LT-33222-L LoRa I/O Controller - Payload decoder and downlink config
see
Encoder:
function Encoder(object, port) {
  var bytes = [];
  if (object.Control == "DO")
    //test with: {"Control": "DO", "DO1":1 , "DO2":1, "DO3":1} => 02 01 01 01 (where 1 = on, 0 = off)
    bytes[0] = 0x02;
    if (object.DO1 ==1)
      bytes[1] = 1;
    else
      bytes[1] = 0;
    if (object.DO2 ==1)
      bytes[2] = 1;
    else
      bytes[2] = 0;
    if (object.DO3 ==1)
      bytes[3] = 1;
    else
      bytes[3] = 0;
  if (object.Control == "RELAY")
    //test with: {"Control": "RELAY", "RO1":1 , "RO2":1} => 03 01 01 (where 1 = close, 0 = open)
    //test with: {"Control": "RELAY", "RO1":0 , "RO2":1} => 03 00 01 (where 1 = close, 0 = open)
    //test with: {"Control": "RELAY", "RO1":1 , "RO2":0} => 03 01 00 (where 1 = close, 0 = open)
    bytes[0] = 0x03;
    if (object.RO1 ==1)
      bytes[1] = 1;
    else
      bytes[1] = 0;
    if (object.RO2 ==1)
      bytes[2] = 1;
    else
      bytes[2] = 0;
  if (object.Control == "RESET")
    //test with: {"Control": "RESET"} => 04 FF
    bytes[0] = 0x04;
    bytes[1] = 0xFF;
  if (object.Control == "PERIOD")
    //test with: {"Control": "PERIOD", "Seconds":60} => 01 00 3C
    bytes[0] = 0x01;
    // in seconds byte[2]..byte[3]
    bytes[1] = object.Seconds >> 8;
    bytes[2] = object.Seconds;
  return bytes;
Nice, thanks for sharing! But beware, the following won’t work for values larger than 255 seconds:
Unlike in, e.g., C++ where a byte can really only hold 8 bits and all other bits are simply discarded, JavaScript does not have such specific types. (Instead, everything is a floating point.) Above, bytes[2] will hold the full value, not just limited to its 8 least significant bits. You can try with {"Control": "PERIOD", "Seconds": 300}, which will not throw an error in the JavaScript, but TTN will still reject with Error("Encoder Output not valid: Numbers in Array should be between 0 and 255").
Also, it seems you need 3 bytes for the time?
So, I’d use:
// test with: {"Control": "PERIOD", "Seconds": 86400} => 01 01 51 80 (24 hours)
bytes[1] = object.Seconds >> 16;
bytes[2] = object.Seconds >> 8 & 0xFF;
bytes[3] = object.Seconds & 0xFF;
For bytes[1] you don’t need the & 0xFF to limit to 8 bits (as all bits in the leftmost bytes are zeroes), but it won’t harm either.
And just some notes in case you didn’t know:
You’re defaulting to zero. Probably by design, but just so you’re aware: {"Control": "DO", "DO1": 2, "DO2": "foo"} (where DO3 is missing and the others have invalid values) will silently set all outputs to zero. If you don’t expect errors in the input, then you could simply use:
bytes[1] = object.DO1;
bytes[2] = object.DO2;
bytes[3] = object.DO3;
You can define helper functions too, either above Encoder or within that function. Like:
// Decodes the value to either 1 or 0
function onoff(val) {
  // Non-strict equals: return 1 for the number 1 or the string "1"
  if (val == 1) {
    return 1;
  // Default all missing or invalid values to 0
  return 0;
  var bytes = [];
  if (object.Control === "DO") {
    bytes[0] = 0x02;
    bytes[1] = onoff(object.DO1);
    bytes[2] = onoff(object.DO2);
    bytes[3] = onoff(object.DO3);
If you want to fail on invalid inputs then we’d need to investigate on how TTN acts on returning a null value or on throwing an error. (TTN Console might work differently from the APIs there; not sure if there’s any documentation about that.)
Thanks Arjan
I was a little lazy with period - thanks for correction.
I am still trying to get the unit to uplink a payload. I have only been able to test the encoder. Just preparing an email to Dragino support. (yet other lansetic units work as soon as you turn then on.
