PCI/mini PCIe concentrator boards
Something to watch out for with randomly sourced mPCIe adapters intended for mobile data modems is that a lot of the cheap ones supply substantially more than 3.3 volts.
So make sure to measure the regulator output and decide it is appropraite before putting your LoRa card in there.
If the voltage is too high, it’s easy to rework them with a fixed 3-terminal regulator and grounding out the adjust pad, or by changing the resistors on an adjustable regulator to produce an allowed voltage.
Also consider cooling as the SX1301 chip will produce a fair amount of heat once the packet forwarder fully starts it up.
Thanks for the warnings, @cslorabox.
Air flow should be ok. The cpu fan is close by and the case has at least three fans plus the PSU fan. Not sure how I can check the supply voltage, but I will aim to buy a mpcie-usb adaptor that looks identical to that shown in the hackster article. Suspect the probes of my DMM will be too large to measure the correct contacts, even if I knew which ones to measure…
Actually not hard at all as you don’t have to probe the mPCIe itself. There are plenty of grounds on such a board, and the tab on modern positive 3 terminal regulators is usually their output. If you’re worried about a probe slipping do the regulator voltage test with a USB power source you don’t particularly care about, and of course the LoRa card is not yet installed.
Incidentally the board in the hackster link is visually identical to those I found with the regulator set to output excessive voltage.
@cslorabox You were right. The regulator output on my “randomly sourced” adaptor is 3.77V. But that is with no load. Could it be that it would be closer to the expected 3.3V with a load?2019-03-22-182121
EDIT: No, loading it does not help. I shorted the regulator tab to ground with 330R. Around 11.3mA flowed, as you would expect @ 3.77V.
From the data sheet:
Screenshot_20190322-190641
Looks like R12 & R13 on the adaptor are R1 & R2 in the above schematic.
Not really - that would only happen on the edge of failure. Regulator failure would hopefully result in a shutdown, so really the only way you’d see droop would be loss on the input (USB/wiring) side. But setting the setpoint higher doesn’t help with that.
It looks like SX1301 operational max is 3.6 volts while the “absolute maximum” is 4.0, but you are not supposed to run parts beyond their operational ratings, and there are also other chips in a concentrator.
My feeling is that this higher voltage was chosen because someone thought it would work better with the mobile data modems for which these adapters are intended.
I personally just change out the regulator for a 3.3v fixed model and ground the adjust terminal (as it is a ground terminal on the fixed models). But you can also recalculate the resistors if you prefer.
Or you can make your own decision to chance running it as is. I decided the LoRa modems are expensive enough I’d prefer to be careful of them. For that matter, I’m also using mine with tiny wires pulling the non-standard SPI lines off the mPCIe connector, so it’s been on the to-do list to just make a more suitable board, make it out of thicker PCB stock, and perhaps leave the actual area where the modem sits open for better cooling.
IMG_20190323_065439
I think these are EIA SMD resistor codes.
30A = 200R
01A = 100R
Which would make the output voltage
1.25 * (1 + 200/100) = 3.75V
(Ignoring Iadj which should be 50uA)
Which is close to what I measure.
If I put 1K in parallel with the 200R, that would bring the combination down to 167R. Then the output would be
1.25 * ( 1 + 167/100) = 3.33V
820R soldered in place. Regulator output is now 3.27V. Job done!IMG_20190323_084235
Concentrator card has arrived. Now I need to find some time to install it!IMG_20190329_063858
I’m following the instructions here as suggested by N-fuse. Just plugged the concentrator + usb adaptor + antenna in for first time. lsusb shows:
Bus 004 Device 002: ID 0483:5740 STMicroelectronics STM32F407
In step 3, I needed to use sudo:
sudo ./util_chip_id/util_chip_id
A gateway ID appears. So far so good…
UPDATE: All steps completed. Gateway is up and running and receiving its first packets!
IMG_20190331_180847
Thanks again @Vanthome and @cslorabox for the advice.
