Hello friends,
I have te follow question.
I’m running node red and a Influxdb on my server.
In node red I have a MQTT noce connected to my TTI node.
With a function node I put the data to my Influx database.
But now I want to connect another TTI node to my database.
This is how my code looks in my functionnode:
let eui = msg.payload.end_device_ids.device_id;
let temperature_11 = msg.payload.uplink_message.decoded_payload.temperature_11;
let analog_in_1 = msg.payload.uplink_message.decoded_payload.analog_in_1;
let analog_in_2 = msg.payload.uplink_message.decoded_payload.analog_in_2;
let barometric_pressure_12 = msg.payload.uplink_message.decoded_payload.barometric_pressure_12;
let relative_humidity_10 = msg.payload.uplink_message.decoded_payload.relative_humidity_10;
msg = {}
msg.payload = {
eui: eui,
temperature_11: temperature_11,
analog_in_1: analog_in_1,
analog_in_2: analog_in_2,
barometric_pressure_12: barometric_pressure_12,
relative_humidity_10: relative_humidity_10
return msg
How can I send the data from every eui seperated from the other eui?
Now when I go to Grafana and I want to make a dashboard I got al lot of datafields.
I want (if eui is XXXXXXXXXXXX the I must have XXXXXXXXX data.
I hope someone knows what I mean.
Regards
Reinier
