Heltec HT-M01 LoRa concentrator board for €100
Hello Jac,
Thank you for the hint!
I have now 5m+ and a wall between my device and my gateway - but the result is still the same: 3 messages per second (every 6 minutes) and all with CRC_FAIL. I had it running all night - but not a single message was successfully received :frowning:
Sep 1 09:12:40 RaspiZeroW lora_pkt_fwd[584]: # CRC_OK: 0.00%, CRC_FAIL: 100.00%, NO_CRC: 0.00%
Sep 1 09:18:40 RaspiZeroW lora_pkt_fwd[584]: # CRC_OK: 0.00%, CRC_FAIL: 100.00%, NO_CRC: 0.00%
Sep 1 09:24:40 RaspiZeroW lora_pkt_fwd[584]: # CRC_OK: 0.00%, CRC_FAIL: 100.00%, NO_CRC: 0.00%
I’m using the provided global_conf.json for EU868 (and local_conf.jason to overwrite the gateway-id and the server address, which obviously works as I see the gateway on TTN)
KR Bernd
Hi Bernd,
The interval between status messages should be 30 seconds, not 6 minutes. However this might just be a logging issue. Could you check the gateway consoles ‘Last Seen’ message for a couple of minutes? The value should not exceed 35 seconds.
Just to make sure, you are using a 868MHz model, not 443MHz?
Could you post a picture of your setup?
Best regards,
Jac
Hello Jac,
the update on last seen happens precisely every 2 minutes (3x2min = 6min … could be the explanation) in my local_conf.json I use this setting:
/* adjust the following parameters for your network */
“keepalive_interval”: 30,
“stat_interval”: 120,
“push_timeout_ms”: 100,
At least I ordered the 868MHz Version - but there is no info neither on the device nor on the packaging .
As Lora-Device I use a Mini-Ultra-Ultra-Pro3 with Radio from Rocketscream which works fine with TTN but never uses MY gateway but others (see metadata).
mini-ultra-pro-v3-ttn
mini-ultra-pro-v3-metadata
KR Bernd
Hello Jac,
after disassembling the device it turned out that I’ve received the 433MHZ (although I clearly ordered the 868 MHZ version) version as it contains 2 SX1255 (instead of SX1257) :frowning:
Thank you for your support!
KR Bernd
Hi Bernd,
That is disappointing. Hopefully the vendor will solve this issue soon.
Best regards,
Jac
Hi
One question. Do you receive packets from radio 0? Because I have one TTGO and one Heltec ESP32 and the gateway only receives in radio 1, it seems the channels in radio 0 are not listening:
*** Packet Forwarder for Lora PicoCell Gateway ***
Version: 0.1.0
*** Lora concentrator HAL library version info ***
Version: 0.2.2;
*** MCU FW version for LoRa PicoCell Gateway ***
Version: 0x010A0006
INFO: Little endian host
INFO: found global configuration file global_conf.json, parsing it
INFO: global_conf.json does contain a JSON object named SX1301_conf, parsing SX1301 parameters
INFO: lorawan_public 1, clksrc 1
INFO: antenna_gain 0 dBi
INFO: Configuring TX LUT with 16 indexes
INFO: radio 0 enabled (type SX1257), center frequency 867500000, RSSI offset -164.000000, tx enabled 1
INFO: radio 1 enabled (type SX1257), center frequency 868500000, RSSI offset -164.000000, tx enabled 0
INFO: Lora multi-SF channel 0>  radio 1, IF -400000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 1>  radio 1, IF -200000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 2>  radio 1, IF 0 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 3>  radio 0, IF -400000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 4>  radio 0, IF -200000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 5>  radio 0, IF 0 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 6>  radio 0, IF 200000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 7>  radio 0, IF 400000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora std channel> radio 1, IF -200000 Hz, 250000 Hz bw, SF 7
