Adding Gateway ID into AWS IOT Dataset
Did you notice gateways is an array? It can contain multiple elements. I would expect you need to specify at least which from of the elements you want the gtwid.
However I don’t use AWS IoT (yet) so I might be missing the actual problem by a mile.
