Gateway for covering a large concrete building - best practices
Hi @LoRaTracker, the ones that I use are:
They are LoRaWAN Certified so I presume that they maintain compliance to the regional regulations at all times.
thanks for the link - my browse of the interwebs puts these at around $100 which seems a good price. It is the ‘triggered’ nature of the sensor which is important to us, and a GPS theft alarm makes a lot of sense as an application requiring that reduced latency.
A misunderstanding has crept in here somehow, for which I apologise.
The (university) research we’re doing involves applying machine learning to real-time data streams from dense sensor networks. Our deployment of sensors isn’t particularly unusual, but our aspiration to spot patterns in the spatio-temporal data in a timely fashion (e.g. seconds) is somewhat advanced. As you say, the system would need to learn what’s ‘normal’ for 10:30am (maybe class time) vs. 10am (maybe class changes) i.e. include both space and time in the pattern it’s recognizing, but mostly I should choose a less controversial hypothetical example…
Sounds like (if you forgive the pun) something that Edge Impulse does:
That would imply that the firmware in ‘LoRaWAN Certified’ nodes cannot be reprogramed, is that the case ?
Hi @LoRaTracker, my industrial experience is that if you need formal certification and commissioning then there will be limits on what the user can do without breaking the certification or commissioning.
In the case of the DigitalMatter GPS trackers the result appears to be:
  • The user cannot change the hardware.
  • The user cannot change the firmware, only install new [binary/closed-source] versions from the manufacturer.
  • The user can use a wide range of configuration options to change the device behaviour.
Most makers reject this compromise as they need open access to the hardware and firmware.
Most industrial users accept this compromise as they need to reduce risk.
Hi @CambridgeSensorNetwo
probably not the type of sensor that s going to be deployed in this case, but water meters typically have alarm logic (on top of configurable regular reporting intervals).
LoRaWAN certification would certainly be reassuring - but if you’ve built a device to a reference design using Semtech code, is it not a bit academic?
It strike me of more use is having (real) CE or FCC or similar certification so that you can use a MCU+Radio module in a product without having to get that element certified.
Hi @descartes
Good heavens man, are you trying to put lawyers out of work? It’s all about money, liability and risk - and that means lawyers.
Back to the OP and a “large concrete building”. The builder wants to buy a bunch of LoRaWAN stuff from Descartes Galactic Enterprises PLC (DGE). The project is being run by accountants and lawyers. They worry about catastrophes and ask “Who are these DGE people?” and “How big is their product liability insurance?”. DGE’s insurer says “You’ll need to prove this stuff is ok before we’ll insure it”.
DGE has a choice:
  1. Use an ISO 9000 QA system for development and manufacturing and get the devices formally certified. Result; insurance ok and probable sale. Risk rests with the insurer.
  2. Use DGE’s processes and issue a manufacturer certificate of conformity. Result; no insurance but possible sale if DGE has a good balance sheet. Risk rests with DGE.
  3. Tell the buyer that it’s all academic. Result; no sale.
Never going to exist - I stop as soon as the lawyers get involved - really. But Hotblack Desiato may …
I do take your point, but you may have missed the “a bit” bit. Certainly if someone is doing a project on the “lawyers are involved in the sales contract” scale, getting the certification is a minor expense. I’d still want to spend more money on testing the devices than on making them certifiable.
But for covering a large concrete building, we can start first week of Nov and evolve the project. Or we can spend a few months with some lawyers hammering out details. The first gets the job done whilst the project still has some point. The second sees the project become obsolete before the ink has been manufactured for the contract.
After 15 years of research, the lawyers have changed the classification of Descartes Galactic Enterprises PLC from “harmless” to “mostly harmless”.
thanks sebastianb, yes we’ve used 3 types of water meters, and these generally have an ‘alarm’ mode for tampering (i.e. sent as what we would call an ‘event’ rather than a periodic status reading) as well as sending their usage data periodically. FWIW I have not seen an example where the water meter sends a timely water-related ‘event’ such as (simplest) usage exceeding a threshold - I could imagine more sophisticated events like ‘usage not normal’. The meters are pretty impressive in terms of specification… waterproof with a 25-year (lifetime) battery life - sending 24 readings per day batched into a message every 12 hours.
The meters we’ve tested are from Diehl, Arad and Itron - I browsed around for links but most of these things are still in the development/evaluation stage (as understandably there’s a dependency on an available LoraWAN network which the water companies, in the main, don’t yet have).
