LoRa gateway RAK831 433 Mhz
I have RAK831 433 Mhz gateway. It is connected to TNN. I just wondering since my gateway is 433 Mhz but TTN console doesn’t have 433 Mhz plan. Will my gateway still get the data from my node and shows on TTN console in applications?
Erm, No!
@Jeff-UK so what should I do?
Get replacement card at freq suited to your location - perhaps vendor will swap out (for small restocking fee?) If bought as part of an original RAK Pilot build keep rest of system and swap the 831 board only?
@ but that’s the only frequency band available for LoRa communication in my region.
Where in the world are you? Have you checked with the LoRa Alliance for the recommended frequency plan & specification for your country?
Updated:
Rp doc https://lora-alliance.org/wp-content/uploads/2020/11/RP_2-1.0.2.pdf
Its unusual for radio regulations to specifically mention ‘LoRa’ …
There are a few locations world wide where LA have only defined a 433Mhz plan. E.g Azerbaijan, Morocco… In some case a part of the 86x band allowed but only a small portion e.g AZ allows 868-868.6 and 868.7-869.2 so LA recommend using 433 band etc. Morocco is 869-870…
