Well… I think it’s kosher:
Thats the whole point about fakes, they make them look kosher.
Anyway, the forum software is the case of the confusion, it is omitting the strings of commas that are normally present in a NMEA sentence without a fix, below is two copies of a sentence from one on my GPSs, the first is a straight copy to the forum, the second I deleberatly put spaces between the groups of commas;
$GPGGA,091258.00,0,00,99.99,*61
$GPGGA,091258.00, , , , ,0,00,99.99, , , , , ,*61
One wonders what other characters the forum software strips out …
Hmm. I did have it running and getting a fix with cgps and gpsd properly under raspbian. Checked that before I moved on to trying to get it working with the concentrator.
Still could be a formatting issue I suppose…
May-be put this kind of information in a code block? [ code ] … [ /code ] (skip the spaces)
Just some comma's without spaces
Idem with spaces
What do you mean ‘forum software’?
Something’s seriously wrong… syslog and daemon.log are filling up and /var is running out of space.
Could you try mp_pkt_fwd? (Easiest is resin.io.) There have been a couple of updates to low level libraries after the version you are using that are included in MP forwarder.
OK, some progress.
First of all there was a dry joint on my TX wiring Fixing that means I get reliable data from the module.
In case I’d screwed something up at system level, I did a clean install of Stretch and got the GPS module set up and working first. That gets me reliable position information on ttyAMA0. Yay.
$GPRMC,225036.000,A,51xx.xxxx,N,000xx.xx,W,0.00,200.38,090318,A*71
I then installed and configured the LoRa software per the ttn-zh wiki (https://github.com/ttn-zh/ic880a-gateway/wiki). Everything is up and running and the concentrator appears to be seeing the GPS:
Mar 9 22:47:09 ttn-dev-gw ttn-gateway[538]: INFO: Reference longitude is configured to 0.000000 deg
Mar 9 22:47:09 ttn-dev-gw ttn-gateway[538]: INFO: Reference altitude is configured to 0 meters
Mar 9 22:47:09 ttn-dev-gw ttn-gateway[538]: INFO: GPS is enabled
I say ‘appears’… it isn’t throwing any errors about opening the serial port. I’m slightly suspicious that I can still cat /ttyAMA0 in another shell. However:
Mar 9 22:49:32 ttn-dev-gw ttn-gateway[538]: ### [GPS] ###
Mar 9 22:49:32 ttn-dev-gw ttn-gateway[538]: # Invalid gps time reference (age: 1520635659 sec)
Mar 9 22:49:32 ttn-dev-gw ttn-gateway[538]: # Manual GPS coordinates: latitude 0.00000, longitude 0.00000, altitude 0 m
Mar 9 22:49:32 ttn-dev-gw ttn-gateway[538]: ##### END #####
I’m getting this despite the fact that the timestamp on each sentence format is correct. I’ve also patched the PPS output from the GPS module to pin 19 on the iC880a concentrator.
I’m prepared to look at the resin option, but it feels like I’m so close that I’d really like to get it working as it stands…!
Mark
PS: fun fact - another problem I found was that with the module and antenna in the case, it doesn’t get a fix; with them out of the case, it works. The module (not antenna) was sandwiched between Raspi and concentrator - is it possible RFI was interfering with the signal? It’s still indoors by the way.
PS - I know the time ref in the log is unix 1970 default date.
GPSs are highly marginal indoors, just about anything could make reception worse, or indeed better.
I’ll see how it performs in the final location. Assuming I can get it working!
I built a new instance with resin and it all works first time. Still annoyed that I couldn’t get it working by the traditional method, but resin FTW - first time I’ve sued this tool, I love it.
One thing which is probably a simple one:
11.03.18 12:56:03 (+0000) main # Valid gps time reference (age: 2 sec)
11.03.18 12:56:03 (+0000) main # System GPS coordinates: latitude 51.4xxx, longitude -0.xxx, altitude 56 m
Is there a way to get the gateway to automatically update its position in the console? It’s keeping whatever lat/long I set there and ignoring the GPS co-ords.
You could try clearing the location information in the settings for you gateway. (Red cross below the coordinates.) However, this is just a guess. If you want to know for sure you will have to ask one of the TTN developers.
OK, thanks.
One last thing - I got it working using your RAK831 instructions. Is there a guide to getting the TTN gateway connector setup? I’d like to benefit from the enhanced security and efficiency.
If you have supplied the GW_ID and GW_KEY to resin you are using the (build into MP forwarder) TTN gateway connector setup.
Yup, I’ve since worked that out. I haven’t sued Docker before either. Resin is FUN
Gateways aren’t showing as Connected with a green dot tho - still blue ones…
Have you created a new gateway registration without setting ‘legacy’?
Yup. The instructions are clear not to use the Semtech legacy tickbox.
I don’t know if this is relevant:
11.03.18 20:49:04 (+0000) main ### [ CONNECTIONS ] ###
11.03.18 20:49:04 (+0000) main # bridge.eu.thethings.network: Connected
11.03.18 20:49:04 (+0000) main # Semtech status report send.
11.03.18 20:49:04 (+0000) main ##### END #####
It says connected, that matters. Ignore the color of the dot. Even my TTN gateway has a blue dot.
