Antenna advice
Yes I’m aware you’re communicating with the network server and not the gateway itself, I was just trying to describe my issue.
I found the elevation map data after making my post so yes I agree, that is probably part of the problem.
I’m just after any advice and information I can get. I’ll research the Fresnel Zone, thanks.
There’s not much between the two points, some residential buildings spread out on 10 to 50 acre blocks of land and not too many trees, but there’s certainly some the signal would have to pass though.
I obviously can’t really show the area in depth without giving out my location which I won’t do but from what I’ve read up today I don’t believe there’s anything wrong with the gateway setup, it’s most likely going to be a combination of the land and obstacles.
I think I’ll try get the antenna a bit higher up and keep trying.