Looks like I may have the same issue as described in the Hackster.io article. After a reboot, the packet forwarder service starts, but the gateway does not connect with TNN.
granary@granary:~$ systemctl status pkt_fwd.service
● pkt_fwd.service - Semtech packet-forwarder
   Loaded: loaded (/lib/systemd/system/pkt_fwd.service; enabled; vendor preset:
   Active: active (running) since Mon 2019-04-01 20:54:14 BST; 25s ago
 Main PID: 856 (lora_pkt_fwd)
    Tasks: 1 (limit: 4433)
   CGroup: /system.slice/pkt_fwd.service
           └─856 /home/granary/loragateway/picoGW_packet_forwarder/lora_pkt_fwd/
Apr 01 20:54:14 granary systemd[1]: Started Semtech packet-forwarder.
The journal shows nothing interesting either:
granary@granary:~$ journalctl -u pkt_fwd.service -b -f
-- Logs begin at Wed 2019-01-23 22:35:37 GMT. --
But if I stop and start the service, the gateway connects to TNN in ~ 1min:
granary@granary:~$ systemctl stop pkt_fwd.service
==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ===
Authentication is required to stop 'pkt_fwd.service'.
Authenticating as: granary,,, (granary)
Password:
==== AUTHENTICATION COMPLETE ===
granary@granary:~$ systemctl start pkt_fwd.service
Authentication is required to start 'pkt_fwd.service'.
Password:
Apr 01 21:04:23 granary lora_pkt_fwd[856]: *** Packet Forwarder for Lora PicoCell Gateway ***
Apr 01 21:04:23 granary lora_pkt_fwd[856]: Version: 0.1.0
Apr 01 21:04:23 granary lora_pkt_fwd[856]: *** Lora concentrator HAL library version info ***
Apr 01 21:04:23 granary lora_pkt_fwd[856]: Version: 0.2.2;
Apr 01 21:04:23 granary lora_pkt_fwd[856]: ERROR: FAIL TO CONNECT BOARD ON /dev/ttyACM0
Apr 01 21:04:23 granary lora_pkt_fwd[856]: INFO: Stopping concentrator
Apr 01 21:04:23 granary systemd[1]: pkt_fwd.service: Main process exited, code=exited, status=1/FAILURE
Apr 01 21:04:23 granary systemd[1]: pkt_fwd.service: Failed with result 'exit-code'.
Apr 01 21:04:23 granary systemd[1]: Stopped Semtech packet-forwarder.
Apr 01 21:04:37 granary systemd[1]: Started Semtech packet-forwarder.
Maybe it doesn’t like being run before you have network connectivity? Often service startup scripts can be set to have an order.
That said, no matter what your network backhaul is, you should assume that it will go down (and hopefully come back up) in operation.
I ended up with a multi-level watchdog, on the network link itself, and ultimately on the packet forwarder stats packets being bounced back from a server setup to do that. Either failure will ultimately reboot the gateway if it persists long enough.
Applying the fix suggested in theHackster.io article, I get an error message when the service attempts to start:
   Loaded: loaded (/lib/systemd/system/pkt_fwd.service; enabled; vendor preset: enabled)
   Active: activating (auto-restart) (Result: exit-code) since Mon 2019-04-01 21:14:05 BST; 22s ago
  Process: 1541 ExecStart=/home/granary/loragateway/picoGW_packet_forwarder/lora_pkt_fwd/start.sh (code=exited, status=203/EXEC)
 Main PID: 1541 (code=exited, status=203/EXEC)
Apr 01 21:14:05 granary systemd[1]: Started Semtech packet-forwarder.
Apr 01 21:14:05 granary systemd[1]: pkt_fwd.service: Main process exited, code=exited, status=203/EXEC
Apr 01 21:14:05 granary systemd[1]: pkt_fwd.service: Failed with result 'exit-code'.
That’s not the meaningful error message, it is only the error that there was an error.
You need to look in /var/log/syslog or wherever the packet forwarder output is going to see the actual error.
Also make sure your systemd service is set to auto-restart on failure…
/var/log/syslog shows:
Apr  1 21:25:10 granary systemd[1]: pkt_fwd.service: Service hold-off time over, scheduling restart.
Apr  1 21:25:10 granary systemd[1]: pkt_fwd.service: Scheduled restart job, restart counter is at 23.
Apr  1 21:25:10 granary systemd[1]: Stopped Semtech packet-forwarder.
Apr  1 21:25:10 granary systemd[1]: Started Semtech packet-forwarder.
