# What happens if someone does not follow the guidelines?
**URL:** <https://www.thethingsnetwork.org/forum/t/what-happens-if-someone-does-not-follow-the-guidelines/15298>\
**Category:** LoRaWAN Discussions\
**Created:** [June 25, 2018, 4:01pm UTC](https://www.thethingsnetwork.org/forum/t/what-happens-if-someone-does-not-follow-the-guidelines/15298 "2018-06-25T16:01:50Z")\
**Showing post:** 2
**Post date:** [June 25, 2018, 4:27pm UTC](https://www.thethingsnetwork.org/forum/t/what-happens-if-someone-does-not-follow-the-guidelines/15298/2 "2018-06-25T16:27:47Z")
> [@marioz](#):
> What can be done if the neighbor sends every 2 seconds in SF12 on all channels?
As long as you’re not using SF12, you don’t need to worry, as other spreading factors can still be received just fine.
As for your other points: see [LoRaWAN duty cycle abuse](https://www.thethingsnetwork.org/forum/t/lorawan-duty-cycle-abuse/5945).
> [@marioz](#):
> Should a city provide connectivity for parking, garbage and more through TTN, or should it build its own network?
Unless private networks use a different frequency plan, everyone is sharing the same radio spectrum. So adding gateways to a shared network such as TTN is better, as then more nodes will have a gateway close by and can decrease their transmission power.
_[View the full topic](https://www.thethingsnetwork.org/forum/t/what-happens-if-someone-does-not-follow-the-guidelines/15298)._
