May it be linked to the fact that I concurrently have both NMEA and UBX messages flowing?
Maybe it is a misinterpretation of GST and it takes the time from here:
It might well be receiving a time, however the packet forwarder requires RMC messages and those I donāt see.
Please try to disable the binary format messages and make sure the NMEA output contains lines with RMC output. For testing it would be best if you can use something simple that just shows the output of the GPS without trying to interpret it. Something as simple as ācat < /dev/ttyACM0ā sometimes works (depends on default speed when opening the port).
OK I will try that. I have RMC (see gpsmon output below), but data is āblinkingā (sometimes is displayed, sometimes not, multiple times per second); maybe due to binary format messages.
OK, I just disabled binary format message, have made sure there is RMC output, but still,
16.01.18 20:21:28 (+0100) ### [GPS] ###
16.01.18 20:21:28 (+0100) # Invalid gps time reference (age: 1516130488 sec)
16.01.18 20:21:28 (+0100) # System GPS coordinates: latitude 48.69466, longitude 2.29817, altitude 52 m
That happens only using USB. When using UART or UART to USB converterā¦ that works. Why??
BTW, do you know how to enable beaconing via resin.io (using an environment variable maybe)?
Thanks for your help
Sorry, I donāt understand what you are saying. Are you saying GPS with time works OK when the GPS module is connected using UART?
You will not be able to enable beacons without working GPS time. Also you need to connect PPS from GPS to the iC880a board before it can work. If that is in place we can enhance the resin.io setup to enable beacons. Current script does not support it as far as I know.
I just tested interfacing UART GPS interface with my RPi3 using a UART to USB module, and this time GPS with time works
16.01.18 22:42:45 (+0100) ### [GPS] ###
16.01.18 22:42:45 (+0100) # Valid gps time reference (age: 1 sec)
16.01.18 22:42:45 (+0100) # System GPS coordinates: latitude 48.69464, longitude 2.29831, altitude 51 m
Still, it doesnāt work using USB interface from GPS to USB interface of RPi3 (only position, not valid time)
Is that easy to do now that I have working time?
Do you have PPS connected as required?
No, not simple. Will have to wait for the weekend before I got time to look into it. Sorryā¦
I think you need to enable UBX over USB using U-center, and make sure you can save the config.
Sorry, had to fix more urgent (affect more users) issues first.
Evening all. This is a simple question which I canāt seem to find the answer to.
I want to bring the Raspi activity LED to the front panel on my gateway. Is there any way to install the āact_led_gpioā overlay in my docker container?
Alternately, I think I can map the GPIOs to a fileā¦ is there a script which can map activity to a file?
Not sure what you mean with
in particular in dockerā¦
AFAIK act_led_gpio
is an overlay parameter, not an overlay by itself.
And why donāt you just set it in config.txt
(If it is for a resin.io deployment, you can set the dt parameters in your device config in resinā¦)
Aha! I see it:
āi2c_arm=onā,āspi=onā,āaudio=onā
Iām about 2 minutes from screwing the case together and taking the beauty shots. Maybe Iāll do it another time!
Iāve added a GPS module to my dev gateway, bringing it to the same h/w spec as production. It is working (console sees it and itās routing traffic), but itās a constantly flagging an error and the machine is running very hot:
16.03.18 08:32:49 (+0000) main 08:32:46 WARNING: [gps] read() returned value 0
ā¦
Any suggestions? Exact same spec and modules as the other one, and same resin.io build.
This is actually the issue I couldnāt fix on the manual build which made me try resin.
Not sure if you resolved that issue, but I saw the same thing when using the resin ādevā image instead of prod, The issue turned out to be due to this. In my case I simply deployed the production image instead, following the guide and making sure to apply the correct overlay.
Yup, exactly that
I found this post in german. Maybe that could help you!
Iāve looked into it but it requires a lot of refactoring for which I havenāt had time and will not have time in the near future. Also because TTN back-end does not support Class B and very few nodes do it is low priority for me. (Feel free to motivate me, not by bugging/nagging but you can probably think of some way )
If you want beacons with the current code base you need to use Semtech protocol for packet forwarding to at least one destination and set the approriate flags in the global config. (And have a GPS attached for timing)
