Arduino code to send voltage, current and power to the things network with uplink
Note this won’t run very long on a power bank.
In fact if you get the firmware properly entering a low power sleep mode, a decent powerbank will likely decide nothing is connected and turn its output off.
In terms of initial experiments you are doing fine, but for something to really use, power supply is going to take more engineering.
Yea, thanks its working now
but I want to send downlinks back to the node, how do i modify the code to do this
You have already done it!
Just extend that code to process the received message which is in LMIC.frame.
Because the message is in the frame, LMIC will tell you where your message starts:
LMIC.frame[LMIC.dataBeg]
and LMIC.datalen tells you how long it is, starting at LMIC.dataBeg
Thank you very much,
Can u have a look at this new code and tell me what to do please.
 * Copyright (c) 2015 Thomas Telkamp and Matthijs Kooijman
 * Copyright (c) 2018 Terry Moore, MCCI
 * Permission is hereby granted, free of charge, to anyone
 * obtaining a copy of this document and accompanying files,
 * to do whatever they want with them without any restriction,
 * including, but not limited to, copying, modification and redistribution.
 * NO WARRANTY OF ANY KIND IS PROVIDED.
 * This example sends a valid LoRaWAN packet with payload "Hello,
 * world!", using frequency and encryption settings matching those of
 * the The Things Network.
 * This uses ABP (Activation-by-personalisation), where a DevAddr and
 * Session keys are preconfigured (unlike OTAA, where a DevEUI and
 * application key is configured, while the DevAddr and session keys are
 * assigned/generated in the over-the-air-activation procedure).
 * Note: LoRaWAN per sub-band duty-cycle limitation is enforced (1% in
 * g1, 0.1% in g2), but not the TTN fair usage policy (which is probably
 * violated by this sketch when left running for longer)!
 * To use this sketch, first register your application and device with
 * the things network, to set or generate a DevAddr, NwkSKey and
 * AppSKey. Each device should have their own unique values for these
 * fields.
 * Do not forget to define the radio type correctly in
 * arduino-lmic/project_config/lmic_project_config.h or from your BOARDS.txt.
 // References:
 // [feather] adafruit-feather-m0-radio-with-lora-module.pdf
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
// For normal use, we require that you edit the sketch to replace FILLMEIN
// with values assigned by the TTN console. However, for regression tests,
// we want to be able to compile these scripts. The regression tests define
// COMPILE_REGRESSION_TEST, and in that case we define FILLMEIN to a non-
// working but innocuous value.
#ifdef COMPILE_REGRESSION_TEST
# define FILLMEIN 0
#else
# warning "You must replace the values marked FILLMEIN with real values from the TTN control panel!"
# define FILLMEIN (#dont edit this, edit the lines that use FILLMEIN)
#endif
// LoRaWAN NwkSKey, network session key
// This should be in big-endian (aka msb).
static const PROGMEM u1_t NWKSKEY[16] = {0x32, 0xF8, 0xD5, 0x7D, 0x2A, 0x08, 0xE2, 0x4F, 0xED, 0x83, 0x14, 0x90, 0x0F, 0x1A, 0xE2, 0x62};
// LoRaWAN AppSKey, application session key
// This should also be in big-endian (aka msb).
static const u1_t PROGMEM APPSKEY[16] = { 0x27, 0x27, 0x9A,0x5F, 0x68,0x0A, 0x23, 0xA1, 0x1C, 0x84, 0x91, 0xBC, 0x74,  0xFE, 0X09, 0X0F};
// LoRaWAN end-device address (DevAddr)
// See http://thethingsnetwork.org/wiki/AddressSpace
// The library converts the address to network byte order as needed, so this should be in big-endian (aka msb) too.
static const u4_t DEVADDR = 0x00BC3BBE ; // <-- Change this address for every node!
