Dragino LT-22222-LT downlink decoder error - redux
Unfortunately, the solution does not work for me in 2025.
My Firmware V1.6.1. 19. Jan. 2024
https://www.dropbox.com/scl/fo/ztlw35a9xbkomu71u31im/AMnEamqoeB3aaTsYDfwFtUM/LoRaWAN%20End%20Node/LT-22222-L/Firmware?dl=0&rlkey=ojjcsw927eaow01dgooldq3nu&subfolder_nav_tracking=1
V1.7
-- 1.Upgrade LoRaWAN to DR-LWS-008 stack
1)Added multicast downlink functionality via server chirpstack.
2)Added downlink delay reset function, four bytes 0x0​​4 FF xx xx, where xx xx is the number of seconds after receiving the command to reset.
-- 2.After adding a downlink control relay or DO port, save the status to FLASH immediately.Need to be used with AT+RODORET.
v1.6.3
-- 1.Optimize the interrupt trigger delay of AT+TRIG.
-- 2.Optimize serial port printing to prevent abnormal reset.
V1.6.2
-- 1.When AT+ATDC=0, the voltage and current alarms will continue to alarm.
V1.6.1
-- Fixed bug where current and voltage values ​​could be incorrect due to TDC being too short.
V1.6.0
-- LoRaWAN Stack update to DR-LWS-007
-- Add AS923-2 band , AS923-4 band and MA869 band3.
-- Added AT+RODORET command
-- Use downlink type 02, 03, 05, A9 to change the status of RO DO, and the node will send the uplink immediately after the status is completed.
--Downlink type 05, A9 timeout adds 4 bytes of control
--Add AT+DECRYPT command
--Add AT+ GETSENSORVALUE command
--Add AT + DISFCNTCHECK command
--Add AT+DISMACANS command
--Add AT+RPL=5 command
v1.5.7
* OTAA RX2DR is set to 0 by default now for EU868
Image v1.5.7:
-- Compatible with 128K flash version ST chip
--Add AS923-2 band
Image v1.5.6:
--The RX2DR of EU868 frequency before entering the network was changed from 3 to 0.
--MCP3425 changed the material, and the software is compatible with the MCP3425 of two materials.
--Repair the sum value of the voltage and current acquisition definition is too small, causing the measured value to exceed half of the range Will overflow.
Image v1.5.4:
-- Upgrade LoRaWAN to DR-LWS-005 stack (http://www.dragino.com/downloads/downloads/LoRa_End_Node/DR-LWS/changelog)
-- Remove mod7
-- Change the implement of command AT+TRIG
Image v1.5.3:
-- Fix ADC sampling jitter bug
Image v1.5.2:
-- Fix DI1 and DI2 payload order
-- MOD1 can be used together with Interrupt mode now. If MOD1 want to use Interrupt mode, need to configure AT+TRIG first.
-- Send Interrupt packet first and then normal packet.
-- Interrupt can support rising and falling edge (only for MOD1, because other MOD use DI for counting).
----AT+TRIG=2,50,1 If there is a rising or falling signal >50ms on DI1. trigger Interrupt
----AT+TRIG=2,50,2 If there is a rising or falling signal >50ms on DI2. trigger Interrupt
Image v1.5.0
-- Add MOD6 , Similiar as MOD2, but the device will uplink on every interrupt.
Image v1.4.2
Ø	Update LoRaWAN stack to DR-LWS-003 (http://www.dragino.com/downloads/index.php?dir=LoRa_End_Node/DR-LWS/&file=changelog )
Ø	Fix DO / Relay state lose after reboot. Now After reboot, the DO/Relay will keep the same state as before.
Image v1.4.1
Ø	Fix watchdog bug. This bug cause some devices will un-stop reboot with the v1.4 firmware.
Image v1.4
Ø	Add hardware support for LT-22222-L
Ø	Update LoRaWAN stack to DR-LWS-002
Ø	Change to Class C by default
Ø	Add Software Watchdog
Ø	Re-construct Payload format, use the new decoder for v1.4.
Ø	Add Downlink command to pre-set count number
Ø	First bug for endless loop when TDC is too small
Image v1.3
Ø	Add clear counting feature via Downlink
Ø	Improve Downlink type code 0x03 to support control RO1 or RO2 separately.
Ø	Add Downlink type code 0x05
Ø	Add Downlink type code 0x07
Image v1.2
Ø	Add counting feature
Image v1.1
Ø	Voltage and Current reserve three decimal, previous is two
Ø	Can use any Fport for downlink
Ø	Add AT+CFG to print all settings
Ø	Fix current and voltage glith bug
My new firmware V1.7 23. Sept. 2025
fw-1-7
