Gemtek Indoor Femto LoRaWAN Gateway - Anyone else using one?
After a small delay I am back to trying to get this to work on TTN. The unit runs OpenWrt Barrier Breaker which is no longer getting security updates from OpenWrt. Midnight Commander plays well with this unit (sudo apt install mc to install on Ubuntu). Using mc connect to the unit using the Shell Link dialog, enter giot-admin@192.168.55.1 and type password admin when asked. Using mc I copied nearly all the directories from the root file system to a folder on my machine for ease of poking around. I have found a file /usr/bin/lora_sw_arch_check.sh that looks interesting, here is a copy of the file.
#!/bin/sh
#1.check real files
#2.move file
#3.create symbolic link
DATA_MNT="/mnt/data"
REAL_LORA_DIR="/mnt/data/lora"
REAL_LORA_LIB="/mnt/data/lora/usr/lib"
REAL_LORA_BIN="/mnt/data/lora/usr/bin"
SOUR_LIB_PATH="/usr/lib"
SOUR_BIN_PATH="/usr/bin"
CHK_LIB="liblgwinfo.so"
APP_MNT_DIR="/mnt/data/lora/app"
REAL_LORA_DIR_BOOT0="$APP_MNT_DIR/boot0"
REAL_LORA_LIB_BOOT0="$APP_MNT_DIR/boot0/usr/lib"
REAL_LORA_BIN_BOOT0="$APP_MNT_DIR/boot0/usr/bin"
REAL_LORA_DIR_BOOT1="$APP_MNT_DIR/boot1"
REAL_LORA_LIB_BOOT1="$APP_MNT_DIR/boot1/usr/lib"
REAL_LORA_BIN_BOOT1="$APP_MNT_DIR/boot1/usr/bin"
REAL_LORA_DB="$APP_MNT_DIR/db"
LORA_CFG_BK_DIR="$DATA_MNT/lora_cfg_bk"
CFG_NAME="lora_WLRGFM-100.ini"
CFG_NAME_BK="BK-lora_WLRGFM-100.ini"
CFG_NAME_BOOT0="boot0_lora_WLRGFM-100.ini"
CFG_NAME_BOOT1="boot1_lora_WLRGFM-100.ini"
GJSON_NAME="global_conf_0.json"
GJSON_CFG_NAME_BOOT0="boot0_global_conf_0.json"
GJSON_CFG_NAME_BOOT1="boot1_global_conf_0.json"
LORA_CFG_DIR="/app/cfg"
LORA_EXE_PATH="/app/lora_pkg"
LORA_DB_DIR="/app/db"
LORA_DB="lora.db"
MNT_CFG="/mnt/data/config"
ROM_CFG_DIR="/rom/app/cfg"
ROM_LORA_EXE_PATH="/rom/app/lora_pkg"
FIRST_EXE="cfg_cmd"
LAST_EXE="util_tx_test"
SW_ARCH_LOG="/tmp/lora_sw_arch_chk_log"
CUR_BOOT_LINK=""
AUTO_W_MAC="0"
AUTO_W_MAC_CMD="$LORA_EXE_PATH/lora_mac_rw.sh w"
CFG_CMD_EXE="/app/lora_pkg/cfg_cmd"
CFG_CMD_EXE_SYNC="$CFG_CMD_EXE sync"
LORA_GW_EXE="pkt_forwarder"
LORA_SVR_EXE="loraserver"
APP_PRODTEST="/app/prodtest"
PWR_TAB="pwr_tables.ini"
sync_lora_cfg(){
	$CFG_CMD_EXE_SYNC
	sleep 2
create_dual_boot_dir()
	mkdir -p $REAL_LORA_DIR_BOOT0
	mkdir -p $REAL_LORA_LIB_BOOT0
	mkdir -p $REAL_LORA_BIN_BOOT0
	mkdir -p $REAL_LORA_DIR_BOOT1
	mkdir -p $REAL_LORA_LIB_BOOT1
	mkdir -p $REAL_LORA_BIN_BOOT1
rm_ng_link_in_boot()
	for CHK_BOOT in $REAL_LORA_DIR_BOOT0/cfg $REAL_LORA_DIR_BOOT0/lora_pkg $REAL_LORA_DIR_BOOT0/usr/bin $REAL_LORA_DIR_BOOT0/usr/lib \
		$REAL_LORA_DIR_BOOT1/cfg $REAL_LORA_DIR_BOOT1/lora_pkg $REAL_LORA_DIR_BOOT1/usr/bin $REAL_LORA_DIR_BOOT1/usr/lib
	do
		for FILE in $CHK_BOOT/*
		do
			file_name=`echo $FILE | awk -F "/app/" '{print$2}'`
			if [ -L "$FILE" ]; then
				echo "$FILE is link!"
