# TTN V2 to V3 migration
**URL:** <https://www.thethingsnetwork.org/forum/t/ttn-v2-to-v3-migration/43445>\
**Category:** Migrating Gateways to V3\
**Created:** [January 29, 2021, 9:44am UTC](https://www.thethingsnetwork.org/forum/t/ttn-v2-to-v3-migration/43445 "2021-01-29T09:44:20Z")\
**Showing post:** 20
**Post date:** [March 26, 2021, 10:36am UTC](https://www.thethingsnetwork.org/forum/t/ttn-v2-to-v3-migration/43445/20 "2021-03-26T10:36:34Z")
That’s not what the error message says, it says the ID is already taken.
It doesn’t say the DevEUI is taken.
Also:
> [@How do I format my forum post? \[HowTo\]](https://www.thethingsnetwork.org/forum/t/how-do-i-format-my-forum-post-howto/8735):
> The TTN forum is using [Discourse](https://www.discourse.org/), which supports several ways to format your post: Markdown BBCode HTML Any combination of the above Quite often you’ll need an empty line above specific formatting to make it work. You’ll also have to type blank lines to create proper paragraphs; just pressing Return once and then typing a new block of text right below a previous block only creates a so-called line break, which might be harder to read. Leaving one blank line between two blocks of texts nicely…
_[View the full topic](https://www.thethingsnetwork.org/forum/t/ttn-v2-to-v3-migration/43445)._