// These callbacks are only used in over-the-air activation, so they are
// left empty here (we cannot leave them out completely unless
// DISABLE_JOIN is set in arduino-lmic/project_config/lmic_project_config.h,
// otherwise the linker will complain).
void os_getArtEui (u1_t* buf) { }
void os_getDevEui (u1_t* buf) { }
void os_getDevKey (u1_t* buf) { }
static uint8_t mydata[] = "Hello, world!";
static osjob_t sendjob;
// cycle limitations).
const unsigned TX_INTERVAL = 60;
// Pin mapping
// Adapted for Feather M0 per p.10 of [feather]
    .nss = 10,                       // chip select on feather (rf95module) CS
    .rxtx = LMIC_UNUSED_PIN,
    .rst = 9,                       // reset pin
    .dio = {2, 6, 7}, // assumes external jumpers [feather_lora_jumper]
                                    // DIO1 is on JP1-1: is io1 - we connect to GPO6
                                    // DIO1 is on JP5-3: is D2 - we connect to GPO5
//------ Added ----------------
#define LED_RED 8
#define LED_GREEN  5
void onEvent (ev_t ev) {
    Serial.print(os_getTime());
    Serial.print(": ");
    switch(ev) {
        case EV_SCAN_TIMEOUT:
            break;
        case EV_BEACON_FOUND:
            break;
        case EV_BEACON_MISSED:
            break;
        case EV_BEACON_TRACKED:
            break;
        case EV_JOINING:
            break;
        case EV_JOINED:
            break;
        || This event is defined but not used in the code. No
        || point in wasting codespace on it.
        || case EV_RFU1:
        ||     Serial.println(F("EV_RFU1"));
        ||     break;
        case EV_JOIN_FAILED:
            break;
        case EV_REJOIN_FAILED:
            break;
        case EV_TXCOMPLETE:
            if (LMIC.dataLen) {
              Serial.println(LMIC.dataLen);
              if (LMIC.dataLen == 1) {
                uint8_t result = LMIC.frame[LMIC.dataBeg + 0];
                if (result == 0)  {
                  Serial.println("RESULT 0");
                  digitalWrite(LED_RED, LOW);
                  digitalWrite(LED_GREEN, LOW);
                if (result == 1)  {
                  Serial.println("RESULT 1");
                  digitalWrite(LED_RED, HIGH);
                if (result == 2)  {
                  Serial.println("RESULT 2");
                  digitalWrite(LED_GREEN, HIGH);
                if (result == 3)  {
                  Serial.println("RESULT 3");
             Serial.println();
            // Schedule next transmission
            break;
        case EV_LOST_TSYNC:
            break;
        case EV_RESET:
            break;
        case EV_RXCOMPLETE:
            // data received in ping slot
            break;
        case EV_LINK_DEAD:
            break;
        case EV_LINK_ALIVE:
            break;
        || case EV_SCAN_FOUND:
        ||    Serial.println(F("EV_SCAN_FOUND"));
        ||    break;
        case EV_TXSTART:
            break;
        case EV_TXCANCELED:
            Serial.println(F("EV_TXCANCELED"));
            break;
        case EV_RXSTART:
            /* do not print anything -- it wrecks timing */
            break;
        case EV_JOIN_TXCOMPLETE:
            Serial.println(F("EV_JOIN_TXCOMPLETE: no JoinAccept"));
            break;
        default:
            break;
void do_send(osjob_t* j){
    } else {
void setup() {
//    pinMode(13, OUTPUT);
   // while (!Serial); // wait for Serial to be initialized
    Serial.begin(115200);
    //delay(100);     // per sample code on RF_95 test
    pinMode(LED_RED, OUTPUT);
    pinMode(LED_GREEN, OUTPUT);
    #ifdef VCC_ENABLE
    // For Pinoccio Scout boards
    pinMode(VCC_ENABLE, OUTPUT);
    delay(1000);
    #endif
    // LMIC init
    os_init();
    LMIC_reset();
    // Set static session parameters. Instead of dynamically establishing a session
    // by joining the network, precomputed session parameters are be provided.
