Whilst using the same command code for two different things, the parser should be able to tell from the downlink length.
01 for the stationary uplink mode, 0x7800 = 30720 = 8 hours.
The two bytes is little endian.
[School boy error ]
But if your intention was …
then apart from the questionable use of battery sending a message to say something is in the same place every two minutes, there is no region where that doesn’t breach the TTN Fair Use Policy.
Well, I understand the policy:
my intention was only to see if downlink was working. At the end I would have in stationary mode one up link every 2 Hours, and when moving I would every 30 minutes. What you said about the 8 Hours I think that is not correct because If you see the command example attached there is a switch in the digit: 01201C Command for example become 0x1C20,yhat is 7200secs.Not sure if I’m right or you are right, this is what I understand. But apart the frequency I need to figure out if downlink work
As there is no point in duplicating the image, it’s been removed along with my embarrassing error. Ideally you could supply a link to the entire PDF so there is context and we can remove the mauve colour scheme!
But you don’t have to break FUP to do that - 5 minutes would suffice. What if it gets through and then it’s not able to be reversed or you forget?
Why not send the 00 command - that way it should send back the current configuration and it is documented that it just needs a standard downlink.
Has it been uplinking in the meanwhile so you know the battery is OK, ie it is still running?
Can you get someone to check on it?
Why are you trying to debug something so far away?
Can it be bought to you so you have more control over the situation?
If the “get” version can only be sent by itself, that’s possible.
But from the context of the examples, it looks like it’s legal to put multiple verbs in sequence, each of which encodes the length of the following data, if any, that would have to be included before the next verb.
Note that’s exactly how LoRaWAN MAC commands are encoded, and while these aren’t those (they’re sent on port 204 with application keys, rather than unencrypted in the fopts or on port 0 with network keys), inspiration wouldn’t be surprising.
Hmm, those uplink numbers are neither great nor terrible, they start to get into the range where I’d expect things to often work but there to be occasional packets dropped even absent specific intereference.
Do you have any independent confirmation that the node is managing to receive downlinks at all?
If there is some other evidence that the node is receiving downlinks, and these in particular aren’t working, you may need to pursue clarification with the vendor.
A lot of Questions, thank you for your kindness.
Sensor is working, because I have the integration with Cayenne and i see every day the sensor update, that is in stationary mode and send up link every two hours. It has been one week and battery it’s 100%.Sensor is in my bedroom ( parent’s house), I’m living 30km away. On Wednesday when I will go there I would try some On Off director in the sensor, that has also a push button to trigger up link and anyway it could start moving and give by default up link every 15 secs. Attached data on Cayenne web app: last SNR e RSSI is better than before:
This is my first end node with first gateway installed in our municipality for testing before going to the next step. For GPS tracking we would preservativo buttery consumption to send up link not every 15 secs, but something like 15 min or 30 min would be useful for our utilization. I’ve already figured out that with uplink every 15 secs, in moving situation, battery went away in less than 24 Hours.
I could setup moving mode up link every 2 minutes on order to got 8 days sensor alive. Or a multiple of 2 minutes, but 15 secs it Is too high frequency. People don’t Want put on charge their smartphone and a certain number of sensors every day,. I undestand that tracking need high frequency update, but a compromise could help for now
Please return to step 0 where you have a gateway and two or three devices in the same room and you learn LoRaWAN really well before inflicting complications on yourself like trying to debug downlinks on a device 30km away whilst saying things that break the FUP - you know we hate that, well we’re not so keen on downlinks either - search the forum for more info, very particular the why and what happens to a gateway when you do a downlink.
I think you are spinning your wheels at present so I’d suggest you stop for now - get the device in the same room as you to debug things and as you have aspirations for a great TaDa roll out across your village, you really need to know LoRaWAN well before your neighbours start trying to warp time & space with their ideas and you literally break LoRaWAN / TTN in your area.
As a minimum, you need to know: https://www.thethingsnetwork.org/docs/lorawan/ which should get you to a point where you can get the basic certification. Inevitably you will end up wanting or needing to build your own devices, so getting good with Arduino & LMIC-node & an Adafruit Feather M0 with RFM95 would be a good start.
