Lorawan Gateway Implementation
Thanks for reply, i think its around 60cm - 70 cm both node and gateway are nearby only. Either it is problem with gateway or node side because, whenever i restart node or gateway once i receive message.
Another output which i got after restart.:-
got ip 192.168.1.101 255.255.255.0 192.168.1.1
Gateway ID 5CCF7FF42F33BF04
ntp synced using 85.255.214.66
2017-05-10 11:57:28 GMT
sx1272: 34
start singleSF detector on SF7
router ip: 52.169.76.203
ntp synced using 88.159.1.196
rxpk 010c77005ccf7ff42f33bf04 message {“rxpk”:[{“rssi”:-115,“stat”:0,“modu”:“LORA”,“rfch”:1,“tmst”:305066763,“datr”:“SF7BW125”,“lsnr”:-12,“time”:“2017-05-10T12:02:28.016974Z”,“codr”:“4/5”,“data”:“9a+z9ank+XlpHCqaC1rg/K+czZz3/nVktk2L2/Iaj4WNXpyq3jV9LpaTP9w7k+BtHkJPEB6nV1dWikj4uUIdVSA381RopPE4M0Pea21OS73uKDytPoNI2sxcO0sRPwo//+siaRlK7OcnffXk1DmiGnCWqXSpvR+Xm7gSXpYwj6I=”,“freq”:868.100,“chan”:0,“size”:128}]} length.
I mean to say sometime only i gets packet from node to gateway. i won’t able to find bug. Please advise me how to proceed.
