# What is the maximum number of characters I can send with LMiC?
**URL:** <https://www.thethingsnetwork.org/forum/t/what-is-the-maximum-number-of-characters-i-can-send-with-lmic/9537>\
**Category:** LMIC\
**Created:** [September 16, 2017, 12:08am UTC](https://www.thethingsnetwork.org/forum/t/what-is-the-maximum-number-of-characters-i-can-send-with-lmic/9537 "2017-09-16T00:08:00Z")\
**Showing post:** 6
**Post date:** [September 16, 2017, 12:27pm UTC](https://www.thethingsnetwork.org/forum/t/what-is-the-maximum-number-of-characters-i-can-send-with-lmic/9537/6 "2017-09-16T12:27:48Z")
> [@pierrot10](#):
> `Serial.println((char *)mydata);`
> it print me an human-raedable value.
In computer memory and when transmitting, everything is just a sequence of bits (and 8 bits are then called a byte). That might be hard to understand at first, but you’ll need to read and re-read “Working with Bytes” (and the links it refers to) until you do understand.
When you think you understand, you should be able to see:
- When (erroneously) using human-readable text, the value 34.51:
  - [is stored as](http://www.binaryhexconverter.com/ascii-text-to-binary-converter) the 48 bits `00110011 00110100 00101110 00110101 00110001 00000000` which includes a trailing NUL-character for a [null-terminated string](https://en.wikipedia.org/wiki/Null-terminated_string),
  - which is the same the decimal [ASCII codes](http://www.rapidtables.com/code/text/ascii-table.htm) 51, 52, 46, 53, 49 and 0,
  - which [is the same as](http://www.binaryhexconverter.com/ascii-text-to-hex-converter) hexadecimal `0x33 34 2E 35 31 00`,
  - and further below you’ll see that using `Serial.println((char *)mydata)` will show “34.51” for the above ASCII codes.
- When (nicely) using an integer number, the value 34.51 can be multiplied by 100 to get 3451, which:
  - [is stored as](http://www.binaryhexconverter.com/decimal-to-binary-converter) the 16 bits `00001101 01111010`,
  - which [is the same as](http://www.binaryhexconverter.com/decimal-to-hex-converter) `0x0D 7B`,
  - and (erroneously) using `Serial.println((char *)mydata)` might then print a new line (for ASCII code `0x0D`) followed by `{` (for `0x7B`), followed by whatever is in memory until it finds the first `0x00` NUL-character, meanwhile printing garbage for all bytes that cannot be converted to ASCII.
Using the `(char *)mydata` above you’re telling the compiler that the program _knows_ that what is currently in the memory buffer `mydata` is in fact human-readable text (and not, for example, some image, or a PDF document, or a simple number). The only reason the program knows, is because it has stored the value there itself (like by using `strcpy` earlier).
So, `(char *)` does not _convert_ anything; it _is_ already human-readable text in memory. And when trying to use a built-in function such as `Serial.println` to show its contents, then your program needs to share that knowledge with the compiler, by prefixing `mydata` with `(char *)`. (Here, `(char)` tells the compiler it’s human-readable text, and `*` gives the compiler a “pointer” to the memory location, which is simply what `Serial.println` expects.) That line would then print garbage if it was in fact not human-readable text. But as it apparently shows the value you expected, you’re still storing human readable text in memory (and so you would also be sending that to TTN).
> [@pierrot10](#):
> I have to review this part of my code (and remove the ’ {}:" ’ which consist of a json format
Just removing the `{...}` does not suffice. JSON is one of the many human-readable formats. Changing `{"x": 123.45, "y": 45.678}` into, e.g., `123.45,45.678` would still be a human-readable format, wasting bytes when sending to TTN.
_[View the full topic](https://www.thethingsnetwork.org/forum/t/what-is-the-maximum-number-of-characters-i-can-send-with-lmic/9537)._