				rm -f $FILE
			fi
		done
	done
new_lib_chk(){
	#Add new lib here to make sure they are included
	for lib in libringbuf.so libmosquitto.a libmqttcli.so libcommon.so
	do
		if [ -f $SOUR_LIB_PATH/$lib ]; then
			if [[ ! -f $REAL_LORA_LIB_BOOT0/$lib || ! -f $REAL_LORA_LIB_BOOT1/$lib ]]; then
				cp $SOUR_LIB_PATH/$lib $REAL_LORA_LIB_BOOT0
				cp $SOUR_LIB_PATH/$lib $REAL_LORA_LIB_BOOT1
			fi
		fi
	done
cp_and_chk_lora_lib()
	#Only when there is no lora lib in /mnt/data/lora/usr/lib
	if [[ -f $SOUR_LIB_PATH/$CHK_LIB && ! -f $REAL_LORA_LIB_BOOT0/$CHK_LIB || ! -f $REAL_LORA_LIB_BOOT1/$CHK_LIB ]]; then
		for lib in libcurls.so liblargedata.so liblgwinfo.so libringbuf.so liblorasql.so liblorautility.so libloglevel.so libmosquitto.a libmqttcli.so
		do
		done
	fi
	#Exist both in /usr/lib and /mnt/data
	if [[ -f $REAL_LORA_LIB_BOOT0/$CHK_LIB && -f $REAL_LORA_LIB_BOOT1/$CHK_LIB ]]; then
		new_lib_chk
		echo "[cp_and_chk_lora_lib]:LoRa libraries copy to /mnt/data DONE!"
		return 0
	else
		echo "[cp_and_chk_lora_lib]:LoRa library copy to /mnt/data FAILED!"
		return 1
	fi
get_lora_db(){
	mkdir -p $REAL_LORA_DB
	if [ ! -f $REAL_LORA_DB/$LORA_DB ] ; then
		if [ -f $ROM_LORA_EXE_PATH/$LORA_DB ]; then
			cp -f $ROM_LORA_EXE_PATH/* $REAL_LORA_DB
		else
			cp /rom/$LORA_DB_DIR/* $REAL_LORA_DB
		fi
	fi
create_lora_link()
	new_lib_chk
	get_lora_db
	if ls -al /app/lora_pkg | grep $LORA_SVR_EXE | grep boot1 > /dev/null; then
		LINK_BOOT="$REAL_LORA_DIR_BOOT1"
	else
		LINK_BOOT="$REAL_LORA_DIR_BOOT0"
	fi
	mkdir -p /app/lib /app/bin $LORA_DB_DIR
	#create symbolic link for /app/cfg
	for FILE in $LINK_BOOT/cfg/*
	do
		file_name=`echo $FILE| awk -F "cfg/" '{print$2}'`
		if [ ! -L "$FILE" ]; then
			ln -sf $FILE $LORA_CFG_DIR/$file_name
		fi
	done
	#create symbolic link for /app/lora_pkg
	for FILE in $LINK_BOOT/lora_pkg/*
	do
		file_name=`echo $FILE| awk -F "lora_pkg/" '{print$2}'`
			ln -sf $FILE $LORA_EXE_PATH/$file_name
		fi
	done
	#create symbolic link for /app/usr/lib
	for FILE in $LINK_BOOT/usr/lib/*
	do
		file_name=`echo $FILE| awk -F "usr/lib/" '{print$2}'`
			ln -sf $FILE /app/lib/$file_name
		fi
	done
	#create symbolic link for /app/db
	for FILE in $REAL_LORA_DB/*
	do
		file_name=`echo $FILE| awk -F "db/" '{print$2}'`
			ln -sf $FILE /app/db/$file_name
		fi
	done
	#create symbolic link for /app/usr/bin
	chk_and_create_cwmpc_link
	if [[ ! -L $LORA_CFG_DIR/$CFG_NAME || ! -L $LORA_EXE_PATH/$FIRST_EXE || ! -L $LORA_EXE_PATH/$LAST_EXE ]]; then
		echo "[$0]:Create LoRa link fail!"