    #ifdef PROGMEM
    // On AVR, these values are stored in flash and only copied to RAM
    // once. Copy them to a temporary buffer here, LMIC_setSession will
    // copy them into a buffer of its own again.
    uint8_t appskey[sizeof(APPSKEY)];
    uint8_t nwkskey[sizeof(NWKSKEY)];
    memcpy_P(appskey, APPSKEY, sizeof(APPSKEY));
    memcpy_P(nwkskey, NWKSKEY, sizeof(NWKSKEY));
    LMIC_setSession (0x13, DEVADDR, nwkskey, appskey);
    #else
    // If not running an AVR with PROGMEM, just use the arrays directly
    LMIC_setSession (0x13, DEVADDR, NWKSKEY, APPSKEY);
    #endif
    #if defined(CFG_eu868)
    // Set up the channels used by the Things Network, which corresponds
    // to the defaults of most gateways. Without this, only three base
    // channels from the LoRaWAN specification are used, which certainly
    // works, so it is good for debugging, but can overload those
    // frequencies, so be sure to configure the full frequency range of
    // your network here (unless your network autoconfigures them).
    // Setting up channels should happen after LMIC_setSession, as that
    // configures the minimal channel set. The LMIC doesn't let you change
    // the three basic settings, but we show them here.
    LMIC_setupChannel(0, 868100000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
    LMIC_setupChannel(1, 868300000, DR_RANGE_MAP(DR_SF12, DR_SF7B), BAND_CENTI);      // g-band
    LMIC_setupChannel(2, 868500000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
    LMIC_setupChannel(3, 867100000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
    LMIC_setupChannel(4, 867300000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
    LMIC_setupChannel(5, 867500000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
    LMIC_setupChannel(6, 867700000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
    LMIC_setupChannel(7, 867900000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
    LMIC_setupChannel(8, 868800000, DR_RANGE_MAP(DR_FSK,  DR_FSK),  BAND_MILLI);      // g2-band
    #elif defined(CFG_us915) || defined(CFG_au915)
    // NA-US and AU channels 0-71 are configured automatically
    // but only one group of 8 should (a subband) should be active
    // TTN recommends the second sub band, 1 in a zero based count.
    // https://github.com/TheThingsNetwork/gateway-conf/blob/master/US-global_conf.json
    LMIC_selectSubBand(1);
    #elif defined(CFG_as923)
    // Set up the channels used in your country. Only two are defined by default,
    // and they cannot be changed.  Use BAND_CENTI to indicate 1% duty cycle.
    // LMIC_setupChannel(0, 923200000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);
    // LMIC_setupChannel(1, 923400000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);
    // ... extra definitions for channels 2..n here
    #elif defined(CFG_kr920)
    // Set up the channels used in your country. Three are defined by default,
    // and they cannot be changed. Duty cycle doesn't matter, but is conventionally
    // BAND_MILLI.
    // LMIC_setupChannel(0, 922100000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_MILLI);
    // LMIC_setupChannel(1, 922300000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_MILLI);
    // LMIC_setupChannel(2, 922500000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_MILLI);
    // ... extra definitions for channels 3..n here.
    #elif defined(CFG_in866)
    // BAND_MILLI.
    // LMIC_setupChannel(0, 865062500, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_MILLI);
    // LMIC_setupChannel(1, 865402500, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_MILLI);
    // LMIC_setupChannel(2, 865985000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_MILLI);
    #else
    # error Region not supported
    #endif
    // Disable link check validation
    LMIC_setLinkCheckMode(0);
    LMIC.dn2Dr = DR_SF9;
    // Set data rate and transmit power for uplink
    LMIC_setDrTxpow(DR_SF7,14);
    // Start job
    do_send(&sendjob);
void loop() {
    unsigned long now;
    now = millis();
    if ((now & 512) != 0) {
      digitalWrite(13, HIGH);
    else {
      digitalWrite(13, LOW);
    os_runloop_once();
Compile & test??
At face value it looks OK to me.
Thank you,
so I send 01 from server but it does not get to node
What does the serial output show you - I’m betting it is:
Received 2 bytes of payload
as that’s what you have sent - two bytes, and you’ve coded to check for 1. So why the 0? But I agree, it’s not clear what you put in the various boxes - suffice to say, it’s not hex and it translates whatever characters you enter in to binary.
