I don’t see that in the Gateway console anymore, but I looked in the earlier ones and there was no information there to be picked up by another Gateway.
Regarding whether or not to be sure, yes to this Gateway there is quite a high hill to this covered with forest, this frequency will not get in this direction from a small antenna from the room I am 100% sure of this.
Note that here it is only about testing of the prepared Nod to cover the topic of data collection and their transmission/reading.
Until the end of the tests I had no intention to take this Nod outside.
Crystal balls aside, if you mean configure and leave it alone for many years, yes, it will run a seamless gateway and as LoRaWAN is an accredited standard, if you do choose to upgrade the firmware, Mikrotik will be breaking the point of their own product if they don’t stick to the standard. Not that the gateway does that much, so there’s not much to change.
For your 3 options, there is some investment in time and a bit of money for you to learn what’s what so you can understand the answers. So get a TTIG, adapt it for an external antenna if you want to, and then you will be able to read the answers about why future compatibility isn’t a thing, whether using an embedded processor or an SD Card based SBC is better, that there are few Pi’s setup as outdoor gateways and that “outdoor” could mean IP54 in a plastic box or it could be IP67 on the top of an antenna installation.
So get a TTIG, learn, ask questions here, learn more (see link at top of menu) and create a solution!
Yes, only if I buy TTIG then I can only rely on what I read in the Gateway console, but I do not have the ability to plug into the console of TTIG itself .
Please correct me if I don’t know something.
I would prefer to have a full picture of how it works before the packets are sent to TTN.
You can by soldering on the pin headers - but why do you need to read the console of the gateway - many people do and post the results on here asking for us to interpret the logs for them.
Which we can do, but mostly a gateway is an appliance - I rarely look at gateway web console logs and very very very rarely look at the RAK/Pi/TTIG/TTOG/LPS8/uAP logs and I design & build devices - I can see from the device logs if I’ve screwed up something.
I’d not recommend building a gateway until you have a known good one and a known good device - if you don’t like the TTIG, a Dragino LPS8 seems to be good.
Don’t, there is no need and it doesn’t add value over the MikroTik offerings. RPi based solutions were nice when we started because of the price point, these days a turn key solution is cheaper and does not suffer from SDcard issues.
