# Token Exchange refused Error
**URL:** <https://www.thethingsnetwork.org/forum/t/token-exchange-refused-error/41643>\
**Category:** Uncategorized\
**Created:** [November 25, 2020, 4:30pm UTC](https://www.thethingsnetwork.org/forum/t/token-exchange-refused-error/41643 "2020-11-25T16:30:07Z")\
**Showing post:** 14
**Author:** ![dsmith](https://www.thethingsnetwork.org/forum/user_avatar/www.thethingsnetwork.org/dsmith/32/25844_2.png) [@dsmith](https://www.thethingsnetwork.org/forum/u/dsmith)\
**Post date:** [November 27, 2020, 6:39am UTC](https://www.thethingsnetwork.org/forum/t/token-exchange-refused-error/41643/14 "2020-11-27T06:39:58Z")
Hey @Tigere, I’ve just managed to get https with a custom certificate working on my open source TTS server, and it looks like you want to use HTTPS, so I’ll post instructions here.
First, download `docker-compose.yml` and `ttn-lw-stack-docker.yml` and configure them as normal. In my case, this meant replacing `thethings.example.com` with the static ip address of the machine hosting my docker containers. Then, uncomment the sections about using custom certificates.
At the bottom of `docker-compose.yml`:
 ![image](https://www.thethingsnetwork.org/forum/uploads/default/original/3X/f/d/fdee35c8e4774ec7f9a64e30690d42fe7643b131.png)
Near the top of `ttn-lw-stack-docker.yml` (don’t forget to comment out the let’s encrypt section):
 ![image](https://www.thethingsnetwork.org/forum/uploads/default/original/3X/3/7/3756d49aeb883efa1eb2a702bc6018a3a5de554e.png)
Next, install cfssl and cfssljson:
go get -u [github.com/cloudflare/cfssl/cmd/cfssl](http://github.com/cloudflare/cfssl/cmd/cfssl)
go get -u [github.com/cloudflare/cfssl/cmd/cfssljson](http://github.com/cloudflare/cfssl/cmd/cfssljson)
You can run the installed binaries from `~/go/bin` or add them to your `PATH`.
You are now ready to follow the [instructions](https://thethingsstack.io/getting-started/installation/certificates/) for using a custom certificate. I created `ca.json` exactly as shown. For `cert.json`, I replaced `thethings.example.com` with the static ip address of the host (as I had done in `docker-compose.yml` and `ttn-lw-stack-docker.yml`). After creating the two json files, I ran the commands to generate the certificates and put the relevant files into my project:
cfssl genkey -initca ca.json | cfssljson -bare ca
cfssl gencert -ca ca.pem -ca-key ca-key.pem cert.json | cfssljson -bare cert
mv cert-key.pem tts/key.pem
mv cert.pem tts/cert.pem
mv ca.pem tts/ca.pem
Like the instructions say, your project directory (`tts` in my case) should look like this:
├── blob
├── ca.pem
├── cert.pem
├── config
│ └── stack
│ └── ttn-lw-stack-docker.yml
├── docker-compose.yml
└── key.pem
Finally, add `ca.pem` to the certificate store(s) on any machines that will be interacting with your TTS installation.
sudo cp ca.pem /usr/local/share/ca-certificates/ca.crt
sudo update-ca-certificates
You can discard the other files created during the certificate signing process - you no longer need them (`ca-key.pem, ca.csr, ca.json, cert.csr, cert.json`).
Now, [run the things stack](https://thethingsstack.io/getting-started/installation/running-the-stack/) as normal and you should be good to go.
_[View the full topic](https://www.thethingsnetwork.org/forum/t/token-exchange-refused-error/41643)._