INFO: FSK channel> radio 1, IF 300000 Hz, 125000 Hz bw, 50000 bps datarate
INFO: global_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
INFO: gateway MAC address is configured to AA555A0000240409
INFO: server hostname or IP address is configured to "localhost"
INFO: upstream port is configured to "1680"
INFO: downstream port is configured to "1680"
INFO: downstream keep-alive interval is configured to 10 seconds
INFO: statistics display interval is configured to 30 seconds
INFO: upstream PUSH_DATA time-out is configured to 100 ms
INFO: packets received with a valid CRC will be forwarded
INFO: packets received with a CRC error will NOT be forwarded
INFO: packets received with no CRC will NOT be forwarded
INFO: found local configuration file local_conf.json, parsing it
INFO: redefined parameters will overwrite global parameters
INFO: local_conf.json does not contain a JSON object named SX1301_conf
INFO: local_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
INFO: gateway MAC address is configured to <hidden>
INFO: server hostname or IP address is configured to "router.eu.thethings.network"
INFO: upstream port is configured to "1700"
INFO: downstream port is configured to "1700"
INFO: [down] PULL_ACK received in 51 ms
INFO: [down] PULL_ACK received in 56 ms
INFO: [down] PULL_ACK received in 58 ms
INFO: Received pkt from mote: 26011ACE (fcnt=84Preformatted text0)
JSON up: {"rxpk":[{"tmst":25992764,"chan":0,"rfch":1,"freq":868.100000,"stat":1,"modu":"LORA","datr":"SF7BW125","codr":"4/5","lsnr":8.8,"rssi":-41,"size":16,"data":"QM4aASaASAMBrLDMhzv+mw=="}]}
INFO: [up] PUSH_ACK received in 57 ms
##### 2018-11-01 00:31:03 GMT #####
### [UPSTREAM] ###
# RF packets received by concentrator: 3
# CRC_OK: 33.33%, CRC_FAIL: 66.67%, NO_CRC: 0.00%
# RF packets forwarded: 1 (16 bytes)
# PUSH_DATA datagrams sent: 1 (196 bytes)
# PUSH_DATA acknowledged: 100.00%
### [DOWNSTREAM] ###
# PULL_DATA sent: 3 (100.00% acknowledged)
# TX errors: 0
### [JIT] ###
src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
### [GPS] ###
# GPS sync is disabled
##### END #####
JSON up: {"stat":{"time":"2018-11-01 00:31:03 GMT","rxnb":3,"rxok":1,"rxfw":1,"ackr":100.0,"dwnb":0,"txnb":0}}
INFO: [up] PUSH_ACK received in 55 ms
INFO: [down] PULL_ACK received in 57 ms
INFO: Received pkt from mote: 26011ACE (fcnt=841)
JSON up: {"rxpk":[{"tmst":38228572,"chan":1,"rfch":1,"freq":868.300000,"stat":1,"modu":"LORA","datr":"SF7BW125","codr":"4/5","lsnr":8.2,"rssi":-65,"size":16,"data":"QM4aASaASQMB+Ippj4C6DA=="}]}
INFO: [up] PUSH_ACK received in 52 ms
INFO: [down] PULL_ACK received in 55 ms
INFO: Received pkt from mote: 26011ACE (fcnt=842)
JSON up: {"rxpk":[{"tmst":50464316,"chan":2,"rfch":1,"freq":868.500000,"stat":1,"modu":"LORA","datr":"SF7BW125","codr":"4/5","lsnr":5.5,"rssi":-64,"size":16,"data":"QM4aASaASgMByGJhP4rY7g=="}]}
INFO: [up] PUSH_ACK received in 68 ms
INFO: host/sx1301 time offset=(1541032230s:361669µs) - drift=2522µs
##### 2018-11-01 00:31:33 GMT #####
### [UPSTREAM] ###
# RF packets received by concentrator: 4
# CRC_OK: 50.00%, CRC_FAIL: 50.00%, NO_CRC: 0.00%
# RF packets forwarded: 2 (32 bytes)
# PUSH_DATA datagrams sent: 3 (505 bytes)
# TX errors: 0
### [JIT] ###
### [GPS] ###
##### END #####
JSON up: {"stat":{"time":"2018-11-01 00:31:33 GMT","rxnb":4,"rxok":2,"rxfw":2,"ackr":100.0,"dwnb":0,"txnb":0}}
INFO: [down] PULL_ACK received in 54 ms
Since here the log doesn’t show any activity until the modules start to send in frequencies associated to radio 1.
