I reversed the bytes of APPKEY, but it doesn’t work. I was reanding about endian-ness. Are you trying to tell me that I should enter my numbers without inverting because APPKEY is in Big Endian, and DEVEUI and APPEUI are on little endian?
No, I was pretty clear that the AppKey is not end sensitive. Whereas the EUI’s are endian specific which is why you need to check the docs. So pretty much the reverse of your interpretation.
If you are using the ancient code base of the IBM LMIC of 2016 it may not be clear. More recent versions are clear. More recent versions are far more compatible with pretty much everything LoRaWAN so you may get the code base at the top of this thread working, it wasn’t a good choice, which is why I directed you to LMIC-node which has gold-plated documentation with gift-wrapping.
In the meanwhile, if you’ve had your EUI’s MSB, try them LSB. DO NOT try to mix & match - it’s either BOTH MSB or BOTH LSB.
Referencing your duplicate post, this is by design - you are likely recycling the DevNonce and duplicates are rejected by the LNS. For development work you can turn this off in the console or you can make your version aligned with LMIC which does NOT support v1.0.4 incrementing Nonces.
Edit 11 Jan: failed to include NOT in the last sentence - LMIC doesn’t support incrementing DevNonces as required for v1.0.4 so you MUST use v1.0.3
actually i need to have deep undrestand of concept of lorawan
but i only study “the thing network” document could you give me road map to have better undrestand of it
i didnt found anything with this title in forum does it exist?
That will guarantee it gets re-used…which is the problem. You want a value (preferably random?) that increments each time and isnt re-used. Note any given device has a limited pool of DevNonces (actually quite a lot!) which under normal use & life time operation should not become exhausted, but if joining regularly (some badly witten s/w joins every time before 1st data TX and is a waste of space/should be avoided like the plague) such that you run out in the working life of the device then only option is to delete device in LNS and start again!
How about the Learn link at the top of the every forum page? And the link bottom right to the documentation on every console page?
And then there is the LoRaWAN specification on the LoRa Alliance website.
There is an error in my post above - I missed a not - I’ve edited this now - LMIC does NOT support v1.0.4 so if you’ve selected that as your device version, it will need to be changed to v1.0.3
We’d need some more info on what it’s doing for those 15 minutes - serial logs from the device as text formatted with the </> tool plus screen shots at a reasonable “old person” resolution of the exact same time from the device console in verbose mode.
Your RSSI/SNR looks OK, there aren’t any warnings in the console about the DevNonce, so I’d have to suspect that something is stopping the device from hearing the Join Accept. Potentially:
The gateway is not transmitting the accept - you can check on the gateway console
The antenna is inefficient, compensated for by the device transmitting at a high power providing a good signal, but the antenna isn’t quite right for listening.
The timing is badly out due to other threads on the device so it misses the receive window - you’ll need to turn on the timestamps on the serial log so we can see what it is doing.
Im still developing my project but now I have another problem.
I developed a Node Red app that sends a hexadecimal data (B6 BB 9E). I can see it on ttn console without problem. The problem comes when my board read the MAC payload as B6 BB 9E.
You can think that I coded this interpretation on my stm32 project but I didn’t. That’s what I want but even if I have my Node Red app closed, it’s still interpreting the same way.
Despite being told previously that you need to consider the Fair Use Policy, you appear to be sending every 5 seconds. You were asked to read the Learn section which covers this. This is not only a massive breach, but is illegal use of the radio spectrum - illegal like police, court fines, etc etc.
Do not post serial logs as an image.
Suspending the thread until you confirm you are working to FUP. That’s if the TTI staff don’t suspend your entire account first.
