Can we use the “Payload Functions” (Decoder, Converter and Encoder) when integrating with Cayenne myDevices? This way we could optimize for airtime and enjoy standardized sensor data…
@eptak My encoding routine was based on the example provided for addAnalogOutput
(Cayenne LPP C++ payload builder). The line buffer[cursor++] = value;
should be removed, as else there are 5 bytes added and not just 4 as define with LPP_ANALOG_OUTPUT_SIZE
Slightly offtopic - I think when I wrote it I wasn’t looking at it in a generic enough way - happy to revise humidity
to percentage and add more types (pull requests welcome!). I actually added a bitmap type yesterday for @Caspar .
There was also some talk last year to add protocol buffers as first-class-citizens to the TTN side (see https://github.com/TheThingsNetwork/sdk/pull/19) - I was talking to @johan at the time, but the issue got closed and I lost track. Maybe we can pick that up again.
Hi all, have been investigating the LoraWan network in Australia, running a rpi and a multitech lora 915 card as the gateway and a Sodaq one as the node, which is running great but it is a pain to decode the data that I send … and it’s all been very generic data: lat, lon, bat, temp
I have been reading about the LPP on the myDevices Docs, now I think it would be absolutely fantastic if there was a inbuilt TTN decoder that adheres to the LPP standard so if we were to use the rest data intergration in the TTN, or view from the data tab, we would be presented with the data that we are most fond of … a json object with pretty properties of temp, hum, lat, long etc … that we didn’t have to decode manually … yay!
The LPP standard would also reduce the amount of manually sticking bits into a buffer on the arduino side also, reducing the complexity for beginners, the only library I have found for the LPP on the arduino side is Zenseio/CayenneLPP, which seems to support the standard, maybe there is more?
Cheers
Adam.
If the node always sends the same data, do you feel LPP is that much easier than lora-serialization? I’d prefer something like the latter to be integrated in the payload functions. Arduino side:
LoraMessage message;
message.addTemperature(-1.45)
.addHumidity(30.10)
.addUint16(3900) // anything, like maybe voltage
.addLatLng(-33.905052, 151.26641); // et cetera
Decoder (if the library would be integrated in TTN; right now one needs to first copy/paste it into the Decoder function manually):
// Define the order in which the fields are sent, and their
// names in the JSON output
return decode(bytes,
[temperature, humidity, uint16, latLng],
['temp', 'humidity', 'battery', 'location']);
That’s 12 bytes† for the application payload (with the 13 bytes LoRaWAN header: total of 24), whereas LPP would then use an additional 11 bytes (including 3 for the altitude which on roads is hardly useful).
One could even do smart things with bits to tell if data is skipped (rather than using 16 bits for each field).
† Well, currently 2 more, as it sends 8 bytes for coordinates while 6 would suffice.
@arjanvanb thanks the lora-serialization library indeed does solve many of my issues, thanks for the explanation of the the size difference also.
But… if it is working correctly at the myDevices side as I haven’t tested, the major bonus of using the LPP is that the UI is generated for you, adhere to the LPP and myDevices supposedly will expose the data for the UI automatically… this is the closest I’ve seen to a interoperable standard I’ve seen in my brief experience in low powered data. I believe whole heartily that this should be the direction forward.
Cheers
I was able to get things up and running by including https://github.com/Zenseio/CayenneLPP and adjusting the example a bit. Works with https://github.com/tijnonlijn/RFM-node
Here is a sample sketch using a DHT 11 temp sensor.
I’ll go for a decoder solution on the TTN Backend. Since then it doesn’t matter how I transmit the data over the air. If I use the STM Stack it’s not so easy to implement a Arduino Stack, if i use a board running python and the microchip module, i need to reemplement the whole Arduino library.
That would be great indeed. Unfortunately, the payload functions expect an object as the result. When just trying to return an array of (modified) bytes, one cannot save the Decoder function:
function Decoder(bytes, port) { return bytes; }
Error(“Could not dry-run uplink on Handler: Decoder not valid: does not return an object”)
So, even if the payload functions are executed before the integration is invoked (I don’t know for Cayenne; they are certainly called for the Data Storage integration), then currently one cannot enhance/convert the node’s payload into a Cayenne LPP.
