# TTN meets RIVM. or: how to-make your own lora air quality sensor
**URL:** <https://www.thethingsnetwork.org/forum/t/ttn-meets-rivm-or-how-to-make-your-own-lora-air-quality-sensor/5162>\
**Created:** [February 1, 2017, 7:08pm UTC](https://www.thethingsnetwork.org/forum/t/ttn-meets-rivm-or-how-to-make-your-own-lora-air-quality-sensor/5162 "2017-02-01T19:08:36Z")\
**Showing post:** 2
**Author:** ![TijnOnlijn](https://www.thethingsnetwork.org/forum/user_avatar/www.thethingsnetwork.org/tijnonlijn/32/27494_2.png) [@TijnOnlijn](https://www.thethingsnetwork.org/forum/u/TijnOnlijn)\
**Post date:** [February 1, 2017, 7:13pm UTC](https://www.thethingsnetwork.org/forum/t/ttn-meets-rivm-or-how-to-make-your-own-lora-air-quality-sensor/5162/2 "2017-02-01T19:13:08Z")
**Shopping List**
The core components are an arduino/lmic node. This could be the [Cheapest Possible Node](https://www.thethingsnetwork.org/labs/story/build-the-cheapest-possible-node-yourself). Alternatively ready made PCB’s like [Doug LaRue’s PCB](http://dirtypcbs.com/store/designer/details/13122/1115/promini-node-v1-0-50x50-zip) or LoRaUK’s PCB are also suitable. Alternatively RN2483 based nodes could also be used but that’s out of scope for this story.
![](https://www.thethingsnetwork.org/forum/uploads/default/original/2X/d/dd1114c0d5c66a9e519c8768c678967f1dcd1cc1.jpg)
Then you’ll need a Shinyei PPD42NS sensor like used in the DustDuino. Note that because of the need to continuously measure as well as the presence of a heating element this is not suitable for battery operation.
![](https://www.thethingsnetwork.org/forum/uploads/default/original/2X/a/acdfe41bdf167f34a4c4d21c4cc23beb3d75e57f.jpg)
_Some links to shops._
**NL**
Sensor casing [https://www.weerstationkopen.nl/nieuwe-producten/98111402-tfa-sensorhut](https://www.weerstationkopen.nl/nieuwe-producten/98111402-tfa-sensorhut)
RFM95 [http://webshop.ideetron.nl/RFM95W](http://webshop.ideetron.nl/RFM95W) excl btw
Pro Mini: [http://www.tinytronics.nl/shop/Pro-Mini-3.3V-8Mhz?search=pro%20mini](http://www.tinytronics.nl/shop/Pro-Mini-3.3V-8Mhz?search=pro%20mini)
FTDI: [http://www.tinytronics.nl/shop/index.php?route=product/product/&product\_id=277](http://www.tinytronics.nl/shop/index.php?route=product/product/&product_id=277)
Capacitor, level shifter, power supply: Conrad?
PPD42NS: [https://www.kiwi-electronics.nl/grove-dust-sensor](https://www.kiwi-electronics.nl/grove-dust-sensor)
**China**
Sensor casing: [https://nl.aliexpress.com/item/plastic-outer-shield-for-thermo-hygro-sensor-spare-part-for-weather-station-Transmitter-thermo-hygro-sensor/32498845208.html?scm=1007.13339.33317.0&pvid=ab1cc3b5-7ca6-4f76-8c86-9808633a036b&tpp=1](https://nl.aliexpress.com/item/plastic-outer-shield-for-thermo-hygro-sensor-spare-part-for-weather-station-Transmitter-thermo-hygro-sensor/32498845208.html?scm=1007.13339.33317.0&pvid=ab1cc3b5-7ca6-4f76-8c86-9808633a036b&tpp=1)
RFM95: [http://www.ebay.com/itm/231784606792?var=531046227200](http://www.ebay.com/itm/231784606792?var=531046227200)
Arduino Pro Mini: [http://www.ebay.com/itm/172421681472?var=471254472226](http://www.ebay.com/itm/172421681472?var=471254472226)
FTDI: [http://www.ebay.com/itm/272429652176?var=571417073476](http://www.ebay.com/itm/272429652176?var=571417073476)
PPD42NS dust sensor: [http://www.ebay.com/itm/Original-PPD42NJ-PPD42NS-Dust-Sensor-SHINYEI-Air-Quality-Monitor-Purifier-/162237452408?hash=item25c61b1078:g:8IUAAOSwOyJX5PqY](http://www.ebay.com/itm/Original-PPD42NJ-PPD42NS-Dust-Sensor-SHINYEI-Air-Quality-Monitor-Purifier-/162237452408?hash=item25c61b1078:g:8IUAAOSwOyJX5PqY)
5v power supply: [http://www.ebay.com/itm/HLK-PM01-AC-DC-220V-to-5V-Step-Down-Power-Supply-Module-Household-Switch-D-/112041806450?hash=item1a16364a72:g:Xt8AAOSwvg9XcxFr](http://www.ebay.com/itm/HLK-PM01-AC-DC-220V-to-5V-Step-Down-Power-Supply-Module-Household-Switch-D-/112041806450?hash=item1a16364a72:g:Xt8AAOSwvg9XcxFr)
Capacitor: [http://www.ebay.com/itm/231913059895](http://www.ebay.com/itm/231913059895)
Level shifter: [http://www.ebay.com/itm/141728904474](http://www.ebay.com/itm/141728904474)
_[View the full topic](https://www.thethingsnetwork.org/forum/t/ttn-meets-rivm-or-how-to-make-your-own-lora-air-quality-sensor/5162)._