Apr  1 21:25:10 granary systemd[1832]: pkt_fwd.service: Failed to execute command: Exec format error
Apr  1 21:25:10 granary systemd[1832]: pkt_fwd.service: Failed at step EXEC spawning /home/granary/loragateway/picoGW_packet_forwarder/lora_pkt_fwd/start.sh: Exec format error
Apr  1 21:25:10 granary systemd[1]: pkt_fwd.service: Main process exited, code=exited, status=203/EXEC
Apr  1 21:25:10 granary systemd[1]: pkt_fwd.service: Failed with result 'exit-code'.
If I stop the service and run start.sh manually, I get:
granary@granary:~/loragateway/picoGW_packet_forwarder/lora_pkt_fwd$ sudo ./start.sh
[sudo] password for granary:
Version: 0.1.0
Version: 0.2.2;
Version: 0.1.0
Version: 0.2.2;
*** MCU FW version for LoRa PicoCell Gateway ***
Version: 0x010A0006
INFO: Little endian host
INFO: found global configuration file global_conf.json, parsing it
INFO: global_conf.json does contain a JSON object named SX1301_conf, parsing SX1301 parameters
INFO: lorawan_public 1, clksrc 1
INFO: antenna_gain 0 dBi
INFO: Configuring TX LUT with 16 indexes
INFO: radio 0 enabled (type SX1257), center frequency 867500000, RSSI offset -164.000000, tx enabled 1
INFO: radio 1 enabled (type SX1257), center frequency 868500000, RSSI offset -164.000000, tx enabled 0
INFO: Lora multi-SF channel 0>  radio 1, IF -400000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 1>  radio 1, IF -200000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 2>  radio 1, IF 0 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 3>  radio 0, IF -400000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 4>  radio 0, IF -200000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 5>  radio 0, IF 0 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 6>  radio 0, IF 200000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 7>  radio 0, IF 400000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora std channel> radio 1, IF -200000 Hz, 250000 Hz bw, SF 7
INFO: FSK channel> radio 1, IF 300000 Hz, 125000 Hz bw, 50000 bps datarate
INFO: global_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
INFO: gateway MAC address is configured to 3338333045003200
INFO: server hostname or IP address is configured to "router.eu.thethings.network"
INFO: upstream port is configured to "1700"
INFO: downstream port is configured to "1700"
INFO: downstream keep-alive interval is configured to 10 seconds
INFO: statistics display interval is configured to 30 seconds
INFO: upstream PUSH_DATA time-out is configured to 100 ms
INFO: packets received with a valid CRC will be forwarded
INFO: packets received with a CRC error will NOT be forwarded
INFO: packets received with no CRC will NOT be forwarded
INFO: [main] concentrator started, packet can now be received
INFO: host/sx1301 time offset=(1554150705s:740683µs) - drift=1554150705740683µs
INFO: [down] PULL_ACK received in 23 ms
INFO: [down] PULL_ACK received in 24 ms
INFO: [down] PULL_ACK received in 22 ms
and the gateway connects to TNN again…
It’s refusing to run the startup script.
You should probably post the full systemd service file, and the permissions and first few lines of start.sh
start.sh is just these 3 lines, as suggested in the Hackster article:
timeout 10 ./lora_pkt_fwd
sleep 5
./lora_pkt_fwd
It runs OK if I invoke it manually using sudo.
Permissions on start.sh:
granary@granary:~/loragateway/picoGW_packet_forwarder/lora_pkt_fwd$ ls -l start.sh
-rwxrwxr-x 1 granary granary 49 Apr  1 21:09 start.sh
Where do I find the systemd service file?
Well, there’re your problem exactly as the error complained.
It must begin with something like
#! /bin/bash
To tell the system that it needs to be interpreted by a shell, as a text file isn’t an executable format. Why it works when invoked from an interactive shell is probably an interesting topic to research, but not really relevant to your need.
Thanks, I wondered why the shell script did not begin with the usual #! line, but because it ran when I invoked it manually, I began to think it didn’t matter.