		return 1
	else
		echo "[$0]:LoRa link is ready!"
		return 0
	fi
#Supposed we only wanna dual images
mv_and_create_link()
	#Keep LoRa CFG
	if [[ "$1" = "regen" || "$2" = "regen" ]];then
		mkdir -p $REAL_LORA_DIR_BOOT0/cfg
		mkdir -p $REAL_LORA_DIR_BOOT1/cfg
		cp -f $LORA_CFG_BK_DIR/$CFG_NAME_BOOT0 $REAL_LORA_DIR_BOOT0/cfg/$CFG_NAME
		cp -f $LORA_CFG_BK_DIR/$CFG_NAME_BOOT1 $REAL_LORA_DIR_BOOT1/cfg/$CFG_NAME
	fi
	#Actually, needless, since there is anothre check before this API...
	if [[ -L $LORA_EXE_PATH/$LORA_SVR_EXE && -L /app/lib/$CHK_LIB && -L $LORA_EXE_PATH/$FIRST_EXE \
		&& -L $LORA_CFG_DIR/$CFG_NAME && -L $LORA_EXE_PATH/$LAST_EXE && -L /app/bin/cwmpc \
		&& -f $REAL_LORA_DIR_BOOT0/lora_pkg/$FIRST_EXE && -f $REAL_LORA_DIR_BOOT1/lora_pkg/$FIRST_EXE \
		&& -f $REAL_LORA_DIR_BOOT0/cfg/$CFG_NAME && -f $REAL_LORA_DIR_BOOT1/cfg/$CFG_NAME \
		&& -f $REAL_LORA_BIN_BOOT0/cwmpc && -f $REAL_LORA_BIN_BOOT1/cwmpc ]]; then
		echo "[mv_and_create_link]:No need to re-construct!"
		chmod -R 777 $REAL_LORA_DIR_BOOT0/*
		chmod -R 777 $REAL_LORA_DIR_BOOT1/*
		return 0
	fi
	#Initial status
	if [[ ! -L $LORA_CFG_DIR/$CFG_NAME && -f $LORA_CFG_DIR/$CFG_NAME \
		&& -f $LORA_EXE_PATH/$FIRST_EXE && -f $LORA_EXE_PATH/$LAST_EXE ]]; then
		#At this point, there is lora real package in /app, but not in /mnt/data/lora/app/boot0 and /mnt/data/lora/app/boot1!
		if [[ ! -f $REAL_LORA_DIR_BOOT0/cfg/$CFG_NAME || ! -f $REAL_LORA_DIR_BOOT0/lora_pkg/$FIRST_EXE \
			|| ! -f $REAL_LORA_DIR_BOOT0/lora_pkg/$LAST_EXE || ! -f $REAL_LORA_DIR_BOOT1/cfg/$CFG_NAME \
			|| ! -f $REAL_LORA_DIR_BOOT1/lora_pkg/$FIRST_EXE || ! -f $REAL_LORA_DIR_BOOT1/lora_pkg/$LAST_EXE \
			|| ! -f $REAL_LORA_BIN_BOOT0/cwmpc || ! -f $REAL_LORA_BIN_BOOT1/cwmpc ]]; then
			cp -rf $LORA_CFG_DIR $REAL_LORA_DIR_BOOT0
			cp -rf $LORA_CFG_DIR $REAL_LORA_DIR_BOOT1
			#Keep LoRa CFG
			fi
			cp -rf $LORA_EXE_PATH $REAL_LORA_DIR_BOOT0
			cp -rf $LORA_EXE_PATH $REAL_LORA_DIR_BOOT1
		fi
		if [ "$1" = "recfg" ]; then
			cp $ROM_CFG_DIR/$CFG_NAME $REAL_LORA_DIR_BOOT0/cfg
			cp $ROM_CFG_DIR/$CFG_NAME $REAL_LORA_DIR_BOOT1/cfg
		fi
		cp_and_chk_lora_lib
		create_lora_link
		echo "[mv_and_create_link]:Creating and checking LoRa link done-01!"
