Ttgo T-beam
(Verkehrsrot) #85
but sure that the newer versions does not have these or other flaws in RF design?
(DarkMan) #86
nice. tnx.
(Rem73) #87
“buying a new one is probably cheaper…” : No!! You don"t undestand.
I’m pratically sure that the mistake is not on MY board but on ALL TTGO V1 at 868Mhz:
There is a mystake in the layout: use of PAboost with wrong parts. Or it is only a BOM mistake
Understanding PA SX1276 is not obvious: many frequencies and BOM changes, many power configuration, 2 différents layout available, use or not EMI filter…not so easy as connecting an Oled Display.
Any way , if you are not able to do the measurement with specific hardware, you can not see the difference. 10dB Could be over-pass by good or bad cable and antenna. You will see it only for test at the limit range, with same antenna…
#88
ok, therefore you can’t say that changing a few components will help if there is a fundamental design error.
(Rem73) #89
To be clear : If you change theses components ( not easy ) and modify LMIC lib, you can improve de transmitted power, to be close to the semtech specification and RFM95
(Ud Lo Ra) #90
There is a video by Andreas Spiess about the ESP32 issues due to bad RF design . However, I agree that is likely better to buy an ESP32 alone + RFM95w instead.
#91
tnx… Andreas was spotted at The Conference yesterday ! :sunglasses:
(Ori) #92
I wonder what is this UFL connector for, does anyone know?UFL
(Eric VdB) #93
Wifi ?
#94
It is meant for connecting an external Wifi/BT antenna but that would require moving (de/re-soldering) a 0 ohm resistor (on the left of the U.FL connector) from one location to another to switch the RF connection.
(Ori) #95
Not good for the Lora antenna then…
#96
That is unrelated to the LoRa antenna (or at least as much related as the on-board Wifi/BT antenna).
(Ori) #97
Any luck/update with regards to the GPS and sleep mode?
(Bercman) #100
Hello!
I’m new to the LoRaWAN and TTN community.
I’ve been trying to get my TTGO T-Beam to work (connect to TTN) for several days now, but have had no success whatsoever.
What I’ve tried so far:
  • Downloaded LMIC library and tried out the following pinout settings according to the best TTGO T-Beam pinout information I’ve found so far (incl. soldering LoRa1 to pin 33 and LoRa2 to pin 32 on the board itself):
.nss = 18, // LoRa chip select on ttgo t-beam
.rxtx = LMIC_UNUSED_PIN,
.rst = LMIC_UNUSED_PIN, // Not required
.dio = {26, 33, 32}, // To LoRa DIO0 (interrupt), To LoRa DIO1 (interrupt) & To LoRa DIO2 (interrupt)
  • Updated SPI settings in hal.cpp according to the correct SPI pinout:
static void hal_spi_init () {
// SPI.begin();
SPI.begin(5,19,27); // These specific pins are for TTGO T-Beam only!
  • Tested LMIC AGP example, paying very close attention to little- and big-endian formats. This is what I see (no joining feedback, the last lines just repeat after every 60 seconds as defined):
    Baud rate 115200
ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x33 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:928
ho 0 tail 12 room 4
load:0x40078000,len:9280
load:0x40080400,len:5848
entry 0x40080698
Starting
11124: EV_TXSTART
Packet queued
206222: EV_TXCOMPLETE (includes waiting for RX windows)
  • Tested LMIC OTAA example, paying very close attention to little- and big-endian formats. This is what I see:
    Baud rate 9600 (the last lines just repeat)
⸮as⸮⸮J&&⸮SY
Packet queued
4918: EV_JOINING
4937: EV_TXSTART
414734: EV_TXSTART
843576: EV_TXSTART
1302692: EV_TXSTART
2665242: EV_TXSTART
  • OTAA example. Baud rate 115200
ho 0 tail 12 room 4
entry 0x40080698
  • Peeled off the LoRa module sticker to make sure I do not have the 433 MHz LoRa module as I did have with other LoRa modules I failed with as I live in Europe. Although it is not the 433 MHz module, I found HPD13A-915 written on top of the module. Knowing that the TTGO T-Beam advertises itself to be compatible with 868 MHz and 915 MHz at the same time (?!), might this prove to be a problem? I do have to admit I’m too novice in this to make sure, so any feedback on this would be fantastic.
Going through numerous topics on TTGO T-Beam and different examples, the board itself works and I’ve managed to upload code onto it, but I cannot seem to connect with the TTN. Any help or extra questions to give input to would be greatly appreciated!
PS. I am using The Things Gateway for testing.
Thanks!
-Tarvo.
#101
see
(Verkehrsrot) #102
If you have the older TTGO T-Beam Version you need to wire Lora Pin DIO1 to CPU.
You can also check paxcounter software which comes with tailored settings for TTGO T-Beam, perhaps it works on your’s. If yes, you know that you did something wrong.
(Bercman) #103
Thanks for the tip. Could You please elaborate to where I would have to wire the LoRa DIO1 in case I need to?
I’ve had a look at the Paxcounter before, but haven’t really tried uploading it to the T-Beam that as it seemed a bit too complex code to begin my exploration with, but I will try it out. Hopefully it reveal something. :slight_smile:
EDIT: Paxcounter works fine, I was able to connect to TTN and forward data. So what mightbe up with the previous codes? :confused:
(Deux Vis) #104
Well first make sure you have a version which needs the wiring.
Can you find any version marking on the board ? Please copy it here.
Later : I just saw your edit. You definitely do not need more wiring if paxcounter works.
(Verkehrsrot) #105
Double-check your pinout and your keys.
Pinout of TTGO-Tbeam can be found here:
(Shadowkane) #106
i’m not sure if this is the right place to post my question about TTGO T beam. It’s my first ESP board and my very first project with ESP and lora. my question is simple, can i use my board without battery, just power it on using only USB (connected to PC). I already tried that because i though it’s fine, like almost every single board in the market has an USB port for power and programming, but the moment i turn the switch on i heard some noise.i’m not sure if the noise is from Lora component or not but i think it is, so i just turned off.
