I am conveniently receiving data on my application(Console), and I have set up an HTTP Integration to one of my webhosts. Iâve kept Auth blank, and put a optional custom header âContent-Typeâ:âapplication/jsonâ. But i receive absolutely NO post requests. Iâve also configured my site to send me an SMS every time a POST request is made(yes, I tried with a post request using Postman and it does work). I also tried using a temporary http endpoint like Requestbin, but to no avail. Help? Is the HTTP Integration service currently down??
HTTP Integration seems to be working now (still shaky, though, sometimes goes down without any warning), but it still takes close to 30-40 seconds to forward data (make the HTTP request)
I did an HTTP integration to requestb.in. If Iâm simulating an upload it works. If i get data from my device it does not work. Any suggestion what might be the difference? I see in the console for the simulated package there is no metadata. Might it be this?
is there a way to see the return code from calls from the HTTP integration?
Return codes are set by your own server, right? (Things like 200 OK and 500 Internal Server Error?)
But maybe the MQTT events topic can show some details; https://www.thethingsnetwork.org/docs/applications/mqtt/api.html#error-events
Thanks that was a very good hint. I found out that I get an HTTP 400 Bad request
The json arrived at my server looks like this
052.169.225.045.60130-192.168.001.137.08080: POST /api/v1/ACxG-redacted-fL0/telemetry HTTP/1.1 Host: tron.internet-box.ch:89 User-Agent: http-ttn/2.6.0 Content-Length: 708 Content-Type: application/json Accept-Encoding: gzip {"app_id":"bubble_logger","dev_id":"heltec","hardware_serial":"0123456789AABBCC","port":1,"counter":291,"payload_raw":"Aqc=","payload_fields":{"bubbles":679},"metadata":{"time":"2018-11-13T20:25:35.810596656Z","frequency":868.5,"modulation":"LORA","data_rate":"SF11BW125","coding_rate":"4/5","gateways":[{"gtw_id":"eui-b827ebfffe97f686","timestamp":3645317348,"time":"2018-11-13T20:25:35.792731Z","channel":2,"rssi":-115,"snr":-13.5,"rf_chain":1,"latitude":47.379448,"longitude":8.548805,"altitude":504,"location_source":"registry"}]},"downlink_url":"https://integrations.thethingsnetwork.org/ttn-eu/api/v2/down/bubble_logger/thingsboard_local?key=ttn-account-v2.1UQ-redacted-P7o"} 192.168.001.137.08080-052.169.225.045.60130: HTTP/1.1 400 X-Content-Type-Options: nosniff X-XSS-Protection: 1; mode=block Cache-Control: no-cache, no-store, max-age=0, must-revalidate Pragma: no-cache Expires: 0 Content-Length: 0 Date: Tue, 13 Nov 2018 20:25:36 GMT Connection: close
I tried to with postman to modify the content of the POST and as soon as I have a nested json like the metadata and gateway than it fails. If I just send some key:value pairs it is working
like
192.168.001.102.53806-192.168.001.137.08080: POST /api/v1/ACx-redacted-fL0/telemetry?= HTTP/1.1
cache-control: no-cache
Postman-Token: 892ee8a4-9b13-442f-9899-e49ffbd282b4
User-Agent: PostmanRuntime/7.4.0
Accept: /
Host: 192.168.1.137:8080
accept-encoding: gzip, deflate
content-length: 347
Connection: keep-alive{
âapp_idâ:âbubble_loggerâ,
âdev_idâ:âheltecâ,
âhardware_serialâ:â0123456789AABBCCâ,
âportâ:1,
âcounterâ:278,
âpayload_rawâ:âAsQ=â,
âbubblesâ:555,
âdownlink_urlâ:âhttps://integrations.thethingsnetwork.org/ttn-eu/api/v2/down/bubble_logger/thingsboard_local?key=ttn-account-v2.1UQ-redacted-7oâ
192.168.001.137.08080-192.168.001.102.53806: HTTP/1.1 200
Pragma: no-cache
Expires: 0
Content-Length: 0
Date: Tue, 13 Nov 2018 20:29:19 GMT
The receiving server is a Thingsboard.io application running on a raspberry pi. Any Idea why the nested json tags are causing troubles?
THX Sergio
Weâd need to see the code thatâs parsing/interpreting the JSON to make any guess. Note that gateways
in metadata
is an array of one or more gateways. But any JSON parser should be able to handle that.
However, you also wrote:
I donât think requestb.in is doing any parsing/interpretation, but instead itâs just showing the payload? If true, and if showing that payload already fails for true device uplinks, then something odd is going onâŚ
Beware that you posted secrets above. Iâve now redacted those, but once everything is running you might want to change the secrets.
actually I see in the thingsboard documentation that the do not allow nested json only on specific case with ts and values, and I think it also worked with the in the console simulated upload because it does not have the nested gateway block. Any chance to be able to format the json with the payload funktions in ttn?
docu from Thingsboard
The simplest supported data formats are:
{"key1":"value1", "key2":"value2"}
or
[{"key1":"value1"}, {"key2":"value2"}]
Please note that in this case, the server-side timestamp will be assigned to uploaded data!
In case your device is able to get the client-side timestamp, you can use following format:
{"ts":1451649600512, "values":{"key1":"value1", "key2":"value2"}}
Okay, so no problems in requestb.in then?
Indeed, not every third party website will understand the data that the HTTP Integration sends. Using payload functions only affects the value of payload_fields
; the rest of the JSON will not change.
But it seems youâre those whoâre using the Professional Edition are lucky; see (todayâs last post at) Has someone linked TTN with Thingsboard?
funny I just managed to get my payload with node-red to thingsboard without professional edition. Thank you
