I see the 05D1 in the āUPLINK payload (00 F9 8E 01 9C 10 05 D1)ā , but what is the exact value that this 05D1 should be converted into?
If itās linear (is it?), then subtract 4 and multiply by 400 / (20 - 4), so: subtract 4 and multiply the result by 25?
However, Iāve not used Cayenne so no idea if one can use TTN Console payload functions to do any of that before passing it along to Cayenne. Or if one can do this in Cayenne directly.
Also, as I donāt know what the hexadecimal 0x05D1 should convert into, I cannot tell if itās encoded LSB or MSB. (If it is sent as an integer, and is MSB, then 0x05D1 reads 1489 decimal, so maybe you first need to divide by 100 to get the mA reading? But if itās LSB then it reads 53509 decimal, and you might need to divide by 10000 to stay within 4 and 20 mA. And all that even assumes itās an integer to start with.)
ā¦and maybe āsuppressedā should read ārepresentedā or something, so this may imply you need to multiply by 1/200, so: divide by 200? (1489 decimal might be 7.4 mA then?)
But as it seems you already see some data on Cayenne, I guess you already decoded that hexadecimal 0x05D1 into some mA reading between decimal 4 and 20 mA, so maybe you really only need to do the scaling for values between 4 and 20?
function Decoder (bytes, port) {
// In Our case 00 F9 8E 01 9C 10 05 D1
//decoding last 2x bytes "05 D1"
// Unit miliamper, 2x bytes Value/200ma
// Decode whole 2xbytes to %, from % to bar
// Pressure sensor from 100...400bar (0% -> 100bat and 100% -> 400bar)
var pressure = (((bytes[6] << 8) | bytes [7]));
return pressure/200; // Division to 200 is required if the received value was really multiplied to 200ma
And converter should contains conversion calculations:
function Converter(decoded, port) {
// Merge, split or otherwise
// mutate decoded fields.
var conv_procents = (decoded-4)*100/16; //convert into procents (4ma-20ma)
var conv_bar = conv_procents*3+100; //convert to bar (100bar-400bar)
return conv_bar;
Attached us the user guide.
The last two bytes are input current expressed in 1/200ma as 2 bytes unsigned MSB int.
I woukd like to use the TTN Payload formats to decode and convert the current values to bar:
Can I use this code.
Shouldnāt the cayenne widget appears with pressure values instead of current?
Attached is the User guide of sensing Labs, concerned chapter is Uplink DATALOG FPort3.
I have used the TTN PAYLOAD FORMATS Decoder function to decode the last 2x bytes of Sensing Labs Uplink Data: 00 F9 8E 01 9C 10 05 D1
//decoding last 2x bytes ā05 D1ā
// Pressure sensor from 100ā¦400bar (0% -> 100bat and 100% -> 400bar)
var decoded = (((bytes[6] << 8) | bytes [7]));
var procent = ((decoded/200)-4)*100/16; //convert into procents (4ma-20ma)
var pressure = procent *3+1; //convert to bar (1bar-400bar)
return {
Barometer: pressure + ābarā,
Please correct me if I am wrong, should I now replace the last 4x bytes with Cayenne LPP payload format to have like: 05 73 05 D1 in order to get correct widget pressure in Cayenne Tool?
Hey,
Noob question. How did you get your SenLab sensors activated? I got mine registered, but it says in the instructions that after registration you are redirected to the new device where you can get your app key to activate the device. How do I go about doing that?
There is an online tool to easily encode/decode all āSensing-Labsā payloads: https://codecs.slconnect.click
It could be useful for TEST and quick check of some payloads.
if your Senlab is in BASIC mode (one measure per TX), HEX decode is possible (see official documentation)
if your Senlab is in DATALOG mode (up to 24 measures per TX), you need to use āSLcodecā to encode/decode your payloads.
SLCodec can be implemented as a REST API on your server, so you can send REST request from node-red (for example) to decode using SLCodecā¦
Thanks for your reply.
IĀ“m not that skilled in programming so I hoped for a copy/paste decoder script for TTNver3 for my SenlabH. For all our Elsys sensors the manufactorer have the script on their website. I canĀ“t see why Sensing Labs doeasnĀ“t have that.
Shouldnāt take long to post a script to a websiteā¦?
Do you have a timeline?
Can you return and update the Forum when done/available (and please - open access not behind some registartion/licence/paywall implementation (we are all building off open source and standing on the shoulders of giants in this sector and with LoRaWAN & TTN ;-), and many of us get asked to step in and help assist struggling users with devices we would not normally use or access so having the right tools available for that process is key to improving your users experience )
We are working on it ā¦ (to write and test the script in this format)
No, sorry.
I understand this and I will inform by a topic on TTN community and on this topic too, with sources and a kind of README, to make it easy for Sensing-Labs products users.
That sounds good. My Node-Red flow donĀ“t look specially nice right now with a lot of nodes. An ordinary Javascript as a decoder on TTN would be nice. Please post here as well when done. Then it would be a easy as some of your collegues in the business!
We are still working on it (āJavaScript libraryā to decode sensing-labs payload (all modes).
It will be available within end of November 2021.
Thank you for your patience.
