I tried the OTAA example with the firmware 1.0.0.b2 on my LoPy. I did change the app_eui and app_key. Now if I run the script it generates a TimeoutError: timed out on line 25.
If I change the value of the timeout from 60 to 0 the error disappears but I just get “Not joined yet…” on the console and the LED is flashing in red.
Are there any jumper I need to set on the baseboard?
Any hints are welcome and thx in advance.
affoltep
edited: I have tried to use the ABP connection.This was working without any problems. So I guess it needs to be a problem with the new LoPy firmware 1.0.0.b2.
I tried the same example but i can’t connect to the gateway
I build the gateway using Rpi3 +ic880a spi
the gateway is up and running but the lopy never connects I might missing something with gateway configuration
I tried this example tonight and I have version ‘1.7.1.b2’
I’m getting
Traceback (most recent call last):
File “”, line 26, in
Can anyone tell me if these are MSB first or LSB first i.e Do I have to reverse the numbers I get from TTN or leave them as they are on the Device overview screen?
So the answer to this issue is that in the US the DR needs to be 3 not 5. Hope this helps someone else save some time.
“SO_DR (datarate) 5 is only available in LoRa 868Mhz (EU868). Are you in a different region? For US915 it should be 3.” The Answer was found here:
Another note that might be useful. If you are using Atom with the Pymakr plug in it seems you have to save before you run the file or it runs the last file. Possible this is not the case (I’m still learning) but this seemed to be the way it worked as I installed it.
I’m not sure if I should be able to see the Join Accepts in the console? Also I’m new to much of this, so I haven’t figured out how to monitor the Lorix traffic to see what happens at the gateway (any help here would be appreciated). I’ve worked with an iC880A+Raspi before where I used tcpdump on port 1700 to see what happened, maybe something similar can be used here?
Anyways. Does anyone have a reliably working OTAA LoPy node? If so, can you point me in a the right direction?
Thank you!
edit: the ABP examples are working and I am receiving the bytes in my application.
Good point. As you can see in the screenshot, I do not see any application data. Does this imply that there is something wrong with the keys? I’ve double checked, and the app key and EUI should be the right ones…
I was sure that I checked everything! But apparently I made a mistake in the dev eui… I dont quite understand this, because I was able to do the ABP… Anyways - now I joined - awesome!
I got a LoPy on a PyTrack running, based on the code in the PyCom github pycom-libraries\examples\lorawan-nano-gateway and the source otaa_node.py using settings from config.py. And configured the source for OTAA with the dev eui, app eui and app key as in the TTN console. It takes the latitude and longitude from the PyTrack, and sends it as bytes, and the payload is then decoded in the console, based on the lab https://www.thethingsnetwork.org/labs/story/gps-tracker.
I just tried to connect my Lopy to someones Gateway with this code.
I can see the join requests in my TTN Application data but my Lopy keeps sending those request instead of printing “Joined” and start sending the payload. I had the exact same problem with another example code before.
Can someone help me?
I am trying this here in Switzerland and therefore changed the example to:
lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.EU868)
I moved the setup to another location with a different gateway and it works! That means that the gateway in my hometown does not send a confirmation back to my lopy. But why and what can I do?