	#Files in boot0, with no link(it could detect most links missing in /app/lora_pkg, /app/cfg, /app/bin, and /app/lib)
	elif [[ ! -L /app/bin/cwmpc || ! -L /app/lib/$CHK_LIB || ! -L $LORA_CFG_DIR/$CFG_NAME \
		|| ! -L $LORA_EXE_PATH/$FIRST_EXE || ! -L $LORA_EXE_PATH/$LAST_EXE ]] \
		&& [[ -f $REAL_LORA_DIR_BOOT0/cfg/$CFG_NAME && -f $REAL_LORA_DIR_BOOT0/lora_pkg/$LAST_EXE \
		&& -f $REAL_LORA_BIN_BOOT0/cwmpc && -f $REAL_LORA_LIB_BOOT0/$CHK_LIB ]]; then
		fi
		create_lora_link
		echo "[mv_and_create_link]:Creating and checking LoRa link done-02!"
	#No link or file in /app/cfg and boot
	elif [[ ! -f $LORA_CFG_DIR/$CFG_NAME && ! -L $LORA_CFG_DIR/$CFG_NAME \
		&& ! -f $LORA_EXE_PATH/$FIRST_EXE && ! -L $LORA_EXE_PATH/$FIRST_EXE \
		&& ! -f $LORA_EXE_PATH/$LAST_EXE && ! -L $LORA_EXE_PATH/$LAST_EXE \
		&& ! -f $REAL_LORA_DIR_BOOT0/cfg/$CFG_NAME && ! -f $REAL_LORA_DIR_BOOT1/cfg/$CFG_NAME ]]; then
		echo "[mv_and_create_link]:No good files or link found! Try to roll back from backup or default!"
		rm -rf $REAL_LORA_DIR_BOOT0/*
		rm -rf $REAL_LORA_DIR_BOOT1/*
		cp_and_chk_lora_lib
			|| ! -f $REAL_LORA_DIR_BOOT0/lora_pkg/$LAST_EXE || ! -f $REAL_LORA_BIN_BOOT0/cwmpc ]]; then
			cp -rf $ROM_CFG_DIR $REAL_LORA_DIR_BOOT0
			cp -rf $ROM_CFG_DIR $REAL_LORA_DIR_BOOT1
			cp -rf $ROM_LORA_EXE_PATH $REAL_LORA_DIR_BOOT0
			cp -rf $ROM_LORA_EXE_PATH $REAL_LORA_DIR_BOOT1
		fi
		#Try to find backup config, which may be povisioned
		if [[ -f "$MNT_CFG/$CFG_NAME" ]]; then
			cp -rf $MNT_CFG/$CFG_NAME $REAL_LORA_DIR_BOOT0/cfg
			cp -rf $MNT_CFG/$CFG_NAME $REAL_LORA_DIR_BOOT1/cfg
		fi
		create_lora_link
		if [ -f $LORA_EXE_PATH/lora_mac_rw.sh ]; then
			AUTO_W_MAC="1"
			echo "[mv_and_create_link]:Auto writing MAC..."
			$AUTO_W_MAC_CMD
		fi
		echo "[mv_and_create_link]:Creating and checking LoRa link done-3! You may have to re-provision!"
		echo "[mv_and_create_link]:Creating and checking LoRa link done-3! You may have to re-provision!" >> $SW_ARCH_LOG
	# No real files anywhere, but /rom
	elif [[ ! -f $REAL_LORA_DIR_BOOT0/cfg/$CFG_NAME && ! -f $REAL_LORA_DIR_BOOT1/cfg/$CFG_NAME ]] \
		|| [[ ! -f $REAL_LORA_BIN_BOOT0/cwmpc && ! -f $REAL_LORA_BIN_BOOT1/cwmpc ]] \
		|| [[ ! -f $REAL_LORA_DIR_BOOT0/lora_pkg/$FIRST_EXE && ! -f $REAL_LORA_DIR_BOOT1/lora_pkg/$FIRST_EXE ]] \
		|| [[ ! -f $REAL_LORA_DIR_BOOT0/lora_pkg/$LAST_EXE && ! -f $REAL_LORA_DIR_BOOT1/lora_pkg/$LAST_EXE ]] \
		|| [[ ! -f $REAL_LORA_DIR_BOOT0/lora_pkg/$LORA_SVR_EXE && ! -f $REAL_LORA_DIR_BOOT1/lora_pkg/$LORA_SVR_EXE ]] \
		|| [[ ! -f $REAL_LORA_DIR_BOOT0/lora_pkg/$LORA_GW_EXE && ! -f $REAL_LORA_DIR_BOOT1/lora_pkg/$LORA_GW_EXE ]]; then
			echo "[mv_and_create_link]:Wrong LoRa SW detected! Try to roll back from backup or default!"
			cp_and_chk_lora_lib
			fi
			create_lora_link
				AUTO_W_MAC="1"
				echo "[Urgent]: Auto writing MAC..."
