You should not filter. Those devices might be from another TTN user that still needs to migrate their application (and might now be missing data because you migrated your gateways early, the TTN console explicitly instructs to migrate applications/devices, not gateways) and once they migrated their data should not be filtered.
Those messages are not errors. It is merely an informational statement that the community network has no destination for that device address (combined with active Network Session Keys). That message can be useful when debugging connection issues with devices.
In any case, your gateway does not know which devices are known within TTN, it shouldnât. The gateway should just pass all traffic to the backend and the backend can decide what needs processing and what can be ignored.
No - way too early to move as discussed & linked all over TTN site & forum - v2 devices can only be heard by v2 gateways. So anyone who has/had a v2 device being picked up by your gateways (the TTN deal being they are community accessible) has either one less gateway or, depending on location/coverage, has NO gateways to hear them.
This does mean - v3 Gateways are at least not needed currently while not all devices are moved to TTN v3 devices and applications?
Hmmm ⌠but ⌠wouldnât be moving the gateways to v3 will FORCE the device owners to move forward to v3 also?
I am asking this because - I always ask myself why it took such a long time to move e.g. from IPv4 to IPv6 even that is an easy path. As long as old things are supported - I know a lot of admins / owners wonât spent their time in upgrading. Thatâs a pity from my point of view!
At least - the TTN v3 gateway console is an improvement for us as well.
Yes - and sorry - but thatâs what most people will push and start to move forward âŚ
Got that
BUT then - for what and why has TTN enabled the configuration of TTN v3 Gateways. If they wonât enabling the migration path - they just would had left that option disabled?
Until the bulk of people have wrapped their heads around the logistics and then actually done the move, we are recommending people leave their gateways until v2 goes read only. They will carry on working but at that point it will encourage people to transition any remaining v2 devices.
Yes, if they have the time & capability - they may not have finished planning & testing. Forcing them isnât helpful at this point in time.
So incredibly easy that all my corporate (national retailers with hundreds of stores, so really big, well funded, well resourced) clients are running their office networks on IPv6 - NOT.
Thatâs subject to debate - this topic started because to some extent, it totally isnât. Others have noted & requested filters to keep the detail manageable.
For one thing, because features need real world testing.
Some may spin up additional gateways in the new system without moving their existing ones.
But itâs ultimately up to you if you want to move your gateway to V3 now; people have expressed their personal opinions against it, and given the reasons they reached that opinion, but in the end it is your choice.
Just like no one can tell you that you canât unplug your gateway and put it in the closet.
Another good option to test someday - at least the Dragino gateway firmware here in our local office is aweful
Thanks to all the personal opinions - I like to be a fair player and from that point of view we will discuss internally to spin up an additional v2 gateway within the next days.
TTN forces people to move later this year by making V2 read only and later by shutting it down. In the mean time you donât know how much work is involved for others to move. For instance V3 does not have MyDevices Cayenne support. Anyone using that needs to find a new solution and migrate. That isnât a trivial exercise if you donât want to start paying many $$ a month.
Thatâs why in our community we agreed to move gateways as late as possible. New gateways are added on V3 for additional coverage (not that youâre able to show that because both TTNmapper and the main TTN websites map are not V3 ready yet).
That same advice is all over the forum as well⌠Not because we like it that way, but because migration is not trivial for everyone. (Some nodes need to be reset manually and in this COVID-19 world getting to them isnât trivial either)
Off topic, but you you can build your own from source thus fixing whatever you dislike.
(At least assuming youâre talking about one of the boxes that is an actual concentrator based gateway - the non-gateways things with one or two node radios may share the OS build but hardware problems like that canât be fixed in software)
when we setup an additional Gateway for TTN v2 network and locate this right beneath the other v3 gateway, will that cause conflicts in radio communications? I have no experiences currently with two gateways directly in the same area.
Neither gateway will practically be able to receive while the other is transmitting, but thatâs basically a given.
The more interesting question would be if the transmissions of one gateway could be strong enough to actually damage the other. Thatâs a bit uncertain - I know people who put gateways closer together than Iâd like, they havenât seen a problem, butâŚ
Provided they are not sat next to each other, with antennas in exactly the same plane/alignment and you are not pushing to the limit of range you should be ok for practical day to day use. GWs are somewhat able to ignore each other by design and implementation but close proximity operation does raise the local noise floor and reduces sensitivity a little in real world use and if very close (say <2-3m without intervening absorber) can risk saturating each otherâs front ends when txâing. I often have 6-12 GWâs mix of indoor & outdoor running in a small volume roughly 15 x 35 x 20m, though with some intervening walls, glazing and floors, depending on what I am testing/commissioning and burning in at any given time. If you can ensure several meters apart preferably with an absorbers such as a wall or two between them that helps as does offsetting vertically. Directly above/below is good as the ant propagation is usually poorer in that direction. If you are running with feeder cables of any decent length and quality rather than directly attached that helps to have gw main units that in close proximity (within a few metres) effectively better isolated by ensuring the antennas can then be further spaced apart and offset vertically. I have 3 GWâs placed in the roof space at the moment on long term tests, one with feed to an external ant and the other two mounted under roof but, one direct attached ant and the other into a few metres of feeder cable, and with several m separation and also offset wrt the external ant. The external unit is slightly higher and being external has the greatest range/sensitivity, but the two internally mounted have similar performance, and allowing for the through roof losses are not too far behind the external unit. More importantly they have broadly the same real world coverage tested out to 4-9+km depending on direction as main limit is the local topology and line off site issues caused by being on a hill on the edge of the Thames Valley⌠I canât see 20 or 30km from here so am never going to push these units to extremes (unless servicing a high altitude balloon or a plane out of Heathrow! )