So, to speed things up, that 1 will actually be turned in to 49 which is the decimal for the character 1. You may want to Serial.print the result so you can see what you actually receive.
nothing shows on my serial monitor as recieved
Are you seeing the EV_TXCOMPLETE (includes waiting for RX windows) message
If so, you could add a print of the LMIC.datalen directly underneath to see what is coming in, or not.
I already have this line in my code above,
Yes, I could see, I’m asking if that message comes up in the serial console when you send an uplink (which proves the LMIC stack thinks it has sent) and suggesting that you Serial.println the LMIC.datalen value without the if statement so we can see if you are getting the downlink, even if it is longer than you expect.
oh ok let me try that now
I have done that now, I get 0 printed
Assuming TTN Console (or some gateway log) showed that a downlink should have been transmitted, you need to figure out why your device is not receiving it. You can start by adding the following to the setup, for example after the line for LMIC_setDrTxpow:
// Make LMIC start its RX windows a bit earlier, and listen longer, to
// compensate for an inaccurate clock.
// Beware that a specific value may work for a slow data rate, but not
// for faster ones, and remember that RX1 may use different data rates
// than RX2. Like for some tests, RX2 in EU868 (using SF9) worked with
// the standard settings, but RX1 for SF8 needed 2%, while RX1 for SF7
// even needed 5% of the maximum error. For corrections exceeding 0.4%
// (0.4 / 100) this also needs LMIC_ENABLE_arbitrary_clock_error; see
// https://github.com/mcci-catena/arduino-LMIC/blob/master/README.md
LMIC_setClockError(MAX_CLOCK_ERROR * 5 / 100);
Be sure to read the link mentioned in the comment above; the example value of 5% is much higher than the 0.4% mentioned in that documentation. So, you’ll need to set the compile-time flag LMIC_ENABLE_arbitrary_clock_error, or when using the Arduino editor, set the flag in the file Arduino/libraries/MCCI_LoRaWAN_LMIC_library/project_config/lmic_project_config.h
Also note the following comment in LMIC’s source code:
Please please please can you confirm:
as at this stage, we don’t even know if the device is actually transmitting.
And then please please please confirm that you are seeing the transmitted data in the web console - as that will confirm that all the transmission settings are correct.
I am seeing my transmitted data both on the serial monitor and on the web interface,
when i send downlink i also see it scheduled. but it will not get to the node…serial monitor
Only in the gateway’s Traffic page, or also in the application/device’s Data page? Only when you see it in the Data page in TTN Console, you know for sure that the device’s configuration matches the secrets that TTN knows, and that TTN has accepted the value of your uplink counter. (The latter check may be disabled, for testing.)
Here, it’s the other way around: are you only seeing it in the application/device’s Data page, or also in the gateway’s Traffic page? (Or even in the gateway’s log files?) Screenshots will help confirm all this.
Aside:
Beware that, after testing, you’re only allowed to do this at most 10 times per 24 hours.
Morning @cherechi, I think we are really close to solving this.
As Arjan said, just for peace of mind because the downlink will never work if the credentials aren’t correct, can you confirm that you are seeing the uplink on the Device’s Data tab - note, this only shows real time, so you won’t see anything until there is an uplink whilst the page is open.
I use almost exactly the same code base for Arduino 328P + RFM95 setups so I am quite familiar with the issues - it took me a while to get things going but once I did, it works nicely. Whilst you check the console, I’ll get one out so I can dip in to the code myself.
Thanks alot for your concern, I do get the uplinks on the data tab, also i do see the downlinks on the gateway log as shown in the image below as it is sent at 869.525MHz but it never arrives at the node to turn on the LED. But this morning, I tried sending a downlink, my node recieved it and the LED was turned on. now i cannot turn it off anymore as the dowlink will not get to the node againDOWNLINK serial monitor
Woo hoo!
So we know it can work, we just need to make it work more reliably, so I’d look at Arjan’s comment about the timing tuning:
But also, as I should have mentioned sooner, you should limit downlinks as they render the gateway totally deaf whilst transmitting. So what is the LED for? Can it operate locally?
