our test house told us that in Australia the maximum transmission power is 25 mWatt for LoRa. The value 1 watt is also found in the standards.
What applies now and under what circumstances?
Holger
Holger
I am intrigued by this.
Maybe in Australia the regulations notionally allow you to use a TTN Node or Gateway at up to 1 Watt.
But are their Gateways and nodes that are capable of 1 Watt ?
No, of course our LoRa devices cannot handle 1 watt. But just 100 mWatt. And a limit of 25 mWatt hurts.
Hence the question:
Does the limitation to 25 mWatt always apply?
What is the range difference between 100mW and 25mW, or between 1W and 25mW?
Maybe the the Australian regulator knows …
What standards? Australia regulating authority or somewhere ells?
Standard:
https://www.legislation.gov.au/Details/F2022C00281
Out of this document:
58
Digital modulation transmitters
915–928
1 W
The radiated peak power spectral density in any 3 kHz must not exceed 25 mW per 3 kHz.
Your best bet is to speak to the regulating authority.
You can also read from the same document.
20. All transmitters 915–928 3 mW
54. All transmitters 915–928 3 mW Frequency hopping transmitters 915–928 1 W A minimum of 20 hopping frequencies must be used.
58 Digital modulation transmitters 915–928 1 W The radiated peak power spectral density in any 3 kHz must not exceed 25 mW per 3 kHz.
All jargon for lawyers to interpret.
I’m curious if anyone has done further analysis on this issue. i.e. Is LoRa modulation in Australia actually limited to 25mW.
More specifically has anyone done a technical analysis of LoRa Chirp Spread Spectrum modulation in relation to Part 58 of the ACMA regulation (The radiated peak power spectral density in any 3 kHz must not exceed 25 mW per 3 kHz).
Perhaps Andrew @Maj and the Meshed (AU) team as long term friends and deployers of TTN/TTI solutions and TTN network operators have some perspective (and guidance) on this?..
