These are the steps I took, all at your own risk:
Compile TTN Gateway Firmware on Ubuntu
Install 64 Bit dependencies
Resource: http://microchipdeveloper.com/install:mplabx-lin64
sudo apt-get install libc6:i386 libx11-6:i386 libxext6:i386 \
libstdc++6:i386 libexpat1:i386
Download and install MPLABX
Resource: http://microchipdeveloper.com/mplabx:installation
tar -xvf MPLABX-v4.05-linux-installer.tar
chmod u+x MPLABX-v4.05-linux-installer.sh
sudo ./MPLABX-v4.05-linux-installer.sh
Next, Accept Agreement, Next
/opt/microchip/mplabx/v4.05
Next, Finish
To prevent error java not found:
sudo mkdir /opt/microchip/mplab_ide
sudo ln -s /opt/microchip/mplabx/v4.05/sys /opt/microchip/mplab_ide/sys
Install XS32 compiler
Download
Resource: http://www.microchip.com/mplabxc32linux
NOTE: we need older version v1.42 to prevent errors like these:
error: '_CNCONB_SIDL_MASK' undeclared (first use in this function..)
You get them when you try to compile with 1.43 or higher.
https://www.webeaver.com/1199815/08f0d806ca3a4d6a7dc32c4344237875/download-xc32-v1-42-full-install-linux-installer-run
If anyone find a safer download source, please let me know.
chmod +x ./xc32-v1.42-full-install-linux-installer.run
sudo ./xc32-v1.42-full-install-linux-installer.run
Next, Accept, Next, Next
/opt/microchip/xc32/v1.42
Next, Add path, Next, Next, Get Coffee, Next, Finish
sudo apt install build-essential cppcheck
mkdir ~/ttn-gw-dev && cd ~/ttn-gw-dev
git clone --recursive https://github.com/TheThingsProducts/gateway.git
cd gateway/firmware
cppcheck --enable=all --inconclusive --force --xml --xml-version=2 src 2> cppcheck.xml
./generate_version_header.sh
./fix_mplab.sh
vi compile.sh and correct prjMakefilesGenerator path:
elif [ "$(uname -s)" = "Linux" ]; then
prjMakefilesGenerator='/opt/microchip/mplabx/v4.05/mplab_ide/bin/prjMakefilesGenerator.sh'
./compile.sh
[Get Coffee here]
./generate_hex_with_checksum.sh
ls -l firmware.hex
-rw-r--r-- 1 ron ron 2767956 feb 1 21:22 firmware.hex
cat checksums
337950176cab81e5715b16c86af424cca57d0de088e5a24dcec7fef5c24e432b firmware.hex
Write them to SD Card (I used a 2GB FAT32 formatted one)
mkdir /media/<your path>/update
cp firmware.hex checksums /media/<your path>/update
ls -l /media/<your path>/update/
total 2708
-rw-r--r-- 1 ron ron 79 feb 1 21:52 checksums
-rw-r--r-- 1 ron ron 2767956 feb 1 21:52 firmware.hex
Insert in gateway and boot
Notice the intermittent outside and center leds blinking until finished.
Check you info page at http://things-gateway.local/info