				$AUTO_W_MAC_CMD
			fi
			echo "[mv_and_create_link]:Creating and checking LoRa link done-4! You may have to re-provision!"
			echo "[mv_and_create_link]:Creating and checking LoRa link done-4! You may have to re-provision!" >> $SW_ARCH_LOG
	else
		echo "[mv_and_create_link]:Case not definded!"
		echo "[mv_and_create_link]:Case not definded!" >> $SW_ARCH_LOG
		return 1
	fi
	return 0
chk_and_create_cwmpc_link()
	if [[ ! -f $REAL_LORA_BIN_BOOT0/cwmpc || ! -f $REAL_LORA_BIN_BOOT1/cwmpc ]]; then
	    cp $SOUR_BIN_PATH/cwmpc $REAL_LORA_BIN_BOOT0/cwmpc
		cp $SOUR_BIN_PATH/cwmpc $REAL_LORA_BIN_BOOT1/cwmpc
	fi
	if [ ! -L /app/bin/cwmpc ]; then
		echo "[INFO]:cwmpc link is not ready!"
		if ls -al /app/lora_pkg/$LORA_SVR_EXE | grep boot1 > /dev/null ; then
			ln -sf $REAL_LORA_BIN_BOOT1/cwmpc /app/bin/cwmpc
		else
			ln -sf $REAL_LORA_BIN_BOOT0/cwmpc /app/bin/cwmpc
		fi
		echo "[INFO]:Creating cwmpc link done!"
	fi
check_cur_link() {
	echo "[INFO]:Check current link..."
	CHK_BOOT_LINK=`ls -al /app/lora_pkg | grep "$LORA_SVR_EXE" | grep boot0`
	if [ "$CHK_BOOT_LINK" = "" ]; then
		CHK_BOOT_LINK=`ls -al /app/lora_pkg | grep "$LORA_SVR_EXE" | grep boot1`
			#echo "[INFO]:The dual LoRa boots are not ready!"
			return 2
		fi
		CUR_BOOT_LINK="boot1"
	else
		CUR_BOOT_LINK="boot0"
	fi
	echo "[INFO]:Check current link DONE!($CUR_BOOT_LINK)"
	if [ "$CUR_BOOT_LINK" = "boot1" ]; then
		return 1
	else
		return 0
	fi
chk_sw_status ()
	check_cur_link
	if [ "$?" = "2" ]; then
		if [[ -L "$LORA_EXE_PATH/$LORA_SVR_EXE" && -L "$LORA_EXE_PATH/$FIRST_EXE" && -L "$LORA_CFG_DIR/$CFG_NAME" \
		&& -L "$LORA_EXE_PATH/$LAST_EXE" && -f "$REAL_LORA_DIR/$LORA_EXE_PATH/$LORA_SVR_EXE" && ! -f "$REAL_LORA_DIR_BOOT0/lora_pkg/$LORA_SVR_EXE" ]]; then
			echo "[chk_sw_status]:The LoRa SW arch is the old style! LoRa link for single image!"
			return 1
		else
			echo "[chk_sw_status]:The LoRa SW arch needs to re-construct! LoRa link not ready!"
			return 2
		fi
	fi
	#The SW arch is ready only when 1. lora link is ready. 2. the files in current boot are ready
	if [[ -L "/app/bin/cwmpc" && -L "/app/lib/$CHK_LIB" && -L "$LORA_EXE_PATH/$LORA_SVR_EXE" && -L "$LORA_EXE_PATH/$FIRST_EXE" \
		&& -L "$LORA_CFG_DIR/$CFG_NAME" && -L "$LORA_EXE_PATH/$LAST_EXE" && -f "$APP_MNT_DIR/$CUR_BOOT_LINK/lora_pkg/$FIRST_EXE" \
		&& -f "$APP_MNT_DIR/$CUR_BOOT_LINK/lora_pkg/$LAST_EXE" && -f "$APP_MNT_DIR/$CUR_BOOT_LINK/lora_pkg/$LORA_SVR_EXE" \
		&& -f "$APP_MNT_DIR/$CUR_BOOT_LINK/cfg/$CFG_NAME" && -f "$APP_MNT_DIR/$CUR_BOOT_LINK/usr/bin/cwmpc" ]]; then
		#in case, extra files from OTA
		create_lora_link
		#echo "[chk_sw_status]:The LoRa SW arch is ready!"
