Hi guys!
First of all, thank you for answering so quick, let’s see what you recommend:
Yes, that is true for an scenario with real devices, taking into consideration the windows reception limitations for LoRaWAN, but this is not the case, I am simulating both devices and gateways by software through UDP forwarding packet. What I do not get is why the same packet sent to two different destinations (ttn console VS ttn stack) behaves different, working in one side, and not in the other one.
It is a software simulation for both devices and gateways, there is not real gadgets… yet. If everything works as it is expected, I will look for a real case.
Well, I can make the test you are suggesting, but I believe that the real question here could be: what are the differences between TTN V2 stack and TTI V3 stack? Since I am sending exactly the same packet, there are no differences.
Additional information:
I am attaching the issue with further details (see joinError.json (4.7 KB) ) so as it might give you some clues about what it is going on.
Thanks beforehand, and looking forward to hearing from you.
Kind regards.
Daniel.
