On paragraphs 1.4 and later from the QuickStartGuide, there are some descriptions of the Pin headers.
I am not very familiar with the GPIO connections on Raspberry Pi and would like to check the wiring between the Pi and the concentrator.
Would I just need to wire CLK/MISO/MOSI/NSS and Reset pins from the IC880A-SPI to the Raspberry Pi 2 ?
What are the corresponding pins on the Raspberry Pi 2 side ?
About power supply on the IC880A-SPI, I suppose it is preferable to provide a separate power supply to the concentrator rather than getting power from the RPI 2 ?
Finally, can anyone confirm having a working gateway with setup similar to mine (RPI2 with iC880A-SPI) ?
I have used a 5V 3A powersupply from Conrad https://www.conrad.nl/nl/hn-power-hnp18-050-c-stekkernetvoeding-vaste-spanning-5-vdc-3000-ma-512693.html
although i think 2A is good enough. I have connected it to the PI-pins 4(+5V) and 6(gnd).
Connections RPI <=> IC880
+5Vā¦2ā¦21
NSSā¦26ā¦17 (i have rpi-24 but changed the source of poly-forwarder)
MOSIā¦19ā¦16
MISOā¦21ā¦15
SCLKā¦23ā¦14
resetā¦39ā¦13 =gnd - dont know what else to do with it
GNDā¦25ā¦12
please doublecheck the connections for yourselfā¦
I will next connect an Adafruit ultimate GPS to the PIās rxd/txd and the IC880ās PPS.
See what happensā¦
I got this configuration up and running easily last week. The gateway has been running since then (Utrecht Noord-Oost, Holland), without the power block getting (too) warm.
I used a 5V 2A power block for the Raspberry Pi, with the Pi then powering the IC880A-SPI. I followed the instructions and the installation script (!!) at https://github.com/ttn-zh/ic880a-gateway/tree/spi (donāt forget to select the spi branch).
Thanks to you both arthoo and ernestopace.
Actually I did not know about that that auto install script, thanks for the link and the details on the connections.
Iāll post back when I have everything running
@w4e,
Do you still know what the problem/failure was?
Something with the messageformat?
On my windowsill it works a treat. It has a fix in 40sec after a cold start.
Just coming back to confirm the install went smooth, thanks guys for the tips !
The concentrator interface seems to be work and running util_tx_test gives some good feedback and LEDs flashing on the IC880A.
sudo ./util_tx_test -f 868 -r 1257
Sending -1 packets on 868000000 Hz (BW 125 kHz, SF 10, CR 1, 16 bytes payload, 8 symbols preamble) at 14 dBm, with 1000 ms between each
INFO: concentrator started, packet can be sent
Sending packet number 1 ...OK
Sending packet number 2 ...OK
Next, I need to get a node and connect it to the gateway.
First of all, my first post here and enjoying this forum and the input of many of you to help out!
Lojim, I have almost the same configuration not a RPi 2 but a B+ and followed the perfect installation script without any problem. Unfortunately I canāt get the poly_pkt_fwd up and running, I keep getting the ERROR: [main] failed to start the concentrator.
Did you do anything more than the installation script?
The install scripts setup the gateway software as a service which gets starter achter a reboot. So afterthe installatie( and perhaps a reboot) the gateway should be running.
You can check if it is running by looking at the system log file /var/log/daemon.log. The gateway posts some info here every minute or so.
Remember to use sudo to view this file.
You could also check if the gateway is running by using ps -ef.
If you want to run by hand, donāt forget to run the gateway with sudo.
Finally, make sure you have enabled SPI with the programming raspi-config, under Advanced options - SPI.
If youāre getting that error, chances are thereās either a problem with the wiring or -as @ernestopace said- you need to enable SPI using raspi-config.
I had the problem documented here:
https:// github.com/Lora-net/lora_gateway/issues/17
So I just didnāt connect the TX of the Pi. Is it necessary to have the Pi being able to talk back to the GPS? My GPS sends its status once per second, and everything seems to be fine.
Greetings!
Excuse me for newbieās question )
Does IC880A board match to use it in LoRa network environment?
I found the and want to build my own system.
I faced with the problem to make a gateway.
In project description I found out that the LoRaWan concentrator is needed.
But I did not found the schematics of this board.
The IMST sell the IC880A board, and, as far as I understand, the board is the same. Isānt it?