There are two types of water meters, those measuring usage and those measuring presence. I guess the alarming kind meant by the OP is the second one, providing an alarm as soon as water is detected as that generally indicates a leak or other issue.
Ah, you speak wisely Obe-Wan… I wrongly assumed ‘Type 1’. (we have type 2 also but I took the ‘alarm’ aspect for granted…)
We have used Axioma water meters in a pilot project in a residential area.
(no affiliation or such, but reasonably happy with those)
They do not offer what i would call sophisticated events, but at least there are burst, leak and backflow alarms. Leak and burst thresholds are programmable, although i don’t think the company really expects the user to program these. But they are accessible in principle.
Else they resemble what you describe - we collect hourly readings batched into 3 (later 2) messages per day, with battery lifetimes forecast to be 16+ years (but of course critically depending on network quality / SF).
Hi @CambridgeSensorNetwo,
It’s probably also worth referring all the way back to the SNMPv1 architecture in the 1980s. This was intended to be “trap-directed polling”, i.e. the SNMP agent in the device sends an event notification (a “trap” in SNMP vocabulary) and the Network Management System (NMS) then used intelligence to increase polling to identify the cause of the event.
A number of LoRaWAN sensors seem to expect to be operated in the same way. The ones that I have worked with where this is relevant are ultrasonic range sensors when they are used for river-level warning. The logic goes something like this:
  1. The ultrasonic device periodically measures range. If the range has changed, the reading is sent as an uplink.
  2. If the central logic thinks that the new range measurement is a significant event then it sends a downlink to configure a higher rate of sampling and uplinking.
  3. Once the central logic no longer requires the higher rate of uplinking, it sends a downlink to return to the normal configuration for sampling and uplinking.
The ultrasonic range sensors that I have worked with (ELSYS and RadioBridge) do not have this logic built in to the sensor but they do seem to expect to be operated in this way over the network.
With SNMP the “intelligence” in the NMS to run trap-directed polling did not materialise at the time and so everyone ended up polling for everything all the time.
There are two problems with commanding a ramp-up of measurement rate in response to an anomalous event using a network like TTN:
  • if the uplink reporting the anomalous event does not make it through, there’s no way to command a change in rate, and the node has no way to know the message did not get through
  • if one sensor goes into anomalous mode, the immediate natural desire is to ramp up the sampling of other nearby sensors as well, but that cannot be done until they individually transmit their next successful uplink at base rate
Hi @cslorabox, you are, of course, entirely correct. This is the choice between dumb-sensor & central-computing vs. edge-computing.
In my career in oilfield automation both were used with very little in the middle. Most of the automation is dumb-sensor & central-computing. The main edge-computing exceptions were sensors for rotating equipment vibration analysis where only the Fourier Transform is uplinked and InfraRed image analysis looking for fires and equipment hotspots where only alerts are uplinked.
The unreliable nature of any radio network creates difficulties for both dumb-sensor and edge computing. They are just different difficulties.
Using LoRaWAN we deployed a number of Eolane “bob assistants” using Cartesiam AI for monitoring rotating equipment.
https://bobassistant.com/en/offer/
It’s good that LoRaWAN supports both, even if there are problems as you point out.
Actually I see it as more of a “design issues with LoRaWAN” issue in terms of the premium cost of downlinks in the protocol, especially in a class A only setting such as TTN.
“Edge” computing wouldn’t be able to do things like ramp up the reporting at nodes nearby one that gets an anomaly in order to be able to watch it spread in real time.
Though yes, for the single node interest, with the connectivity currently available, a tiny bit of “edge computing” in the sense of having a triggered ramp-up behavior in the node (which could be tuned by commands) could make sense. There’s a balance there, too - how much should one node ramp up, and how much should it consider that its neighbors may soon need to as well, making claiming more airtime not without issue.
Depending on many different design / environmental factors, mostly power & timing, nodes can switch to a mesh mode to inform those close by that things need to be escalated.
Makes more sense to do it with a scheduled multicast downlink; a mesh wouldn’t really work without creating clock synchronization for receive windows, and the network server does that best.
Not only does that avoid potential conflict between multiple nodes trying to autonomously transmit in their peeer’s receive window, it also means that the same periodic receive window can be used for maintainer or infrastructure originated messages.
The issue isn’t that these things can’t be done, but that LoRaWAN both as a matter of design and especially in the limited form implemented by TTN doesn’t do them.
