Hi All, I m trying to install TTN stack and managed to load the console screen using the files described below but every-time the TTN Console is not working properly. It is always showing “Forbidden” - [Token exchange refused].
The docker-compose.yml
version: '3.7'
services:
# If using CockroachDB:
cockroach:
image: cockroachdb/cockroach:latest
command: start --http-port 26256 --insecure
restart: unless-stopped
volumes:
- ./data/cockroach:/cockroach/cockroach-data
ports:
- "159.65.159.245:26257:26257" # Cockroach
- "159.65.159.245:26256:26256" # WebUI
redis:
image: redis:latest
command: redis-server --appendonly yes
volumes:
- ./data/redis:/data
ports:
- "159.65.159.245:6379:6379"
stack:
image: thethingsnetwork/lorawan-stack:latest
entrypoint: ttn-lw-stack -c /config/ttn-lw-stack.yml
command: start
depends_on:
- redis
- cockroach
# If using PostgreSQL:
# - postgres
volumes:
- ./blob:/srv/ttn-lorawan/public/blob
- ./config/stack:/config:ro
# If using Let's Encrypt:
- ./acme:/var/lib/acme
environment:
TTN_LW_BLOB_LOCAL_DIRECTORY: /srv/ttn-lorawan/public/blob
TTN_LW_REDIS_ADDRESS: redis:6379
TTN_LW_IS_DATABASE_URI:
postgres://root@cockroach:26257/ttn_lorawan?sslmode=disable
ports:
# If deploying on a public server:
# - "80:1885"
# - "443:8885"
- "1881:1881"
- "8881:8881"
- "1882:1882"
- "8882:8882"
- "1883:1883"
- "8883:8883"
- "1884:1884"
- "8884:8884"
- "1885:1885"
- "8885:8885"
- "1887:1887"
- "8887:8887"
- "1700:1700/udp"
The ttn-lw-stack.ymlb
is:
# Email configuration for "thethings.example.com"
email:
sender-name: 'The Things Stack'
sender-address: 'noreply@thethings.example.com'
network:
console-url: 'https://localhost/console'
identity-server-url: 'https://localhost/oauth'
# Web UI configuration for "thethings.example.com":
oauth:
ui:
canonical-url: 'https://localhost/oauth'
is:
base-url: 'https://localhost/api/v3'
# HTTP server configuration
http:
cookie:
# generate 32 bytes (openssl rand -hex 32)
block-key: '0011223344556677001122334455667700112233445566770011223344556677'
# generate 64 bytes (openssl rand -hex 64)
hash-key: '00112233445566770011223344556677001122334455667700112233445566770011223344556677001122334455667700112233445566770011223344556677'
metrics:
password: 'metrics' # choose a password
pprof:
password: 'pprof' # choose a password
# If using (self) signed certificates:
# tls:
# source: file
# root-ca: /run/secrets/cert.pem
# certificate: /run/secrets/cert.pem
# key: /run/secrets/key.pem
# If using Let's encrypt for "thethings.example.com"
tls:
source: 'acme'
acme:
dir: '~/df/acme'
email: 'you@localhost'
hosts: ['https://localhost']
default-host: 'https://localhost'
# If Gateway Server enabled, defaults for "thethings.example.com":
gs:
mqtt:
public-address: 'https://localhost:1882'
public-tls-address: 'https://localhost:8882'
mqtt-v2:
public-address: 'https://localhost:1881'
public-tls-address: 'https://localhost:8881'
# If Gateway Configuration Server enabled, defaults for "thethings.example.com":
gcs:
basic-station:
default:
lns-uri: 'wss://localhost:8887'
the-things-gateway:
default:
mqtt-server: 'mqtts://localhost:8881'
console:
ui:
canonical-url: 'https://localhost/console'
is:
gs:
ns:
as:
js:
qrg:
edtc:
oauth:
authorize-url: 'https://localhost/oauth/authorize'
logout-url: 'https://localhost/oauth/logout'
token-url: 'https://localhost/oauth/token'
client-id: 'console'
client-secret: 'xxx'
What can I do ?