		return 0
	#For single image, check if the link is old and no dual boots
	elif [[ -L "$LORA_EXE_PATH/$LORA_SVR_EXE" && -L "$LORA_EXE_PATH/$FIRST_EXE" && -L "$LORA_CFG_DIR/$CFG_NAME" \
		&& -L "$LORA_EXE_PATH/$LAST_EXE" && -f "$REAL_LORA_DIR/$LORA_EXE_PATH/$LORA_SVR_EXE" \
		echo "[chk_sw_status]:The LoRa SW arch is the old style!"
		return 1
	else
		echo "[chk_sw_status]:The LoRa SW arch needs to re-construct!"
		return 2
	fi
#Only for the old LORA SW architecture(single image)
roll_back_lora_sw_arch()
	cp -rf $REAL_LORA_DIR/app/cfg/* $LORA_CFG_DIR
	cp -rf $REAL_LORA_DIR/app/lora_pkg/* $LORA_EXE_PATH
	cp -rf $REAL_LORA_DIR/usr/bin/* /usr/bin
	cp -rf $REAL_LORA_DIR/usr/lib/* /usr/lib
	rm -rf $REAL_LORA_DIR/usr
print_help(){
	echo "Usage:"
	echo "$0 (Check LoRa link and file)"
	echo "$0 reset [recfg](Backup and reset LoRa SW arch + reboot.  With 'recfg', the config will be set to default with auto writing MAC)"
	echo "$0 regen [recfg] [keep_db] (Backup and reset LoRa SW arch + re-generate. With 'recfg', the config will be set to default with auto writing MAC; with 'keep_db': keep the lora.db)"
	echo "$0 r2d [main_r2d](Without backup and remove LoRa link and files to default, with 'main_r2d', the DUT will r2d as well)"
restart_conf_manager(){
	echo "[INFO]:Restart conf_manager..."
	if [ "$(pidof conf_manager)" != "" ];then
		kill -9 $(pidof conf_manager)
	fi
	/usr/bin/conf_manager &
	sleep 5
main_do()
	if [[ "$1" = "-h" || "$1" = "-help" ]]; then
		print_help
		return 1
	fi
	if [ "$(pidof lora_wdg.sh)" != "" ]; then
		/app/lora_pkg/loracmd.sh lora_wdg off
	fi
	if [[ "$(pidof $LORA_SVR_EXE)" != "" || "$(pidof $LORA_GW_EXE)" != "" ]]; then
		/app/lora_pkg/loracmd.sh lora_stop
	fi
	if [ "$(pidof cwmpc)" != "" ]; then
		killall cwmpc
	fi
	if [ "$(pidof mqtt_client_sub)" != "" ]; then
		killall mqtt_client_sub
	fi
	if [ "$1" = "r2d" ]; then
		echo "[INFO]:LoRa SW architecture is now r2d..."
		rm -rf /app
		rm -rf /mnt/data/lora
		cp -rf /rom/app /
		sync;sync
		if [ "$2" = "main_r2d" ]; then
			echo "[INFO]:You may have to re-bind LoRa MAC after rebooting..."
			sleep 2
			restore_default
		fi
		echo "LoRa packages R2D Done! Run restore_default to re-new."
		return 0
	fi
	if [ "$1" = "reset" ]; then
		echo "[INFO]:LoRa SW architecture is now resetting..."
		if [[ -d $REAL_LORA_DIR_BOOT0 && -d $REAL_LORA_DIR_BOOT1 ]]; then
			cp -rf $REAL_LORA_DIR_BOOT0/cfg/* $LORA_CFG_DIR/
			cp -rf $ROM_LORA_EXE_PATH/* $LORA_EXE_PATH/
		else
			cp -rf $REAL_LORA_DIR/cfg/* $LORA_CFG_DIR/
		fi
		echo "[INFO]:LoRa SW architecture reset DONE! Reboot in 5 sec (Ctrl+C to quit)..."
