeReg(RegFrfLsb,0xBE);
			break;
		case CH9:
			//Channel 9 869.525 MHz / 61.035 Hz = 14246334 = 0xD961BE
			writeReg(RegFrfMid,0x61);
			break;
#722
Thank you! :+1:
This gives results that look and sound more like in the video.
I tried with a standard uplink message using SF12 with LMIC but that did not come close.
(Jprttn) #723
I have tested cheap VL53L0X module in a 1 m pipe (11 cm diameter) with good results.
Works quite reliably with lights turned on or in darkness.
#724
just received a mailing about the VL53L1X
#725
How about: https://www.tindie.com/products/onehorse/vl53l1-long-range-proximity-sensor/?pt=ac_prod_search
#726
I would expect condensed water vapor in the tank to be an issue / obstructing the laser beam.
Reliably measuring the level in a water tank reminds me of the following video. The idea is simple but practical issues make it much more complicated.