I updated start.sh:
#! /bin/bash
sleep 5
./lora_pkt_fwd
Then I restarted the service and got:
granary@granary:~/loragateway/picoGW_packet_forwarder/lora_pkt_fwd$ journalctl -u pkt_fwd.service -b -f
Apr 01 21:50:32 granary start.sh[2192]: INFO: Stopping concentrator
Apr 01 21:50:37 granary start.sh[2192]: *** Packet Forwarder for Lora PicoCell Gateway ***
Apr 01 21:50:37 granary start.sh[2192]: Version: 0.1.0
Apr 01 21:50:37 granary start.sh[2192]: *** Lora concentrator HAL library version info ***
Apr 01 21:50:37 granary start.sh[2192]: Version: 0.2.2;
Apr 01 21:50:37 granary start.sh[2192]: ERROR: failed to open COM port /dev/ttyACM0 - No such file or directory
Apr 01 21:50:37 granary start.sh[2192]: ERROR: FAIL TO CONNECT BOARD ON /dev/ttyACM0
Apr 01 21:50:37 granary start.sh[2192]: INFO: Stopping concentrator
Apr 01 21:50:37 granary systemd[1]: pkt_fwd.service: Main process exited, code=exited, status=1/FAILURE
Apr 01 21:50:37 granary systemd[1]: pkt_fwd.service: Failed with result 'exit-code'.
Apr 01 21:51:08 granary systemd[1]: pkt_fwd.service: Service hold-off time over, scheduling restart.
Apr 01 21:51:08 granary systemd[1]: pkt_fwd.service: Scheduled restart job, restart counter is at 35.
Apr 01 21:51:08 granary systemd[1]: Stopped Semtech packet-forwarder.
Apr 01 21:51:08 granary systemd[1]: Started Semtech packet-forwarder.
Apr 01 21:51:08 granary start.sh[2229]: *** Packet Forwarder for Lora PicoCell Gateway ***
Apr 01 21:51:08 granary start.sh[2229]: Version: 0.1.0
Apr 01 21:51:08 granary start.sh[2229]: *** Lora concentrator HAL library version info ***
Apr 01 21:51:08 granary start.sh[2229]: Version: 0.2.2;
Apr 01 21:51:08 granary start.sh[2229]: ERROR: failed to open COM port /dev/ttyACM0 - No such file or directory
Apr 01 21:51:08 granary start.sh[2229]: ERROR: FAIL TO CONNECT BOARD ON /dev/ttyACM0
Apr 01 21:51:08 granary start.sh[2229]: INFO: Stopping concentrator
Apr 01 21:51:13 granary start.sh[2229]: *** Packet Forwarder for Lora PicoCell Gateway ***
Apr 01 21:51:13 granary start.sh[2229]: Version: 0.1.0
Apr 01 21:51:13 granary start.sh[2229]: *** Lora concentrator HAL library version info ***
Apr 01 21:51:13 granary start.sh[2229]: Version: 0.2.2;
Apr 01 21:51:13 granary start.sh[2229]: ERROR: failed to open COM port /dev/ttyACM0 - No such file or directory
Apr 01 21:51:13 granary start.sh[2229]: ERROR: FAIL TO CONNECT BOARD ON /dev/ttyACM0
Apr 01 21:51:13 granary start.sh[2229]: INFO: Stopping concentrator
Apr 01 21:51:13 granary systemd[1]: pkt_fwd.service: Main process exited, code=exited, status=1/FAILURE
Apr 01 21:51:13 granary systemd[1]: pkt_fwd.service: Failed with result 'exit-code'.
Apr 01 21:51:43 granary systemd[1]: pkt_fwd.service: Service hold-off time over, scheduling restart.
Apr 01 21:51:43 granary systemd[1]: pkt_fwd.service: Scheduled restart job, restart counter is at 36.
Apr 01 21:51:43 granary systemd[1]: Stopped Semtech packet-forwarder.
Apr 01 21:51:43 granary systemd[1]: Started Semtech packet-forwarder.
Apr 01 21:51:43 granary start.sh[2250]: *** Packet Forwarder for Lora PicoCell Gateway ***
Apr 01 21:51:43 granary start.sh[2250]: Version: 0.1.0
Apr 01 21:51:43 granary start.sh[2250]: *** Lora concentrator HAL library version info ***
Apr 01 21:51:43 granary start.sh[2250]: Version: 0.2.2;
Apr 01 21:51:43 granary start.sh[2250]: ERROR: failed to open COM port /dev/ttyACM0 - No such file or directory
Apr 01 21:51:43 granary start.sh[2250]: ERROR: FAIL TO CONNECT BOARD ON /dev/ttyACM0
Apr 01 21:51:43 granary start.sh[2250]: INFO: Stopping concentrator
It repeats the same stuff every 5s.