The four voltage and current variables should be divided by 1000 and not 100 :stuck_out_tongue_closed_eyes:
Instead of this:
This:
decoded.ACI1 = ((bytes[0] << 8) + bytes[1])/1000;
decoded.ACI2 = ((bytes[2] << 8) + bytes[3])/1000;
decoded.AVI1 = ((bytes[4] << 8) + bytes[5])/1000;
decoded.AVI2 = ((bytes[6] << 8) + bytes[7])/1000;
Sorry @bryansmith but can’t confirm this.
The device documentation (LoRa_IO_Controller_UserManual_v1.0.2) defines on page 9:
For example if payload is: 0131013004AB04ACAA
The value for the interface is:
ACI2 channel current is 0x0130/100=3.04mA
AVI1 channel voltage is 0x04AB/100=11.95V
AVI2 channel voltage is 0x04AC/100=11.96V
My devices monitor their supply voltage (about 12v) and the readings are fine with /100:
“ACI1”: 0,
“ACI2”: 0,
“AVI1”: 11.97,
“AVI2”: 0,
“DI1”: 1,
“DI2”: 0,
“DI3”: 0,
“DO1”: 0,
“DO2”: 0,
“DO3”: 0,
“RO1”: 0,
“RO2”: 0
I see your reference to user manual version 1.0.2 yet under versions 1.1.0 and 1.1.1 the decoder provides inaccurate data.
Page 9 of version 1.0.2 payload format:
0131013004AB04ACAA
Page 11 of version 1.1.1 payload format:
1310 1300 04AB 04ACAA
Your decoder works fine on version 1.0.2 and 1.0.4 but anything above that Dragino changed the format by removing the leading 0 :see_no_evil:
:roll_eyes: this is going to be funny in an environment with different firmware versions… thank you for pointing it out!
I’m a newbie regarding lorawan, scripting, et cetera. After some study on the internet I bought the I / O controller from Dragino. Now I am testing and trying out. I have made the configuration in the TTN, I can also enter AT commands. I also made the connection with Cheyenne. Then I installed the latest firmware. And now I get “payload:[not provided]”. I can’t find any help anymore.
Thanks in advance.
that’s not very much info for someone to help you I think.
After installing the old firmware everything works again. Has nothing to do with payload. My be someone with better knowledge could configure all the wrong parameters with the newer firmware.
Thanks anyway.
Does anyone know if this device can trigger uplink packets based on state changes on the Inputs, or is it limited to the timed period reporting? I am looking for the lowest possible delay to report an event.
Not at the moment, I made a request on Github over a year ago. The feature would make this device much more interesting.
I’m also looking for a solution of upgrading the firmware of LT-33222-L mote as zone11 aforementioned.
But so far, there is only code for LSN50 and LoRa ST.
Does any one know an alternative code/ industrialised LoRa mote which can send data when inputs change?
We have tried with the Ursalink UC 1114, but there is not enough inputs (02) for our application requirement. I appreciate any suggestion.
Hello dear,
I am also working on a project trying to control LEDs with LoRA. Can I use the same code and which part do I need to modify?
I am a beginner with LoRA one.
This is a forum for The Things Network (TTN).
If you want to use LoRa devices to remote control LEDs, that does not sound like a typical TTN application.
Do you have more details of what you are trying to do ?
I am using LPS8 8-channel dragino gateway and Dragino shield+Arduino Uno as my LoRa node. It worths mentioning, that I want to control solenoid valve using the relay which are connected to the LoRa node. I already configured the gateway with The Things Network and LoRa node. But now I want to control the solenoid valves using relay through things network downlink. I tried several times but no result.
I would be glad if anyone who can help me out.
Tried what? Have you read the pretty reasonable Dragino docs plus the TTS docs on downlinks.
But before you do, have you searched the forum on why LoRaWAN sucks at remote control and the Fair Use Policy on downlinks?
I have studied the Dragino user manual and watched several videos. However, non of them worked out. I tried with a number of downlink encoders based on following some tutorials and sent the message through downlink but it can not control the relay.
To save the volunteers on here digging out all the downlink decoders they know of which you may have already tried, it will help with responses if you told us what they are.
When you say “it can not control the relay” - are there error messages or anything? What do you see in the serial console for the controller?
