Sorry. Should have been more precise. The ebay link on github is to a 3.3v regulator.
I built the Gateway and it works fine, but sensors-js.service does not work. I receive the following messages:
● sensors-js.service - CH2i TTN Gateway Sensors service
Loaded: loaded (/lib/systemd/system/sensors-js.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Fri 2018-02-23 11:30:16 CET; 12s ago
Process: 671 ExecStart=/usr/bin/node /opt/ttn-gateway/bin/sensors.js (code=exited, status=1/FAILURE)
Main PID: 671 (code=exited, status=1/FAILURE)
Feb 23 11:30:16 ttn-gateway systemd[1]: sensors-js.service: Main process exited, code=exited, status=1/FAILURE
Feb 23 11:30:16 ttn-gateway systemd[1]: sensors-js.service: Unit entered failed state.
Feb 23 11:30:16 ttn-gateway systemd[1]: sensors-js.service: Failed with result ‘exit-code’.
Feb 23 11:30:16 ttn-gateway systemd[1]: sensors-js.service: Service hold-off time over, scheduling restart.
Feb 23 11:30:16 ttn-gateway systemd[1]: Stopped CH2i TTN Gateway Sensors service.
Feb 23 11:30:16 ttn-gateway systemd[1]: sensors-js.service: Start request repeated too quickly.
Feb 23 11:30:16 ttn-gateway systemd[1]: Failed to start CH2i TTN Gateway Sensors service.
What goes wrong?
@HaSch
Been long not playing with this, did you enabled i2c with raspi-config ?
Also you can try to start the script by hand and put result here ?
sudo systemctl disable sensors-js.service
cd /opt/ttn-gateway/bin/
sudo node sensors.js
Yes, I enabled i2c.
Starting the script by hand succeeded:
ttn@ttn-gateway:~ $ sudo systemctl disable sensors-js.service
Removed /etc/systemd/system/multi-user.target.wants/sensors-js.service.
ttn@ttn-gateway:~ $ cd /opt/ttn-gateway/bin/
ttn@ttn-gateway:/opt/ttn-gateway/bin $ sudo node sensors.js
Cayenne connected
Si7021 reset failed: Error: , Remote I/O error
Found BMx280 chip ID 0x60 on bus i2c-1, address 0x76
BME280 initialization succeeded
BME280 data = {
“temperature_C”: 22.56,
“humidity”: 34.62856683736186,
“pressure_hPa”: 761.903171283745
What’s going wrong?
could you create a file nodejs.sh
in /etc/profile.d/
that contains
NODE_PATH=/usr/lib/nodejs:/usr/lib/node_modules:/usr/share/javascript
export NODE_PATH
just to be sure ?
I did but the result is the same (see error message above)
Just a curiosity… if the box is sealed…how you can think to measure external humidity, pressure and temperature?
Alex
there is an inside and an outside sensor
Ops sorry… Charles, what kind of material surrounding the SI7021?
It looks like the script automaticly first started and then quits unexpectedly:
ttn@ttn-gateway:~/ic880a-gateway/src/sensors_js $ sudo systemctl status sensors-js
Active: active (running) since Sun 2018-02-25 12:42:06 CET; 358ms ago
Main PID: 8841 (node)
CGroup: /system.slice/sensors-js.service
└─8841 /usr/bin/node /opt/ttn-gateway/bin/sensors.js
Feb 25 12:42:06 ttn-gateway systemd[1]: Started CH2i TTN Gateway Sensors service.
Active: failed (Result: exit-code) since Sun 2018-02-25 12:42:09 CET; 2s ago
Process: 8864 ExecStart=/usr/bin/node /opt/ttn-gateway/bin/sensors.js (code=exited, status=1/FAILURE)
Main PID: 8864 (code=exited, status=1/FAILURE)
Feb 25 12:42:09 ttn-gateway systemd[1]: sensors-js.service: Main process exited, code=exited, status=1/FAILURE
Feb 25 12:42:09 ttn-gateway systemd[1]: sensors-js.service: Unit entered failed state.
Feb 25 12:42:09 ttn-gateway systemd[1]: sensors-js.service: Failed with result ‘exit-code’.
Feb 25 12:42:09 ttn-gateway systemd[1]: sensors-js.service: Service hold-off time over, scheduling restart.
Feb 25 12:42:09 ttn-gateway systemd[1]: Stopped CH2i TTN Gateway Sensors service.
Feb 25 12:42:09 ttn-gateway systemd[1]: sensors-js.service: Start request repeated too quickly.
Feb 25 12:42:09 ttn-gateway systemd[1]: Failed to start CH2i TTN Gateway Sensors service.
