Hi All,
someone can tell me what happen if I try to connect a class B device to TTN? It behave like a class A device (since TTN currently support only class A) or its join is refused or what?
Thank you
Hi All,
Thank you
I didn’t even know of any devices that support class B. What are you using?
Look at this:
Alex
did you noticed this : Radio Frequency Band AS923 - Asia 915-928MHz
No but I would be interested in having an answer if someone has it.
Alex
OK I’m not a specialist but I think it probably won’t work at all.
The class B device will try to aquire a beacon lock (which a class A network don’t have)
Once in the state of a beacon lock, the device negotioates its ping-interval with the backend.
Also you need GPS time based gateways.
Does Lopy4 supports class B connection?
Thank you,
Francisco Oliveira, University of Aveiro
Check the release notes of the firmware you are using… and don’t revive 3 year old discussions.