The documents are clearly written by someone technical who forgot to give it to someone else that doesn’t know the product - ie they forgot testing - as I’d not describe much of that section as a model of clarity.
Apart from the colours making things fuzzy, I think that’s a || aka a logical or between the different packet examples.
As you almost inevitably end up sending two bytes for a time period, I make it simple on myself for testing & anyone else using the console and use HHMM - although I’ve not ended up with any consistency on what to do if they send bigger numbers than 9 or more than 60 in the MM etc. But mostly the downlinks are generated from a UI so it can be sanity checked before hand.
Thank you for your advice. Anyway I understand to procede slowly and increase my skill step by step.
For studying I’ve only bought a gateway and a device, there are not more people insolventi, only the municipality is happy if this project will work some day in the future, it could be one, or two or 3 Years never Mind, in the respect of the regulation and local certification when installing everything: no things will be done with risk.
It was only a start and for sure I have a lot of question. Some young engineer could work as well on Arduino and build own devices, some others, old people could use a commercial end device, so this is why I bought a Browan GPS device, registered on TTN and see data on Cayenne, TTN mapper and anche Mqtt client.
I know that to have a good coverage could be necessary 5 gateway. Municipality looks very interested and appreciate my free study ( I don’t get any money for this, because is my village and i love it) and it would be very happy if one day in the next years if Lorawan could help to prevent fire events in the hills by using hundred of sensor that detect spike on temeprature or umidity. I’m keep studying on it, and ask for help in these topics to solve my doubts and go on.
If downlink is something that are not regular under TTN, we will not use it
This is where you are letting yourself down - it’s not TTN that’s not keen on downlinks, it’s ALL LoRaWAN networks - and you do not appear to know why and you do not appear to have gone to find out what the problem is for a local area when a gateway is transmitting a downlink.
Downlinks are fine here and there - I figure on one a fortnight for device signal strength check for a device that is in a ‘safe’ coverage zone. And occasionally a device may need its configuration changing, typically on season change (no point monitoring soil moisture levels whilst there is no crop in the fields, may as well save battery life).
But if your use case for a device is fundamentally reliant on downlinks, you need to rethink the use case. Because connectivity is not guaranteed, by which we mean it may not get through for a number of hours, days even.
It is also a bit unfortunate that you have chosen a tracker as your first device, as the usefulness of such a thing with LoRaWAN is questionable at best and often prone to not meeting expectations. Again, multiple discussions on the forum for you to read.
TTN Mapper is for radio / gateway coverage - it’s an engineering application, not something end users will benefit from.
I think you gave up too quickly on the water meter - there are other ways to detect water issues as mostly they come from leaks and detecting leaks is something that LoRaWAN is a very good use case. You could have 100 of them setup before the cold weather starts bursting pipes and provide an excellent first project for your community.
And while you are working on the water issue, you can research fire detection for your forests for spring.
That’s definitely true… I think we’re getting to the point where the OP needs to be asking the vendor.
That would appear to be simply visual, as the first screenshot example in the thread has multiple command sequences concatenated together and explicitly list their total of 9 bytes as the payload length - again, exactly the same mechanism as lower level LoRaWAN MAC commands and responses use.
No one is expected to accept the default configuration of the manufacturer.
But we do ask people to find out about LoRaWAN - what have you found out about downlinks and their impact on the gateway and consequently the other devices in the area.
Yes, no, maybe, water leaks in public areas aren’t my thing, what does Mistress Google come up with?
But find out about downlinks first before I wonder if we are just helping facilitate a future train wreck. I trust you understand that it’s all volunteers answering on here, no one is obligated to help you, so some co-operation helps, particularly if the people answering have some modicum of experience and are desperately hinting at important things you really need to know and even provide a link to that basic information and suggest searching the forum for information.
Hmm, the payload in that spreadsheet is, well, absurd
But if it’s accurate, then not only are the command sequences legal to concatenate together but also raises the possibility that you might actually be required to specify everything in the downlink.
To bad the concept of “use your words” seems to be lost on this vendor.