Maybe it’s helpful to look into the system log, here is the depending part:
Feb 28 12:56:52 ttn-gateway systemd[1]: Started CH2i TTN Gateway Sensors service.
– Subject: Unit sensors-js.service has finished start-up
– Defined-By: systemd
– Support: Debian -- User Support
– Unit sensors-js.service has finished starting up.
– The start-up result is done.
Feb 28 12:56:52 ttn-gateway sudo[3730]: pam_unix(sudo:session): session closed for user root
Feb 28 12:56:53 ttn-gateway sensors-js[3736]: /opt/ttn-gateway/bin/node_modules/bindings/bindings.js:88
Feb 28 12:56:53 ttn-gateway sensors-js[3736]: throw e
Feb 28 12:56:53 ttn-gateway sensors-js[3736]: ^
Feb 28 12:56:53 ttn-gateway sensors-js[3736]: Error: Module version mismatch. Expected 46, got 48.
Feb 28 12:56:53 ttn-gateway sensors-js[3736]: at Error (native)
Feb 28 12:56:53 ttn-gateway sensors-js[3736]: at Object.Module._extensions…node (module.js:434:18)
Feb 28 12:56:53 ttn-gateway sensors-js[3736]: at Module.load (module.js:343:32)
Feb 28 12:56:53 ttn-gateway sensors-js[3736]: at Function.Module._load (module.js:300:12)
Feb 28 12:56:53 ttn-gateway sensors-js[3736]: at Module.require (module.js:353:17)
Feb 28 12:56:53 ttn-gateway sensors-js[3736]: at require (internal/module.js:12:17)
Feb 28 12:56:53 ttn-gateway sensors-js[3736]: at bindings (/opt/ttn-gateway/bin/node_modules/bindings/bindings.js:81:44)
Feb 28 12:56:53 ttn-gateway sensors-js[3736]: at Object. (/opt/ttn-gateway/bin/node_modules/i2c-bus/i2c-bus.js:4:28)
Feb 28 12:56:53 ttn-gateway sensors-js[3736]: at Module._compile (module.js:409:26)
Feb 28 12:56:53 ttn-gateway sensors-js[3736]: at Object.Module._extensions…js (module.js:416:10)
Feb 28 12:56:53 ttn-gateway systemd[1]: sensors-js.service: Main process exited, code=exited, status=1/FAILURE
Feb 28 12:56:53 ttn-gateway systemd[1]: sensors-js.service: Unit entered failed state.
Feb 28 12:56:53 ttn-gateway systemd[1]: sensors-js.service: Failed with result ‘exit-code’.
Feb 28 12:56:53 ttn-gateway systemd[1]: sensors-js.service: Service hold-off time over, scheduling restart.
Feb 28 12:56:53 ttn-gateway systemd[1]: Stopped CH2i TTN Gateway Sensors service.
– Subject: Unit sensors-js.service has finished shutting down
– Unit sensors-js.service has finished shutting down.
No idea what’s going wrong?
What sensor did you used ?
would you min stop the service and start it by hand as indicated above to see what’s the output ?
looks like sensor not recognized, a clone one ?
As I wrote above: Starting by hand succeeded (see #7). I use a BME280 and it‘s not a clone.
Ok let’s restart from scratch
cd /opt/ttn-gateway
sudo systemctl stop sensors-js
sudo rm -rf node_modules
sudo npm install -g --unsafe-perm bme280-sensor
sudo npm install -g --unsafe-perm si7021-sensor
sudo npm install -g --unsafe-perm cayennejs
sudo npm link bme280-sensor
sudo npm link si7021-sensor
sudo npm link cayennejs
sudo systemctl start sensors-js
Does this works ?
BTW what nodejs version do you have ?
I tested on my new GW and this is working fine
loragw@ttn-gw04:/opt/loragw $ sudo systemctl status sensors-js.service
● sensors-js.service - CH2i Lora Gateway Sensors service
Active: active (running) since Fri 2018-04-13 18:35:31 CEST; 21min ago
Main PID: 10352 (node)
└─10352 /usr/bin/node /opt/loragw/sensors.js
Apr 13 18:56:28 ttn-gw04 sensors-js[10352]: }
Apr 13 18:57:00 ttn-gw04 sensors-js[10352]: BME280 data = {
Apr 13 18:57:00 ttn-gw04 sensors-js[10352]: "temperature_C": 38.67,
Apr 13 18:57:00 ttn-gw04 sensors-js[10352]: "humidity": 18.941909695408516,
Apr 13 18:57:00 ttn-gw04 sensors-js[10352]: "pressure_hPa": 997.5175459059838
Apr 13 18:57:00 ttn-gw04 sensors-js[10352]: }
Apr 13 18:57:00 ttn-gw04 sensors-js[10352]: SI7021 data = {
Apr 13 18:57:00 ttn-gw04 sensors-js[10352]: "humidity": 32.761138916015625,
Apr 13 18:57:00 ttn-gw04 sensors-js[10352]: "temperature_C": 29.759372558593746
loragw@ttn-gw04:/opt/loragw $ node -v
v9.11.1
I’ve also updated new setup (take care it’s no more /opt/ttn-gateway but /opt/loragw so may be you’ll need to adapt to reflect your old setup)
Thank you for your response. I will try as soon as I can but now I’m away from my GW until end of April.
