Drop downlink data message: no payload when using downlink payload formatters
We are using a selfhosted ttn-stack-v3. Everything seems to be working well, except when we try to send a downlink using the Downlink payload formatters.
If we use the example of Downlink Encoder function from: TTN docs
We can push a download message via MQTT using
  {"downlinks": [{
    "f_port":15,
    "confirmed":false,
    "priority": "NORMAL",
    "frm_payload": "AQ=="
However, if we send the object:
  {"downlinks": [{
    "f_port":15,
    "confirmed":false,
    "payload_fields": {
    "led": true
Following the examples in TTN it should run the Downlink payload formatters, however we get this error code:
  "namespace": "pkg/applicationserver",
  "name": "no_payload",
  "message_format": "no payload",
  "code": 2
This error code is received also if we change the object “payload_fields” to any other, for example “fields_payloads”. This is why I think we are not using the right object.
· Which object must be sent to execute the Downlink payload formatters?
· Are the Downlink payload formatters a functionality not ready yet?
Thank you very much.
Solved
By deeply searching in the github I arrived till this page where there are a lot of examples, so I could find the right object was “decoded_payload”.
  {"downlinks": [{
    "f_port":15,
    "confirmed":false,
    "**decoded_payload**": {
    "led": true
It might be useful to give more visibility to these examples in the documentation