		sleep 5
		reboot
	fi
	if [ "$1" = "regen" ]; then
		echo "[INFO]:LoRa SW architecture is now re-generating..."
			echo "[INFO]:Keep LoRa power table..."
			if [ -f "$REAL_LORA_DIR_BOOT0/cfg/$PWR_TAB" ]; then
				cp $REAL_LORA_DIR_BOOT0/cfg/$PWR_TAB $DATA_MNT
			elif [ -L "$LORA_CFG_DIR/$PWR_TAB" ] ; then
				cp $LORA_CFG_DIR/$PWR_TAB $DATA_MNT
			elif [ -f $APP_PRODTEST/$PWR_TAB ] ; then
				cp $APP_PRODTEST/$PWR_TAB $DATA_MNT
			fi
			if [ ! -f "$DATA_MNT/$PWR_TAB" ]; then
				cp /rom/$LORA_CFG_DIR/$PWR_TAB $DATA_MNT
			fi
			cp -rf $ROM_CFG_DIR/* $LORA_CFG_DIR/
			#keep lora.db
			if [[ -f $REAL_LORA_DB/$LORA_DB && "$2" = "keep_db" || "$3" = "keep_db" ]];then
				cp -f $REAL_LORA_DB/$LORA_DB $DATA_MNT
				echo "[INFO]:Keep customized LoRa DB..."
			fi
			cp -rf /rom/$LORA_DB_DIR/* $LORA_DB_DIR/
			rm -f $LORA_CFG_DIR/$CFG_NAME_BK
			#Keep LoRa CFG
			if [ "$2" != "recfg" ];then
			   mkdir -p $LORA_CFG_BK_DIR
			   cp /mnt/data/lora/app/boot0/cfg/$CFG_NAME $LORA_CFG_BK_DIR/$CFG_NAME_BOOT0
			   cp /mnt/data/lora/app/boot1/cfg/$CFG_NAME $LORA_CFG_BK_DIR/$CFG_NAME_BOOT1
			   cp /mnt/data/lora/app/boot0/cfg/$GJSON_NAME $LORA_CFG_BK_DIR/$GJSON_CFG_NAME_BOOT0
			   cp /mnt/data/lora/app/boot1/cfg/$GJSON_NAME $LORA_CFG_BK_DIR/$GJSON_CFG_NAME_BOOT1
			fi
		else
		fi
		sync_lora_cfg
		echo "[INFO]:Remove old LoRa SW architecture DONE!"
	fi
	chk_sw_status
	rtn=$?
	if [ "$rtn" = "0" ]; then
		sync_lora_cfg
		return 0
	elif [ "$rtn" = "1" ]; then
		echo "[INFO]:Roll back LoRa SW architecture from old style to initial..."
	fi
	#For initial case, no lora package in /mnt/data and lora links are not ready.
	mv_and_create_link $2 $1
	if [ "$?" = "1" ]; then
		return 1
	fi
		if [[ "$2" = "keep_db" || "$3" = "keep_db" ]]; then
			mv $DATA_MNT/$LORA_DB $REAL_LORA_DB
			echo "[INFO]:Keep customized LoRa DB DONE."
		fi
		cp $DATA_MNT/$PWR_TAB $REAL_LORA_DIR_BOOT0/cfg
		cp $DATA_MNT/$PWR_TAB $REAL_LORA_DIR_BOOT1/cfg
		rm -f $DATA_MNT/$PWR_TAB
		echo "[INFO]:Keep LoRa power table DONE."
		#Keep LoRa CFG
			cp -f $LORA_CFG_BK_DIR/$GJSON_CFG_NAME_BOOT0 $REAL_LORA_DIR_BOOT0/cfg/$GJSON_NAME
			cp -f $LORA_CFG_BK_DIR/$GJSON_CFG_NAME_BOOT1 $REAL_LORA_DIR_BOOT1/cfg/$GJSON_NAME
			rm -rf $LORA_CFG_BK_DIR
		fi
	fi
	if [[ "$2" = "recfg" && -f $LORA_EXE_PATH/lora_mac_rw.sh && "$AUTO_W_MAC" != "1" ]]; then
		echo "[INFO]:Auto writing MAC..."
		$AUTO_W_MAC_CMD
	fi
	sync_lora_cfg
	sync;sync
	echo "[INFO]:LoRa program architecture is ready!"
	return 0
main_do $1 $2 $3
I tried running the file but get permision denied error. :frowning:
