Use data from ttn to build an appliquation with google map
hello every one , i m doing my first IOT project .in fact , i need to build an application that get data from ttn (data is coming from gps ) and show this localisation in a map.
i do know how to start ama what i can use to do this mission.
pls help me !!
easiest would be to use CAYENNE … this is allready integrated in TTN
… on the other side, if this project has to be done for school/university, being an easy exercise, at least try to do it by yourself and when you find some issue, ask for help :wink:
Would you be looking for something like our map here?
http://junioriotchallenge.nl/game/
I built this a while ago. Data travels like this:
gps sensor > code on device > sender antenna > TTN gateway > TTN > ttn http integration > AWS Lambda function > frequently updated static file in S3 > webpage with javascript polling the file every 5 seconds