@JDP @eptak @dittrich @AdamJP @christopherdro I just integrated CayenneLPP in TheThingsNetwork Arduino library v2.5.0, soon available from Arduino Library Manager.
See documentation here: https://www.thethingsnetwork.org/docs/devices/arduino/api/cayennelpp.html, and example here: https://github.com/TheThingsNetwork/arduino-device-lib/blob/master/examples/CayenneLPP/CayenneLPP.ino
Next is to have a JavaScript library that we can preload for payload functions, but for use with Cayenne this is already handy.
@joscha @arjanvanb see my comment on the lora-serialization
library here: https://github.com/TheThingsNetwork/sdk/pull/19#issuecomment-286408287. Happy to work with you guys on integrating this too.
Wow awesome work, thanks!
Great work TTN ! Thanks for pushing Cayenne LPP !
Per the JS decoder function, we are going to open source ou Cayenne LPP decoder.
We’ll be able to provide you the code then
Hi All, great discussion and great reads on Cayenne LPP.
Thank you so much…
I tried to combine the TTN Build your own Sensor Workshop, with an implementation of Cayenne LPP.
I think the payload looks ok, but Cayenne does not accept it, since on the dashboard I only see the RSSI and SNR.
Question:
Is there an cayenne LPP Decoder online available that I can feed my byte string and then see what I did wrong?
// Cayenne LPP Byte definition
// https://github.com/myDevicesIoT/cayenne-docs/blob/master/docs/LORA.md
// Cayenne LPP Payload buildup
// https://hansboksem.wordpress.com/2017/03/06/sending-sensor-data-through-the-things-network-to-cayenne/
// Lora TTN via LMIC and bmp280 code
// https://github.com/galagaking/ttn_nodeworkshop/blob/master/ttn_bmp280_abp.ino
// Edzo’s First LoRa TTN Cayenne LPP Implementation
// https://github.com/edzob/loraNode/blob/master/sketch_20170406_lora.ino
old
// Byte string in the Lora TTN Payload
// 036700E9046800057328163C94100F141E3D6F08
It’s not too hard to manually decode this? I run into problems using the documentation:
03 67 00E9 67 = temperature
04 68 00 68 = humidity
05 73 2816 73 = barometer
3C 94 100F141E3D6F08 94 = unknown type?
(My guess is that you’re missing xx 88
at the start of the last section, for GPS location. Any online decoder would fail as well, so is of little help…)
@arjanvanb Thanks for the hint.
I first build a hardcoded message with the existing code
and then used the example functions to build up payload with the sensor data
and now it works!
I needed some reading on Hex Decimals and and Byte Array… and learned a lot.
Thanks for the nudge into the right direction
Code on github is updated.
I have a TTN/Cayenne device integration. This device has a DHT11 sensor and the payload is in LPP format.
The application data in the TTN Console looks fine to me: 036700C804684400
channel 03, type 67, tempvalue: 20C and channel 04, type 68, humvalue: 34%
My problem; I only see the RSI and SNR widget in Cayenne and reading the answers in previous posts there must be something wrong with my payload but I have no idea. Anyone else?
That should be one byte, not two, for the value. But you’re sending 04 68 4400
Thanks Arjan, that is exactly what played in my mind.
At the moment I’ve no access to the code but I’ll try to remove the last byte.
int16_t val;
uint8_t channel;
byte buffer[8];
uint8_t cursor = 0;
val = temperature;
val = temperature * 10;
channel = 0x03;
buffer[cursor++] = 0x03;
buffer[cursor++] = LPP_TEMPERATURE;
buffer[cursor++] = val >> 8;
buffer[cursor++] = val;
val = humidity;
channel = 0x04;
buffer[cursor++] = channel;
buffer[cursor++] = LPP_RELATIVE_HUMIDITY;
buffer[cursor++] = humidity * 2;
Serial.println(F(“OP_TXRXPEND, not sending”));
} else {
//LMIC_setTxData2(1, buffer, sizeof(buffer)/sizeof(buffer[0]), 0);
LMIC_setTxData2(1, buffer, 7, 0); //brute force
…or:
byte buffer[7];
…or better yet:
byte buffer[20]; // any maximum size your payload might need
buffer[cursor++] = ...
LMIC_setTxData2(1, buffer, cursor, 0);
