Yes, thatās the point it keeps the respective link budgets symmetric wrt specā¦
Max. 13 dBm EIRP means max. 11 dBm ERP. If you use a dipole-antenna with a gain of 2.1 dBi or 0 dBd then you have to reduce the output-power by 3 dB or use an antenna with less gain.
Can you tell your gateway, that it has an antenna with a gain of 5 dBi? Than the gateway should reduce itās max. output-power to 11 dBm.
Once I get access to the network again, I can ssh to it and check. Thanx.
That was another suggestion I made on the previous Atacama threadā¦GW then automatically dials down the EIRPā¦ problem is does still risk some asymmetryā¦ but can be made to work.
Since itās the servers responsible for commanding the power level, this really should be verified and submitted as a bug report against the infrastructure.
However, you could modify the packet forwarder with a local limit, so that even if commanded to do more, it will just emit the local maximum.
Keep in mind that normally, emitting less than expected would be detrimental to the network, so this should really be only a last resort for legal compliance in the face of a bug you can verify. LoRaWAN servers choose the gateway with the best received signal to transmit a downlink, but if that gateway is unusually weak in the transmit direction (for example the ST lab bench only board that lacks a power amplifier) then this in essence becomes a denial of service attack on the network, since it tricks the servers into allocating downlink transmissions to a weak transmitter rather than one slightly further away producing the expected power.
In this case, the gateway covers the middle third of South America, literally, itās on top of a mountain on top of the Andes. Which is why they may be being asked to dial down the signal.
This really should have stayed a single thread with the history of the issue.
Here a reply from Kerlinkās helpdesk which I forward to the experts amongst you.
Tx Max Power has to be managed through the LNS. Itās not recommended to change the antenna gain into json file. In case of modification of antenna gain, Rx will be impacted too.
Kerlink is right: in the design of LoRaWAN, itās the network server thatās tasked with issuing only allowable downlink requests.
In effect, the OPās issue is that TTN does not properly support the regulatory environment of their country (it sounds like that may be a still evolving environment).
Realistic options would be working with TTN developers to support the evolving situation, a custom private server instance with experimental changes to support it, or temporary workarounds such as modifying the packet forwarder with a local hard limit, or even a man-in-the-middle server which modified the transmit commands from TTN before they reached the actual gateway.
Actually if I understand it TTN follows the L-A RPās and they in turn are dictated by local in country regulations.
The problem here is a very local and specific deployent problem due to the location used for GW - both extreme height and proximity to the sensitive instrumaentation of the local observatoriesā¦come down to lower levels either side of the Andes and RPās arenāt an issue as I understand it! This one is a bit of an exception and an eye popper! Might be good for setting some ground to ground range records !
If they could run to putting in a FLARM base station that would be cool - then we can track record breaking distance flights in sailplanes in real-time! Thereās ridge soaring and then there is the Andes ā¦
Thatās the idea. But it turns out that they do not reflect the applicable legal regulations.
Thatās an additional problem, not the only problem.
The OP reports that even apart from the specific install location, the system does not meet their countryās regulations for ordinary outdoor use to begin with.
So there are two issues:
TTN does not correctly model the country regulations, because its process of doing so is too indirect, following from guidance by a 3rd party thatās not actually written for the country in question, but merely one similar in some (but not all) respects.
The conventional design of LoRaWAN infrastructure doesnāt really have a way to model varying gateway location-unique concerns. This could be possible without breaking the LoRaWAN spec (since it doesnāt really limit what the server may consider in picking a downlink gateway) but it would require some new and creative thinking. In effect, this gateway should be treated as the āleast preferableā choice for transmission when thereās any other alternative, and if it is used, then the transmit command needs to go out at a reduced power level.
I guess the other problem is RF does a Putin and doesnt respect geo-political/man made borders! A legal GW 10m from border with another country where limits/regulations different?
I and am sure many others on the Forum dont fancy fines or jail time so if you have specific examples of
Such that we can mitigate would be good - specifics/facts please
This is only the 3rdā¦ok maybe 4thā¦ time in near 10 years with LoRa/LoRaWAN that I have seen a very geo specific local variance requested by a regulator, or other requestor with powers of influence/enforcement (or else!)
The non-compliance with the general RF regulations of Chile was already explained in OPās original thread, where the applicable regulation is quoted as the first item, before getting into the additional location specific concern as a second, distinct issue.
Probably the two threads need to be merged.
Not sure how or where you determined that - I see no ref to general regulations only a regulator request to limit in their specific case (because of location etc as explained later on)
Perhaps OP can clarify.
Chile has a significant TTN Community based around Santiago with 14 GWs and 78 contributors and Iām not personally aware of any issues being raised wrt General Regulations previously. (And I believe there are historically around 35-45 TTN GWs in country)
BTW I agree with some of your application driven Downlink adjustments as being impractial and also not then addressing network initiated DL from prior to your post edit I said much the same earlier. Change power per application DL simply wont work/be practical!
You need to re-read the other thread more carefully, because (for the third time) OP states two distinct issues: 1st they quote the general RF regulation that is not being complied with. Then they mention an additional concern about being near radio astronomy installations.
Even apart from that location specific concern they are quoting a general RF regulation that is allegedly not being complied with. Perhaps they are mistaken in some way, but theyāve made a very clear, specific, and regulatory language supported allegation.
Just claiming that the LoRa alliance handles this in no way refutes that claim, both because the regional settings are actually for an entirely different country to begin with, and because the LoRa Alliance explicitly disclaims accuracy in interpreting regulations even for the actual country, nevermind a āsimilarā one.
This would be a good group of people to be discussing the apparent issue
Not having gotten in trouble yet does not in any way mean that whatās being done is legal - accidental non-compliance is very much a thing, and at the power levels in question, discovery would likely only follow from investigation of some specific complaint. But illegal operation (if thatās what it is) is still illegal.
Someone is misreading the rules or unaware of recent changes - the question is, who.
Then that is something to bring to the attention of 1) the Lora Alliance and 2) TTN developers who do (as regular visitors know) not visit the forum daily.
@johan : it seems there is an issue for Chilean users which needs attention. Anything you (as a Lora Alliance member) can do to help them out?
Thanks to all for the great attention to this peculiarity,
in fact have I already contacted TTNās Chilean user group, awaiting a reply.
As a matter of fact the 20mW limit is imposed by the Chilean authorities (ministry of transportation & telecommunication), I provide an excerpt of their regulations (translated by Google) ResoluciĆ³n 755 EXENTA of 2005:
ā¦
Operate, inside real estate, in the TRANSPORTATION band
915 to 928 MHz with a maximum radiated power of 100 mW and, SINGLE Art. NĀ° 2
to the outside of buildings with 20 mW, in both cases technical D.O. 13.06.2013
as: direct-sequence or hopping spread spectrum
of frequency, previous monitoring, dynamic selection of
channels or other digital modulation techniques that
operate with a minimum bandwidth of 5 MHz and allow
share frequencies.
ā¦
Worth noting that since LoRaWAN hardware canāt spread or even hop (uplink) channels over a 5 MHz minimum bandwidth, I have to wonder if these are the correct option in the regs to be looking at.
But that doesnāt necessarily help the situation, since the rules for wideband (low power density) systems are usually more lenient than those for narrower ones.
Right or wrong, an occasional āhey, do we all agree that this is what our local regs mean?ā is a healthy kind of question to be asking.
Sorry, I was merely recapping the regulations
This still leaves the question, whether this radiated power is e.r.p. or e.i.r.p.
There is a difference of 2.1 dB.
good question: admittedly 2.1 dB compared to a difference of about 17 dB is quite neglectableā¦, though