Hans
I did it without errors. But “sudo systemctl status sensors-js.service” always failed:
Active: failed (Result: exit-code) since Sat 2018-04-28 19:08:27 CEST; 6s ago
Process: 5430 ExecStart=/usr/bin/node /opt/ttn-gateway/bin/sensors.js (code=exited, status=1/FAILURE)
Main PID: 5430 (code=exited, status=1/FAILURE)
Apr 28 19:08:27 ttn-gateway systemd[1]: sensors-js.service: Main process exited, code=exited, status=1/FAILURE
Apr 28 19:08:27 ttn-gateway systemd[1]: sensors-js.service: Unit entered failed state.
Apr 28 19:08:27 ttn-gateway systemd[1]: sensors-js.service: Failed with result ‘exit-code’.
Apr 28 19:08:27 ttn-gateway systemd[1]: sensors-js.service: Service hold-off time over, scheduling restart.
Apr 28 19:08:27 ttn-gateway systemd[1]: Stopped CH2i TTN Gateway Sensors service.
Apr 28 19:08:27 ttn-gateway systemd[1]: sensors-js.service: Start request repeated too quickly.
Apr 28 19:08:27 ttn-gateway systemd[1]: Failed to start CH2i TTN Gateway Sensors service.
If I start the service by hand it succeeded.
I have node version 6.9.2. Could this cause the error? How can I update node to version 9.11.1?
Meanwhile, I’m on node v9.11.1 but the problem remains. Starting by hand works but not automatically:
Apr 29 07:19:00 ttn-gateway systemd[1]: Started CH2i TTN Gateway Sensors service.
Apr 29 07:19:01 ttn-gateway sensors-js[3647]: /opt/ttn-gateway/bin/node_modules/bindings/bindings.js:88
Apr 29 07:19:01 ttn-gateway sensors-js[3647]: throw e
Apr 29 07:19:01 ttn-gateway sensors-js[3647]: ^
Apr 29 07:19:01 ttn-gateway sensors-js[3647]: Error: Module version mismatch. Expected 46, got 48.
Apr 29 07:19:01 ttn-gateway sensors-js[3647]: at Error (native)
Apr 29 07:19:01 ttn-gateway sensors-js[3647]: at Object.Module._extensions…node (module.js:434:18)
Apr 29 07:19:01 ttn-gateway sensors-js[3647]: at Module.load (module.js:343:32)
Apr 29 07:19:01 ttn-gateway sensors-js[3647]: at Function.Module._load (module.js:300:12)
Apr 29 07:19:01 ttn-gateway sensors-js[3647]: at Module.require (module.js:353:17)
Apr 29 07:19:01 ttn-gateway sensors-js[3647]: at require (internal/module.js:12:17)
Apr 29 07:19:01 ttn-gateway sensors-js[3647]: at bindings (/opt/ttn-gateway/bin/node_modules/bindings/bindings.js
Apr 29 07:19:01 ttn-gateway sensors-js[3647]: at Object. (/opt/ttn-gateway/bin/node_modules/i2c-bus/i2
Apr 29 07:19:01 ttn-gateway sensors-js[3647]: at Module._compile (module.js:409:26)
Apr 29 07:19:01 ttn-gateway sensors-js[3647]: at Object.Module._extensions…js (module.js:416:10)
Apr 29 07:19:01 ttn-gateway systemd[1]: sensors-js.service: Main process exited, code=exited, status=1/FAILURE
Apr 29 07:19:01 ttn-gateway systemd[1]: sensors-js.service: Unit entered failed state.
Apr 29 07:19:01 ttn-gateway systemd[1]: sensors-js.service: Failed with result ‘exit-code’.
Apr 29 07:19:01 ttn-gateway systemd[1]: sensors-js.service: Service hold-off time over, scheduling restart.
Apr 29 07:19:01 ttn-gateway systemd[1]: Stopped CH2i TTN Gateway Sensors service.
Any suggestion for me to try out? It would be great to get it work.
I did a workaround using tmux but it‘s not as elegant as your solution - if it really works!