I’m using it by usb, but I think there is not difference if I connect it by SPI with a Raspberry Pi Zero W.
What can I do?
I’ve just added a tutorial to my blog for this gateway: https://robotzero.one/heltec-lora-gateway-things-network/
Maybe helpful to someone. Let me know if there’s any errors.
I’ll be setting this up as a permanent gateway in the next few weeks and run some range tests.
Did someone compared the receive sensitivity to other gateways? I think the measured 15,5dBm Output power are enough if we look at our local laws…
25 posts were split to a new topic: PCI/mini PCIe concentrator boards
I did a quick test today with this and the Heltec Lora 32. Connected fine at 2.9km. I’ll try some longer distances when I get my breath back…
:rofl:
Did you get your breath back?
I’m wondering about treating myself to one of these as an upgrade to the single channel test gateways I have been playing with, so I am following your experiments with interest. I was looking at a more conventional RPI + RAK831 setup, but this small unit would be a much easier unit to mount on a mast.
Many thanks for your efforts so far. I have spent the week cycling about with a TTNmapper node taped on the back on my bike to see how my gateways are working…
ha! yeah… but now it’s really hot here so I don’t want to be walking up any mountains.
I need to find some way of adding a remote antennae and mounting the unit and Pi Zero in the shade somehow.
So LoRaWAN is like fitness :thinking: interesting :wink:
Has anyone managed to get this gateway (Heltec’s HT-M01) working over SPI with Raspberry PI Zero and that adapter board from Heltec?
For me, it works with no problem using USB but when I try to set it up for SPI the Packet Forwarder just won’t start, “Fails to start the concentrator”.
Any help or advice would be greatly appreciated :slight_smile:
don’t forget to enable SPI if you using raspi
Hi mertani_gateway,
I’m following this instructions for setting up the gateway, I’m sure the SPI is enabled in the raspi. This is the error I’m getting when trying to start the packet forwarder:
pi@raspberrypi:~/lora/packet_forwarder/lora_pkt_fwd $ ./lora_pkt_fwd start global_conf.json
**** Beacon Packet Forwarder for Lora Gateway ****
Version: 4.0.1
**** Lora concentrator HAL library version info ****
Version: 5.0.1;
INFO: no configuration for LBT
INFO: radio 0 enabled (type SX1257), center frequency 902700000, RSSI offset -164.000000, tx enabled 1, tx_notch_freq 0
INFO: radio 1 enabled (type SX1257), center frequency 903400000, RSSI offset -164.000000, tx enabled 0, tx_notch_freq 0
INFO: Lora multi-SF channel 0> radio 0, IF -400000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 1> radio 0, IF -200000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 2> radio 0, IF 0 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 3> radio 0, IF 200000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 4> radio 1, IF -300000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 5> radio 1, IF -100000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 6> radio 1, IF 100000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 7> radio 1, IF 300000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora std channel> radio 0, IF 300000 Hz, 500000 Hz bw, SF 8
INFO: FSK channel 8 disabled
INFO: gateway MAC address is configured to B827EBFFFE4A0059
INFO: server hostname or IP address is configured to “router.us.thethings.network”
INFO: upstream port is configured to “1700”
INFO: downstream port is configured to “1700”
Have you designated the correct pin for the concentrator reset line, also you may find success setting SPI bus speed/CPU config (250Mhz if I recall) - search the forum for similar issues with other concentrator boards (usually RAK or iMST) and how others solved. The Reset PIN mapping used by various concentrator boards and any associated interposer/interface boards is generally the big gotcha at least for this failed to start conc error! :wink:
Good luck!
Oke . Then , please check your global_conf.json file . I think there is someting miss or wrong.
try to turn on the SPI interface: sudo raspi-config then select “5”, then “P4”. Select “yes” and try to start the ./lora_pkt_fwd start global_conf.json again. Hope this works for you.
